197
I recently asked a question on Stack Overflow to find out why isset() was faster than strlen() in PHP. This raised questions around the importance of readable code and whether performance improvements of micro-seconds in code were worth even considering.
My father is a retired programmer, and I showed him the responses. He was absolutely certain that if a coder does not consider performance in their code even at the micro level, they are not good programmers.
I'm not so sure - perhaps the increase in computing power means we no longer have to consider these kind of micro-performance improvements? Perhaps this kind of considering is up to the people who write the actual language code? (of PHP in the above case).
The environmental factors could be important - the Internet consumes 10% of the world's energy. I wonder how wasteful a few micro-seconds of code is when replicated trillions of times on millions of websites?
I'd like to know answers preferably based on facts about programming.
Is micro-optimisation important when coding?
My personal summary of 25 answers, thanks to all.
Sometimes we need to really worry about micro-optimisations, but only in very rare circumstances. Reliability and readability are far more important in the majority of cases. However, considering micro-optimisation from time to time doesn't hurt. A basic understanding can help us not to make obvious bad choices when coding such as
if (expensiveFunction() || counter < X)
Should be
if (counter < X || expensiveFunction())
(Example from @zidarsk8) This could be an inexpensive function and therefore changing the code would be micro-optimisation. But, with a basic understanding, you would not have to, because you would write it correctly in the first place.
Boz
  • 171
    Your dad is absolutely wrong, but in his defense: 20+ years ago, the tools (editor, compiler, debugger, profiler) were nowhere *near* as powerful as they are now, while memory and computing time were *significantly* more constrained and expensive. What he said was true back then, but the opposite is true today. – BlueRaja - Danny Pflughoeft Aug 08 '11 at 17:37
  • 130
    You father's advice is **outdated**. I would not ask how much it improves performance. I would ask where the bottleneck is. It does not matter if you improve the performance of a section of code if it makes no overall difference, your slowest link is going to determine the speed. In PHP this is writing to the network (unless you can prove IE measure otherwise); which translates into writing more readable code is more important. – Martin York Aug 08 '11 at 17:39
    how interesting - InfoWorld had an article on this just [last week](http://www.infoworld.com/d/application-development/lost-programming-skills-169171) – warren Aug 08 '11 at 18:18
  • 71
    If the key word is consider, he is not wrong. You have to have some clue about it. – JeffO Aug 08 '11 at 18:26
  • 40
    I'm sad because the famous [Premature Optimization](http://c2.com/cgi/wiki?PrematureOptimization) quote hasn't been mentioned yet: "Programmers waste enormous amounts of time thinking about, or worrying about, the speed of noncritical parts of their programs, and these attempts at efficiency actually have a strong negative impact when debugging and maintenance are considered. We should forget about small efficiencies, say about 97% of the time: **premature optimization is the root of all evil**. Yet we should not pass up our opportunities in that critical 3%." – Tamara Wijsman Aug 08 '11 at 20:17
    [KISS Principle](http://en.wikipedia.org/wiki/KISS_principle) 4 the win! – apacay Aug 08 '11 at 20:27
    Can you provide a source on "10% of the world's energy" ? – Michael Easter Aug 08 '11 at 23:12
  • @Michael Easter: It depends how you define "the internet". The data centres use [maybe 2%](http://www.earthtimes.org/business/greenpeace-calls-cloud-dirty/759/), but that's not counting the actual pc's and stuff. And it's all going up *very* fast, so 10% probably isn't ridiculous soon, if not quite yet. – FumbleFingers Aug 09 '11 at 00:59
  • Jeff Atwood's article is worth a read - http://www.codinghorror.com/blog/2004/08/why-arent-my-optimizations-optimizing.html – sarat Aug 09 '11 at 02:42
  • @Michael Easter my father told me - not sure where he got it from, will ask him – Boz Aug 09 '11 at 07:47
    `coder does not consider performance in their code even at the micro level, they are not good programmers` is very different from micro-optimizing. It's just good coding. – woliveirajr Aug 09 '11 at 12:09
  • @woliveirajr: That is the definition of micro-optimizing – BlueRaja - Danny Pflughoeft Aug 09 '11 at 12:33
    Note that `cheap() && expensive()` is ***not*** an optimisation of `expensive () && cheap()` in a language with short-circuit evaluation *unless* you can guarantee that both `expensive()` and `cheap()` are side effect free. – Mark Booth Aug 11 '11 at 10:30
  • I updated the code samples. Should be "||" (or) instead of && (and) because with && there in no difference between those two lines of code (they works the same). – webvitaly Aug 10 '12 at 12:53
    @TomWijsman Great quote. And the quote was [made in 1974](http://pplab.snu.ac.kr/courses/adv_pl05/papers/p261-knuth.pdf), so even a retired programmer like the OP's father should have come across it in his career :) – MarkJ Apr 17 '13 at 09:44
    possible duplicate of [Is premature optimization really the root of all evil?](http://programmers.stackexchange.com/questions/80084/is-premature-optimization-really-the-root-of-all-evil) – nawfal Jul 02 '14 at 14:02
  • see also: [Should you sacrifice code readability with how efficient code is?](http://programmers.stackexchange.com/questions/43151/should-you-sacrifice-code-readability-with-how-efficient-code-is) – gnat Aug 14 '15 at 09:52
  • @MarkBooth Also if the `expensive()` is false often enough `expensive() && cheap()` may perform better with short-circuit evaluation. – Jakub Kania Oct 12 '17 at 22:19
  • In what way @JakubKania (though perhaps we should take this to [chat]). – Mark Booth Oct 13 '17 at 13:33
  • One rarely mentioned, harmful side effect of optimizing at a low level too soon is that once that code is in place it freezes the upper level designs. At that point if you have to refactor due to other pressures on the project all that work at the lowest levels is wasted. This may be perfectly OK in Waterfall projects in well known technologies where the design cannot change, but not in more modern and flexible projects. – Patrick Hughes Feb 06 '19 at 19:12
  • Donald Knuth: "The conventional wisdom shared by many of today's software engineers calls for ignoring efficiency in the small; but I believe this is simply an overreaction to the abuses they see being practiced by penny-wise-and-pound-foolish programmers, who can't debug or maintain their "optimized" programs." (Structured Programming with go to Statements, 1974) – Pedro Amaral Couto Nov 20 '19 at 20:51
  • I don't understand some comments appealing to readability here. I think it's silly to say that "if (counter < X || expensiveFunction())" is not readable or maintainable. If it's more efficient and it's readable and maintainable, then, most probably, it's better. Merely quoting Donald Knuth is not a valid argument, especially if the quotations are out of context. He lamented developers avoiding optimizations for the sake of it. If the retired father is wrong, then Knuth was also wrong in 1974. – Pedro Amaral Couto Nov 20 '19 at 21:07
    Your father is a retired programmer that most probably worked on retired tech. It was just a few years ago that we barely had 16mb of RAM to work with. – T. Sar Feb 06 '20 at 18:41
32 Answers32
127
Micro-optimization is only important if the numbers say it is.
The requirements that you are developing against should have some specification of performance data, if performance is at all an issue to the client or user. As you are developing software, you should test the performance of your system against these requirements. If you aren't meeting performance requirements, then you need to profile your code base and optimize as needed to reach the performance requirements. Once you are within the minimum required performance, there's no need to squeeze any more performance out of the system, especially if you are going to compromise the readability and maintainability of the code any more (in my experience, highly optimized code is less readable and maintainable, but not always). If you can get additional performance gains without degrading the other quality attributes of the system, you can consider it.
There are instances, however, where performance is of the utmost importance. I'm mainly thinking in real-time systems and embedded systems. In real-time systems, changing the order of operations can have a huge effect on meeting the hard-deadlines that are required for proper operation, perhaps even influencing the results of computations. In embedded systems, you typically have limited memory, CPU power, and power (as in battery power), so you need to reduce the size of your binaries and reduce the number of computations to maximize system life.
Thomas Owens
  • 79,623
  • 192
  • 283
  • On the other hand, if there's an issue between using a slower vs. faster function, there is no reason to use the slower function - like here in case of isset. – Mavrik Aug 08 '11 at 17:32
    @Mavrik That's true. If you have two functions, X and Y, and Y is faster than X (at least for your particular conditions), there's no reason to not use Y, if the code is still as readable and maintainable. But if you don't know about Y and you need to refactor code to use Y instead of X, and performance (of that code segment) isn't an issue, then there's no reason to make that change. It's all about tradeoffs - performance, time, cost, effort, readability/maintainability, and so on. – Thomas Owens Aug 08 '11 at 17:37
    I agree wholeheartedly, I just wanted to make this point when it comes to micro-optimization - if it doesn't cost you anythng in terms of readability/time, do it. Otherwise don't. – Mavrik Aug 08 '11 at 18:52
  • +1 highly optimised code is less readable and maintainable... but not always. – Boz Aug 09 '11 at 07:51
  • More cases where performance is important: (1) gaming; (2) large amounts of data; (3) high traffic web site; (4) responsiveness of a highly complex UI; (5) service that's supposed to run in the background like virus checking; (6) finance; (7) smartphone; and so on. It's hardly limited to esoteric cases like RTS and embedded systems. – Rex Kerr Aug 09 '11 at 20:36
  • @Rex I've typically seen smart phones and other mobile devices considered to be embedded systems. You function on similar constraints as limited (although not so much anymore) processing power and battery life. Financal systems are often real-time systems. Large amounts of data, if you need quick responses, would also be real-time systems. – Thomas Owens Aug 09 '11 at 21:01
  • @Thomas, quick response != real-time. – Winston Ewert Aug 10 '11 at 02:08
  • @Winston The definition of real-time system is "a system that must satisfy explicit bounded response-time constraints or risk severe consequences, including failure." If a response to an event is mandated within a certain time constraint, then the system is a real-time system. – Thomas Owens Aug 10 '11 at 02:19
  • @Thomas, as I see it, "quick" isn't a certain time constraint as it is too vague. The thing that prompted me to respond is that making code run faster really isn't directly connected to real-time. Real-time doesn't have to be fast, it has to be within a certain timeframe no matter what. – Winston Ewert Aug 10 '11 at 02:22
  • @Winston "Quick" by itself isn't. However, when talking about the class of systems that have response times measured in fractions of a second, "quick" is a whole lot easier/shorter to say. :) – Thomas Owens Aug 10 '11 at 02:26
  • @Thomas, fair enough. – Winston Ewert Aug 10 '11 at 02:29
112
Whenever anyone asks about optimisation, I'm reminded of the quote from Michael A. Jackson
The First Rule of Program Optimisation: Don't do it.
The Second Rule of Program Optimisation (for experts only!): Don't do it yet.
Quote from Wikipedia corrected for British English. *8')
Implicit in the second rule is to profile your code and only spend time optimising things which will make a difference.
When programming in assembly, your father's assertion was correct. But that is much closer to the metal than most people program these days. Today even trying to optimise yourself (without profiling) can result in making your code run slower than if you'd done something the more common way, since the common way is more likely to be optimised by modern JIT compilers.
Even in C you have to be pretty good at optimisation to know more about how to optimise a section of code than the compiler does.
If you aren't familiar with much of what Ulrich Drepper talks about in his excellent paper What Every Programmer Should Know About Memory, then you are probably on a loser even trying to optimise youself. Contrary to the papers title however (which is actually an homage to David Goldberg’s equally fantastic What Every Computer Scientist Should Know About Floating-Point Arithmetic) not having this level of understanding does not necessarily stop you being a good programmer, just a different sort of programmer.
isset() vs. strlen() in PHP
I don't know PHP, so it really isn't obvious what isset() is meant to do. I can infer it from context, but this means that it will be similarly obscure to novice PHP programmers and might even cause more experienced programmers to double-take. This is the sort of idiomatic use of a language which can make maintenance a nightmare.
Not only that, but there is no guarantee that isset() will always be more efficient, just because it is more efficient now. An optimisation now might not be an optimisation next year, or in 10 years. CPUs, systems, compilers improve and change over time. If the performance of PHP's strlen() is a problem, PHP might get modified in the future, then all of the isset() optimisations may need to be removed to optimise the code once more.
Every optimisation has the potential to become a future anti-optimisation, so should be considered a possible code smell, to be kept to a minimum.
An example from personal experience
As an example of such an anti-optimisation, I once had to sanitise a huge codebase filled with code of the form if x==0 z=0 else z=x*y because someone had made the assumption that a floating point multiply was always going to be more expensive than a branch. On the original target architecture this optimisation made the code run an order of magnitude faster, but times change.
When we tried using this code on a more modern CPU which was highly pipelined the performance was horrifically bad - every one of these statements cause a pipeline flush. Simplifying all of these lines of code to just z=x*y made the program run an order of magnitude faster on the new architecture, restoring the performance lost by the anti-optimisation.
The problems we typically have to optimise for today are very different to the ones we had to optimise for 20 or even 10 years ago.
Then we worried about doing the most work per clock cycle, now we are more likely to be worrying about pipeline flushes, branch mispredictions and cache misses at the CPU level, but locks and interprocess communication are becoming much more significant as we move to multi-process and multi-processor architectures. Drepper's paper can really help with understanding many of these issues.
Mark Booth
  • 14,214
  • 40
  • 79
    Pipeline flush and cache miss is what you want to avoid :D They have horrible costs. but only on parts of code that excute them many many many many many times. – deadalnix Aug 08 '11 at 17:33
    One thing I would add is that compilers have come a long way and will optimize a lot of things for you. AFAIK, they do better optimizing clean, readable code than the tricky stuff. – Becuzz Aug 08 '11 at 18:43
  • +1 For don't optimize YET. If you waste your time on trivial statements, you won't have time to optimize the real bottlenecks later. And you won't find bottlenecks until the code is run and tested. – Phil Aug 08 '11 at 18:54
    +1 for providing an real example of a micro-optimisation that wasted time - and revealing that Michael Jackson was a programmer. – Boz Aug 09 '11 at 07:54
    +1 For the example. It perfectly illustrates why you should leave trivial transformations to the compiler. – back2dos Aug 09 '11 at 08:13
  • That's an AWESOME story. I might have to remember that! – Dave Dopson Aug 09 '11 at 20:27
  • Micro-optimizations that hurt performance only demonstrate that the person who is micro-optimizing doesn't know what they're doing. I think this falls under the "If you don't know what you're doing, don't do it" category. – Rex Kerr Aug 09 '11 at 20:31
    @Rex Kerr > in the exemple, the cost comes from branching, which cause CPU's pipeline flush. Floating point multiplication is expensive too. What is more exepensive depends higly on FPU and pipeline length of the CPU running the code. I wouldn't be surprised that this code ran faster on older CPU that have shorter pipeline and less effiscient FPU than current CPU. – deadalnix Aug 10 '11 at 23:22
  • @deadalnix - I agree, but that's part of what makes a good coder who knows how to optimize--know what is expensive and what is not on your target architecture (and, preferably, understand when the answer will be dramatically different on another architecture, especially if that one is more common). It's not an argument that optimization is bad, it's just an argument that coders are often bad at optimizing. So they either shouldn't do it until their profiler tells them to, or they should learn more before starting. I.e., if you don't know what you're doing, don't do it. – Rex Kerr Aug 11 '11 at 15:09
  • Is it possible that the "huge codebase" was actually old enough that the optimization helped at the time it was written? – phkahler Feb 20 '12 at 15:06
  • @phkahler If I remember correctly, it actually produced a greater than 10x speedup as it was often dealing with sparse matrices. The branch was 1 cycle, the assignment was 1 cycle, the floating point multiply was something like 27 cycles, so the CPU took either 2 or 28 cycles rather than always taking 27 cycles (there was no pipelining on this CPU). – Mark Booth Jan 18 '14 at 00:43
    With regard to the indicated example, a more interesting scenario would be, assuming `x` is a heavily-shared global variable, `if (x != 0) x=0;`. At first blush the `if` might seem nonsensical, but if many processors are simultaneously and repeatedly executing the above code, they can all cache the value of `x` as zero with no collisions. Eliminate the test, and every single time any processor executes this code it will cause a cache collision. What's really needed perhaps is a way to tell the compiler to generate the `if` or not, based upon whether it will help in the target architecture. – supercat May 13 '14 at 02:06
  • I'm note sure how that helps @supercat - whether you are reading the value of `x` to give it as an operand to the branch or reading `x` to give it as an operand to the multiply, you are still reading `x`. – Mark Booth May 13 '14 at 20:14
  • @MarkBooth: I was trying to show a *different* scenario (not involving multiplication) where an "optimization" might make code much faster in one caching architecture and much slower in another. If the goal of some code is to unconditionally make `x` be equal to zero, testing first to ensure it isn't already zero would be helpful in some caching systems (potential order-of-magnitude speed-up), but harmful in others (wasted effort). Someone who doesn't know which situation applies is unlikely to "guess" right. – supercat May 13 '14 at 20:21
  • Those papers have proven to be EXTREMELY helpful in optimizing massive data processing (think image processing / machine visioning). – CurtisHx May 15 '15 at 11:50
  • Also, if the language features some kind of macros, I would have expected that optimization to be behind a commented macro: `// Multiply is much more expensive than branching:\n#define MultZero(a, b, c) a = !b ? 0 : b * c` Good for documentation and for verifying the assumption (still) holds (and is relevant). – Deduplicator Mar 14 '21 at 20:55
  • I could have done that @Deduplicator but it would only be worth it *if* unit tests suggested that this was a viable optimisation on *any* target platform. Otherwise, adding additional layers of code complexity for no reason would just make the code harder to understand and reason about. – Mark Booth Mar 16 '21 at 10:46
  • @MarkBooth I rather meant that the original hand-optimizer should have done it that way, to document his reasons. Also, to allow easily rolling it back if needed, especially for verifying the choice. Yes, after you knew that was now a pessimization, simply returning to the natural code instead of leaving in the option was the right choice. Hope that clarified my comment. – Deduplicator Mar 16 '21 at 12:42
  • I'm sorry @deduplicator, I can't see how your comment helps me improve my answer. Plus, how do you know that the original author was male. It seems like a rather odd assumption. – Mark Booth Apr 06 '21 at 01:35
101
I both agree and disagree with your father. Performance should be thought about early, but micro-optimization should only be thought about early if you actually know that a high percent of time will be spent in small CPU-bound sections of code.
The problem with micro-optimization is that it is usually done without having any concept of how programs actually spend more time than necessary.
This knowledge comes from experience doing performance tuning, as in this example, in which a seemingly straightforward program, with no obvious inefficiencies, is taken through a series of diagnosis and speedup steps, until it is 43 times faster than at the beginning.
What it shows is that you cannot really guess or intuit where the problems will be. If you perform diagnosis, which in my case is random-pausing, lines of code responsible for a significant fraction of time are preferentially exposed. If you look at those, you may find substitute code, and thereby reduce overall time by roughly that fraction.
Other things you didn't fix still take as much time as they did before, but since the overall time has been reduced, those things now take a larger fraction, so if you do it all again, that fraction can also be eliminated. If you keep doing this over multiple iterations, that's how you can get massive speedups, without ever necessarily having done any micro-optimization.
After that kind of experience, when you approach new programming problems, you come to recognize the design approaches that initially lead to such inefficiencies. In my experience, it comes from over-design of data structure, non-normalized data structure, massive reliance on notifications, that sort of thing.
Mike Dunlavey
  • 12,815
  • 35
  • 58
88
  1. Write code, that is clean, concise, simple and self-explanatory.
  2. Make performance tests to identify bottlenecks.
  3. Optimize critical sections.
As a rule of thumb: 95% of your code is run 5% of the time. There's no point in optimizing before you profile/benchmark your code and see which are the 5% that are run 95% of the time.
Every idiot can do micro-optimization and any decent compiler/runtime will do this for you.
Optimizing good code is trivial. Writing optimized code and trying to make it good after that is tedious at best and unsustainable at worst.
If you seriously care for performance, then do not use PHP for performance critical code. Find the bottlenecks and rewrite them with C extensions. Even micro-optimizing your PHP code beyond the point of obfuscation won't get you nearly as much speed.
Personally, I liked doing micro-optimization a lot when I started programming. Because it is obvious. Because it rewards you quickly. Because you don't have to take important decisions. It's the perfect means of procrastination. It allows you to run away from the really important parts of software development: The design of scalable, flexible, extensible, robust systems.
Carl Manaster
  • 4,173
back2dos
  • 29,980
  • 73
  • 114
    The best answer to me was found, remarkably, in the Bugzilla Developer's Guide: "If you're trying to be clever instead of trying to be readable, then maybe you're trying to make things "faster?" If so, just remember: don't solve a problem before you know it exists. If you don't know (by actual, detailed tests) that your code is slow, don't worry about making it "faster." This isn't just limited to optimization--many programmers are constantly solving problems that nobody has ever experienced. Don't do that." http://www.bugzilla.org/docs/developer.html#general – Marco Aug 09 '11 at 09:45
    I generally agree - except for one line, I contend that "every idiot *thinks* they can micro-optimize"... ;) – Nim Aug 09 '11 at 14:24
  • @Nim: Point taken ;) – back2dos Aug 09 '11 at 15:59
29
I would agree with your father: "If a coder does not consider performance in their code even at the micro level, they are not good programmers." The key is to "consider performance". That is not equivalent to "do micro-optimizations at every step".
I agree with most of the other comments - what used to make C programs faster may not do so today - but there are other serious things to consider: Should I use C or C++? Classes with simple overloaded operators can kill performance if you use them a lot. Does that matter? It depends on your application, but if you don't even CONSIDER it, you're not a very good programmer. Some folks might consider it for about 2 milliseconds and dismiss it, but I think far too many literally don't even consider it.
The reality is that with optimization, code can get harder to read. Code will take longer to write. Code will be somewhere between a little faster and an order of magnitude faster (that's rare). Your customers probably won't know the difference.
Another reality is that people like to reuse code, and where it ends up may be quite different than when you wrote it. Suddenly people may care.
As an example, say you wrote something like Angry Birds on a PC, or for a game console. You disregarded optimization in your physics system and your graphics system - because 2.5 GHz dual cores are basically the minimum these days, and your game works good enough. Then smart phones come along and you want to port it. Oh darn, a 600 MHz ARM core?
Think of a web site - something thrown together in a weekend like Hot or Not. You use whatever database is handy, write everything with rapid development in mind, launch by emailing your friends a URL. Three months later your server is dying from overload and there's nothing you can do to scale up. It happens all the time. The largest web sites have power bills measured in hundreds of kilowatts or even megawatts. Think about that, there are megawatts to be saved through code optimization.
Like your father said, you must at least consider it. Most folks don't even know how much performance is on the table and gloss over it with a quick quip about "premature optimization" and "don't do it". These are not good programmers.
This is not a popular opinion on these sites. Bye bye reputation points....
Peter Mortensen
  • 1,050
phkahler
  • 501
    Sure, you should consider it (in the back of your head) and typically reject it, unless its shown to be worth it. You need to consider that optimizations usually lower code readability and can increase the time taken to code and maintain by a factor of 10 or so. If the program isn't CPU intensive, its often not needed. Recognize that your compiler is usually much better at optimizing than you are, and that many of your optimizations will actually hurt performance. If its not worth your time to test your optimizations and profile, its not worth your time to optimize. – dr jimbob Aug 08 '11 at 20:34
    Your Angry Birds example shows exactly why you should *not* optimize prematurely. In porting from desktop to console to mobile device(s), you're dealing with (at least) three very different types of hardware and optimization for one may hurt instead of help on another. Worse, optimizing is going to make the code harder to understand, therefore harder to port. Sure, pick efficient algorithms from the start, but save micro-optimization for the performance tuning phase when real data will tell you where the trouble is on each platform. – Caleb Aug 09 '11 at 14:50
  • @Caleb: The Angry Birds example does illustrate why not to optimize for particular hardware. It also illustrates how you may build an entire app without bothering to do more general "C level" optimizations and then getting burned. Actually not burned, but having trouble going beyond your original intent. – phkahler Aug 09 '11 at 18:06
25
Let's first take your case: PHP
  • I don't think PHP is a kind of language (both because of its nature and its main domain of application) that you need to worry about these "micro-optimizations". PHP code is mostly optimized with opcode caching.
  • The programs written in PHP are not CPU bound, they're mostly I/O bound, so these optimizations won't be worth your time anyway.
  • Anything that you MUST optimize should probably be snuck into a C extension and then dynamically loaded in the PHP runtime
  • So as you can see, we get no incentive by micro-optimizing our code in PHP -- on the other hand, if you spend that time in making PHP code more readable and maintainable -- that will pay you more dividends.
In general,
I wouldn't spend "TOOOOO" much time optimizing my code in a dynamic language like Python or Ruby -- because, they are NOT designed for CPU intensive number-crunching tasks. They solve different class of problems where modelling a real world situation in an elaborate manner (which is easy to read and maintain) -- which is called expressivity -- is more important than speed. If speed were the prime concern, they wouldn't be dynamic in the first place.
For compiled programms (C++, Java), optimization is more crucial. But there too, first you have to look at the nature/domain/purpose of the program you're writing. You should also carefully weigh the time to micro-optimize against the gains from that optimization. If you need even more optimization, then you may as well consider going a step downward -- and code those pieces of your code in assembler.
So, to answer your original question -- "Is micro-optimisation important when coding?" -- the answer is -- it DEPENDS --
  • What kind of thing you're doing: application domain, complexity?
  • Are microsecond speed improvements REALLY important for your program?
  • What sort of optimization will be most gainful? It may not always be code optimization, but something external.
  • How much "goodness" (in terms of speed) you're reaping out of the time you invest micro-optimizing?
  • Can better speeds be achieved in other ways -- by changing the hardware, RAM & processor, executing code parallelly, or on a distributed system?
Not only is micro-optimization (code optimization for that matter) time consuming, it "distorts" the natural readability of your code, thus making it maintenance-heavy. Always consider it a last resort -- always try to optimize the entire application by adopting better hardware and better architecture than optimizing individual code files.
Peter Mortensen
  • 1,050
treecoder
  • 9,475
  • 47
  • 84
18
There seem to be many answers that say micro optimization is
But well I know that there are some optimizations where there is no readability impact, and I just like to do those for fun. I saw on some of my school assignments (which were all speed based), that it's always nice to consider micro optimization when writing conditional statements like:
if (counter < X && shouldDoThis()) // shouldDoThis() is an expensive function
is always nicer than
if (shouldDoThis() && counter < X )
There are quite a few ways to "speed up" your code like that and the difference is usually negligible (not always though), but I feel better if I write it like that.
I don't know if anyone even considers this as an actually optimization, but I think a programmer should know and consider these things when writing their code.
zidarsk8
  • 101
  • +1 you said it's 'fun' but is it important? This is the kind of schooling that I think is in question. – Boz Aug 09 '11 at 07:37
    It might not be important for this *particular* case. However I think it is **very** important to be able to recognize optimizations like these so that when it *does* matter, you don't have to spend unnecessary time profiling and optimizing after the fact. – tskuzzy Aug 09 '11 at 17:01
  • @BozKay knowing more and learning, is always important. Lets say that the other condition is something like nLogn. If you don't normally think of this stuff, then you probably wont think of it when it would really matter. – zidarsk8 Aug 10 '11 at 00:37
  • @zidarsk8 personally, I think your point is important. – Boz Aug 10 '11 at 02:37
    This is a ***very* dangerous** example. An *optimisation* should ***never** change behaviour*. Even suggesting that `cheap() && expensive()` is an optimisation of `expensive () && cheap()` invites people to blindly substitute one with the other without regard for the *significant semantic change* it creates (in languages where `&&` is the short-circuit operator). – Mark Booth Aug 11 '11 at 10:23
    If the functions don't have side effects, they are equivalent and one is faster. If they do have side effects, one should not be writing the code like this in the first place. I would even say this is one that should be done out of habit - unless it actually changes behavior. – phkahler Feb 14 '12 at 16:59
    @MarkBooth I have to agree with phkahler here, none of these functions should have side effects! The order of condionos in an if statement must not have an effect on the outcome of the program. My example would be better written as `if (x<100 && isPrime(x))`, just to make it more clear. – zidarsk8 Feb 16 '12 at 22:02
  • @phkahler - So what you are saying is that it's Ok to optimise like this if the function has no side effects. But that's exactly what I was saying too - if you know that the function has no side effects then you know that there will be no change in behaviour by swapping the LHS & RHS of a short-circuit operator. – Mark Booth Feb 19 '12 at 22:26
    @zidarsk8 - If an *optimisation* changes anything other than *the speed of execution* then it is **not an optimisation**. As programmers we often *have to be pragmatic*, and sometimes that means we cannot guarantee that all functions used with a short-circuit operator are pure - especially when our code calls third party libraries over which we have no control. In that situation you have to be careful that inexperienced programmers are not encouraged to introduce bugs in the name of *optimisation*. – Mark Booth Feb 19 '12 at 22:33
  • For these who recognize the "optimized" version might have just made the program slower, please upvote this comment:-) – Codism May 15 '15 at 18:30
Early in my career, blanket statements such as, "don't micro-optimize" led to a lot of confusion. Everything is circumstantial; thus, the reason people say, "best practice" rather than "do this".
"Best practice" is the top choice considering all circumstances. For example, LINQ and Entity Framework should be used in lieu of inline SQL. At my company we are on SQL Server 2000. SQL Server 2000 does not support Entity Framework. Best practices require:
  • Selling my boss on the idea of buying a new version of SQL Server which means several thousand bucks.
  • Selling developers on the idea of learning new technology.
I know from experience this is not going to happen. So, I could quit, stress to no end or not follow the best practice.
There are political, technical and monetary considerations behind decisions that affect the overall outcome. Remember this fact when making a decision and choose your battles wisely.
"For everything there is a season, a time for every activity under the heaven."
Peter Mortensen
  • 1,050
P.Brian.Mackey
  • 11,123
  • 87
    BTW, you can use [Dapper](http://code.google.com/p/dapper-dot-net/) as a micro-ORM alternative to inline SQL. – Dan Aug 08 '11 at 17:13
    `LINQ and Entity Framework should be used in lieu of inline SQL` -- Until you actually need inline SQL to optimize something; the SQL that EF produces is not always optimal. – Robert Harvey Aug 08 '11 at 17:52
    fwiw, if your boss is worried about the licensing costs of SQL 2k8 (or whatever else may be current), you should point-out that it's old enough to be coming-up on EOL **VERY** soon (if it's not already) – warren Aug 08 '11 at 18:19
  • @warren - Some companies do not take such things into consideration. For some, if it still "works" then they will not upgrade. By work, I mean the server still runs. We already see a lack of support with EF. That is simply not enough to convince them to spend any money. – P.Brian.Mackey Aug 08 '11 at 18:44
  • @P.Brian.Mackey - understood 100% (seen it *FAR* too often in my career already) .. but it's still something to consider :) – warren Aug 08 '11 at 18:45
    Just so you know, you can use EF with SQL 2000. The designer does not work, but the actual entity framework does support SQL 2000. To get around the designer limitation, you can create a local database in sql 2008 express with the same schema as the sql 2000 database, point the designer at that to generate all the classes, then go into the .edmx file and change the target database version to 2000 and point the connection string at your sql server 2000 database. Not the best solution, but if you can't upgrade it works. – Neil Aug 08 '11 at 21:52
This is always a tradeoff.
First, the computer industry is about money at the end. What you need to do as a developer is generate value for customer so you get money (that's an oversimplification but the main point is here).
Developer time costs money. Machine power costs money too. Usually, this second cost is way lower than the first one. So, this is capital to have a readable code and maintainable code, so developer can spend most of their time delivering value.
Micro-optimization can, in some case, be important. But they usually involve less readable code, or less extendable code (this is not the case of your linked example, but in general, it is). This will cost at some point developer's time. This time being more expensive than machine power, this is a waste.
Second, micro-optimization in a large project can make it harder and harder to maintain/evolve. The problem with that is that when evolving, some other optimisation may be now impossible to do. With an evolving application, you'll typically end up with a solution that is slower than what you would have had without doing those optimizations.
Third, the optimization is often irrevelant as algorithm complexity will generally overcome any micro-optimization you could have done if the data set grows. Sadly, as micro-optimization make your code harder to maintain/evolve, thoses optimisation may be harder to do.
Sometime, the value is in this optimization (think about latency critical programs, like in video games or an aircraft's autopilot). But this has to be demonstrated. Usually your program spend most of the time in a limited portion of code. Whatever micro-optimization you do, you'll never get your programs any valuably faster without identifying the bottleneck and work on this part.
Asking your question as you did showed that you didn't benchmark the problem on an actual program. In this case, you could have do the trick and noticed if it was faster or not. So you were asking that before having any problem. This is where the problem is. You were handling the problem of optimization the wrong way.
As maintenance and evolution are usually more valuable than micro-optimization, be sure to have the right interface before doing any. Then if parts of your program are abstract enough for one another, you can micro-optimize one without messing up the whole thing. This requires that your interface is running for long enough to be trusted.
warren
  • 619
deadalnix
  • 5,973
  • "There is always a tradeoff". True, reducing one variable will increase the other, *if the program is on the tradeoff curve*. In my experience, most programs are nowhere near the tradeoff curve, and have plenty of room for both variables to be reduced. – Mike Dunlavey Aug 08 '11 at 18:03
  • +1 maintenance and evolution are more valuable that micro-optimisation. Although I'm sure that the computer industry is about more than just money? For example, open source, education, innovation, governance, community, etc. I'm sure money can be found at the root of it, but that is true of most things. – Boz Aug 09 '11 at 08:08
  • @Boz kay > This is partially true. First because your boss and custome mostly don't know a thing about thoses and care about money. If you want to promote some open source tools, you have to tell them how it will improve the brand of the company or how it will reduce devellopement costs. Plus, making developpers happy is a way to get good dev in your company. Good dev makes money (mostly throw quality and innovation). At the end, money is the key. And I'm writting that from my linux computer beein a great free software supporter. The same goes for education. – deadalnix Aug 09 '11 at 12:19
Performance is a Feature
Jeff Atwood's article is a great one on building a high performance website and the importance of doing so...
That said, don't focus on micro-optimization until you need to. There are more cost beneficial optimization you can perform. Focus on the architecture, not the code. Most web sites I have seen that have performed slowly had high level problems (unnecessary web service layer, poor database design, overly complicated architectures) that not only adversely affected performance but were deeply ingrained and difficult to fix.
When you're building a website, your client side code and database logic is far more likely to cause performance problems than your server side code. Like anything though, if you have performance problems you'll know, even better profile your code and you can find them early on.
Mike Cellini
  • 1,865
It is not important to micro optimize while writing the code. Optimization should be done with the help of a profiler, optimizing the code where it matters.
HOWEVER, a programmer should try to avoid doing obviously stupid things while writing the code.
For example, don't do repeated expensive operations inside a loop. Store the value in a variable outside the loop and use that. Don't do things like string comparisons or regex over and over again in an often called function, when you can go up a level, do the comparison and make it into an integer or a function reference or a derived class.
These things are easy for an experienced programmer to remember and almost always improve the code quality.
Zan Lynx
  • 1,300
  • Realised I need to be clearer in my question edit, I was saying the same thing really - I've updated it. – Boz Aug 10 '11 at 17:08
What do you want to optimize?
  • Software performance?
  • Reliability?
  • Programmer productivity?
  • Customer satisfaction?
  • Power efficiency?
  • Maintainability?
  • Time to market?
  • Cost?
"Optimize" doesn't always mean making the code run as fast as possible. There are times when finding the absolute fastest way to do something is important, but that's really not all that common in most code. If users can't notice the difference between 50 and 100 microseconds, there's effectively no difference between the two in code that will only run occasionally. Here's an example:
If you need to continually update a display of the length of the user's input and the amount of time that it takes either of two routines to determine that length is much smaller than the time between two consecutive keystrokes, it really doesn't matter which routine you use. On the other hand, if you need to determine the length of a billion strings, you'll probably want to pay close attention to performance differences between different routines. In the first case, you might prefer to write code that's easy to understand and verify; in the second case, you might be willing to trade readability for speed.
In any case, if you're going to optimize your code, you should profile your code before and after any changes you make. Programs these days are complicated enough that it's often hard to tell where the bottlenecks are; profiling helps you optimize the right code and then show that the optimizations you made really worked.
You didn't say when your father retired or what kind of programming he did, but his reaction isn't surprising. Historically, memory, secondary storage, and computing time were all expensive, and sometimes very expensive. These days, all of those things have become very cheap compared to programmer time. At the same time, processors and compilers have become able to optimize code in ways that programmers could never match. The days when programmers use little tricks to bum a few machine instructions here and there are mostly gone.
Caleb
  • 38,959
  • 94
  • 152
    +1 Not to mention that in the past few years, mobile devices have again become highly dependent on code optimization. Someone who does not write optimized code or at least consider it might have a hard time getting their CPU intensive app to run smoothly on a mobile device. – Tyler Aug 08 '11 at 20:42
  • +1 very much like your list of possible optimisations. He used assembly/fortran – Boz Aug 09 '11 at 08:14
  • @Styler: it wouldn't be long until mobile devices have quad core CPU with GBs of memory, we already have dual core smartphones. – Lie Ryan Aug 09 '11 at 23:37
  • @Lie Ryan: yes this is true, but like most pioneers they had to travel in wooden boats ;) – Tyler Aug 10 '11 at 13:41
Developer time costs more than computer time. That's usually what you want to optimize. But:
  • There's a difference between micro-optimization and algorithmic complexity. Spend enough time to be confident that you are using the right algorithm.
  • Make sure you're asking the right question, select (select count(*) from foo) >= 1 is not the same thing as select exists(select 1 from foo).
  • some language idioms are popular simply because they are faster, It's ok to use those, since most fluent users of the language will be familiar with them. (your example is a good example).
When deciding what to optimize, always remember Amdahl's law. See the link for precise math; the pithy statement to remember is:
If one part of your program accounts for 10% of its runtime, and you optimize that part to run twice as fast, the program as a whole will only speed up by 5%.
This is why people always say it's not worth optimizing parts of your program that don't occupy more than a few percent of total runtime. But that's just a special case of a more general principle. Amdahl's law tells you that if you need to make the entire program run twice as fast, you need to speed up every piece by an average of 50%. It tells you that if you need to process twenty gigabytes of data, there are only two ways to make that go faster than the time it takes to read twenty gigabytes off the disk: get a faster disk, or make the data smaller.
So what does Amdahl's law say about micro-optimizations? It says that they're maybe worth it if they apply across the board. If you can shave one percent off the runtime of every function in your program, congratulations! You've sped up the program by one percent. Was that worth doing? Well, as a compiler guy I would be delighted to find an optimization that did that, but if you're doing it by hand, I'd say look for something bigger.
zwol
  • 2,576
    +1 for Amdahl quote, but I don't agree with "to make the entire program run twice as fast, you need to speed up every piece". I would say you don't actually speed up any "piece". Rather, you find unnecessary work, and eliminate it. *Especially* function calls, if the program is anything larger than a toy. Much of the common thinking about performance seems to completely ignore the importance of finding whole unnecessary branches of the call tree (which can be single instructions), and lopping them off. – Mike Dunlavey Aug 09 '11 at 02:38
  • The devil's in the word "average" there. It is mathematically the case that to speed up a program by 50% every piece must be sped up by 50% *on average*. Now, if you can divide the program into a job that takes 75% of runtime and another that takes 25%, and speed the former up 3x, that'll give you 50% overall despite not having done anything to the latter job. But the much more common case is that there are dozens of "jobs" that each take less than 5% of runtime - and then you have to speed up or get rid of many of them. – zwol Aug 09 '11 at 03:30
  • I think there's an even more common case. There's a "job" taking 50% of the time, but you *don't actually need it*, so you remove it entirely, reducing overall time by that amount, then repeat. I know this is hard to accept - that programs can be spending large fractions of time doing things that (in hindsight) are totally unnecessary. But [here's my canonical example](http://stackoverflow.com/questions/926266/performance-optimization-strategies-of-last-resort/927773#927773). – Mike Dunlavey Aug 09 '11 at 12:43
It depends upon what stage of development you are at, when initially starting to write something, micro-optimizations should not be a consideration as you are going to get more performance gains by using good algorithms than you are by using micro optimizations. Also, consider what you are developing as time sensitive applications are going to see more benefits from micro optimization considerations than generic business applications.
If you are testing and extending software then micro-optimizations will likely hurt you they tend to make code harder to read and even introduce their own unique set of bugs that need to be fixed along with anything else that needs to be fixed.
If you are actually getting complaints from users about slow code then they might be worth considering but only if everything else has been resolved, namely:
  • Is the code well written?
  • Is the application able to access its data without any issues?
  • Can a better algorithm be used?
If those questions have all be answered and you are still having performance issues, then it might be time to start using micro-optimizations in the code but odds are that other changes (i.e. better code, better algorithm, etc) is going to net you more of a performance gain than a micro-optimization will.
John Saunders
  • 463
rjzii
  • 11,274
  • 71
Execution speed is one of many factors that contribute to the quality of a program. Often times, speed has an inverse correlation with readability/maintainability. In almost all cases, code must be human readable so that the code can be maintained. The only time that readability can be compromised is when speed is an essential requirement. The requirement to make code faster than full readability/maintainability allows is hardly ever applicable, but there are certain cases where it will. The main thing to remember is that micro-optimized code is often hacky code, so unless there is a defined requirement somewhere, it is almost always the wrong way to solve the problem. For example, the user will almost never notice the difference between .5 second and 1 second execution times in CRUD operations, so you do not need to go into an assembly-interop-hackfest to get to that .5 seconds. Yes, I could fly a helicopter to work and it would be 10 times as fast, but I do not because of the price and the fact that helicopter is much more difficult to fly. When you micro-optimize code needlessly, this is exactly what you are doing: adding needless complexity and cost to reach a superfluous goal.
Morgan Herlocker
  • 12,722
  • 47
  • 78
Micro-optimisation is important when you hit a constraint. The thing you care about might be memory, might be throughput, might be latency, or might be power consumption. Note that these are system-level characteristics; you don't need to (and can't) optimise every function in every way.
Embedded systems are more likely to need micro-optimisation because constraints get hit more easily. However, even there micro-optimisation only gets you so far; you can't micro-optimise your way out of a bad design. The point about good design in a system is that you can reason about the system as a whole. Components that needs micro-optimisation should be neatly exposed and optimised in a way that doesn't compromise the design of the system.
Note that small "embedded" systems today can be pretty close to the Vaxen or PDP-11s of yesteryear, so these issues used to be more common. On a modern general purpose system doing modern general commercial computing, micro-optimisation is rare. This is probably part of why your father takes the position he does.
However, it doesn't matter whether you are dealing with nanoseconds, milliseconds, seconds or hours; the issues are the same. They have to be evaluated in the context of the system and what you are trying to achieve.
This is an example from a recent question I answered on Stack Overflow for a case where micro-optimisation was necessary: Open source video encoders for an embedded system.
janm
  • 101
The greatest problem with micro-optimization is that it leads you to write a code harder to maintain.
Another issue is depending on the computer configuration sometimes your micro-optimization might have a worst performance than without the 'optimization'.
Making many micro-optimization will consume you a lot of time fighting against something that doesn't really matters.
A better approach is by making a cleaner code, easier to maintain, and if you get performance issues you run a profile to figure out what really is making your code slow. And knowing exactly what is really bad you can fix it.
I'm not saying that not doing micro-optimizations is excuse for writing stupid code.
Daniel Moura
  • 121
If you start to worry about milliseconds, you should consider to give up PHP and use C or Assembly instead. Not that I would want to do this, it just makes no sense to discuss such numbers and use a scripting language. Does your code iterate with this command that often anyway?
The environmental factors are out of question here, those servers run 24/7 anyway and if they actually process something would only matter if it's really a task running for a very long time.
Most likely the light in your office and the energy our computers used while we all were typing questions and answers, used up far more energy than any kind of micro optimization you can reasonably apply to your applications will ever save.
thorsten müller
  • 12,058
  • 49
You mention that your dad is a retired programmer. Programmers who worked in the mainframe world had to be very concerned about performance. I can remember studying a US Navy activity where their mainframe was hardware-constrained to 64 KB of memory per user. In that programming world you have to eek out every little tiny bit you could.
Things are vastly different now and most programmers don't need to worry so much about micro-optimizations. However, embedded systems programmers still do and database people still very much need to use optimzed code.
Peter Mortensen
  • 1,050
HLGEM
  • 28,709
  • 67
  • 116
You should choose the best, simple algorithm for the task. The reason it needs to be simple is to keep the code readable. The reason it needs to be the best, is to avoid starting out with bad runtime characteristics. Do not blindly choose BubbleSort when you know that you will have large datasets. It is fine, however, for the occasional sort of 10 elements.
THEN, if the profiling numbers show that your choice of best, simple algorithm wasn't good enough, you can start optimization (which is usually as the cost of readability).
  • BubbleSort can actually be better than quicksort or mergesort when your data is nearly sorted with only a few stray elements that is not too far off from their final destination. For all other tasks though, you should use the built-in sorting function that your programming language provides for you; it's the simplest way to get started (and built-in sorting function in most languages have good performance). BAD ADVICE: `start out with bad runtime characteristic`, don't deliberately start with a bad runtime characteristic. – Lie Ryan Aug 10 '11 at 13:50
  • @Lie, if you KNOW that your data is nearly sorted and you THEREFORE can use bubblesort, you are not exactly _blindly_ choosing your algorithm... Also thanks for pointing out the typo. –  Aug 10 '11 at 14:11
I've said it before, and I'll say it here: "Premature optimization is the root of all evil". This should be one of the rules at the center of any programmer's mind.
Code can, to a point, always be faster than it currently is. Unless you're hand-packing assembly with a particular chip in mind, there's always something to be gained through optimization. However, unless you WANT to be hand-packing assembly for everything you do, there has to be a quantitative goal, which once you meet, you say "that's enough" and stop optimizing, even if there is still a glaring performance-sucker staring you in the face.
Beautiful, elegant, extremely performant code is useless if it doesn't work (and by "work" I mean produce the expected output given all expected inputs). Therefore, producing code that works should ALWAYS be the first priority. After it works, you evaluate performance, and if it's lacking you look for ways to make it better, up to the point where it's good enough.
There are some things you do have to decide up front that will impact performance; very basic decisions like what language/runtime you will use to implement this solution. Many of these will impact performance by many orders of magnitude more than calling one method vs another. Honestly, PHP, as a scripted language, is already a performance hit, but as very few scripted sites are built from the bottom up in C/C++, it's comparable to other technologies you'd likely choose from (Java Servlets, ASP.NET, etc).
After that, I/O message size is your next-biggest performance killer. Optimizing what you read from and write to the hard disk, serial ports, network pipes, etc will usually improve the program's run time by many orders of magnitude even if the algorithms behind the I/O operations were efficient. After that, reduce the Big-O complexity of the algorithm itself, and then if you absolutely must, you can "micro-optimize" by choosing less expensive method calls and making other esoteric decisions at low levels.
KeithS
  • 21,994
  • 52
  • 79
No, given that there are platforms like JVM and .NET where code is written for a virtual machine and thus trying to optimize execution may not work out so well as what is optimal on a developer's desktop isn't necessarily the same on a server. Look at how far removed from the hardware some of these pieces of high-level software are for another point here. Something to consider is given the diversity of hardware, how realistic is it to optimize code for specific chips like a CPU or GPU when a new model will probably come out in less than a year?
Another question here to consider is performance as measured by what metric: Speed of execution, memory used in execution, speed of development of new features, size of the code base on a server in compiled or de-compiled forms, scalability, maintainability, etc.? If taken broadly enough the question becomes trivial, but I'm not sure how broadly you meant to take performance as really that can be almost anything as long as it can be measured in some way.
Some micro-optimizations may work and some may not work which is where one can wonder how worthwhile is it to perform such work compared to other work that may be seen as much higher priority such as new features or fixing bugs. The other question would be whether or not an upgrade of hardware or software may break some of those optimizations, too.
Peter Mortensen
  • 1,050
JB King
  • 16,795
  • 40
  • 76
    Note that you **can** absolutely do micro-optimizations on platforms like the JVM and .NET, they just take slightly different forms. But the same is true if you compare and old, simple C compiler with a more modern, highly optimizing compiler: the optimizations that the user can do will look different. – Joachim Sauer Aug 08 '11 at 19:40
Code should be written to be absolutely clear about what it does. Then, if and only if it's too slow, go back and speed it up. Code can always be changed to be faster later, if it can be understood- but good luck changing it to be clear if it's fast.
DeadMG
  • 36,794
  • 70
  • 139
It is important if:
1) Someone's life depends on your code. A function taking 25ms to execute in someone's heart rate monitor is probably a bad idea.
I personally take a two pronged approach -- there are micro-optimizations you can do that won't affect readability -- obviously you want to use those. But if it affects readability, hold off -- you won't get much benefit and it actually might take you longer to debug in the long haul.
ansiart
  • 101
    Just a few minor points on your example: A function in a heart rate monitor that takes 25ms would not be a problem as long as other necessary tasks could happen with the required response time. Interrupts are good for this. And 25ms latency for something that is just monitoring real-world events to update a display for human consumption probably isn't a problem. – janm Aug 09 '11 at 01:11
IMHO code-readability is more important than micro-optimization because in most part of cases micro-optimization does not worth it.
Article about non-sense micro-optimizations:
As most of us, I am tired to read blog posts about non-sense micro-optimizations like replacing print by echo, ++$i by $i++, or double quotes by single quotes. Why? Because 99.999999% of the time, it is irrelevant. Why? Because 99.99% of the time, you'd better install a PHP accelerator like APC, or add these missing indexes on your database columns, or try to avoid those 1000 database requests you have on the homepage.
print uses one more opcode because it actually returns something. We can conclude that echo is faster than print. But one opcode costs nothing, really nothing.
I have tried on a fresh WordPress installation. The script halts before it ends with a "Bus Error" on my laptop, but the number of opcodes was already at more than 2.3 millions. Enough said.
So in most cases micro-optimization saves 1 operation among of millions, but makes readability worse.
webvitaly
  • 101
Other answers are right on the money. But I'll add another point where one have to differentiate what's premature optimization/micro-optimization and writing performant code that reflects an understanding of the behaviour of the language/framework constructs (sorry, couldn't find a one word for the last). The last one is a good coding practice and one should generally do!
I will explain. Bad optimization (read premature/micro optimization) is not when you optimize sections of code without profiling to know if they are really the bottlenecks. It's when you optimize based on your assumptions, hearsays and undocumented behaviours. If it's documented and does something in a more efficient/logical manner however small it is, I call it good optimization. As others have stated, both of these have cons and almost no pros at all as far as earning you good business is concerned, but still I do the latter, not the former, if it doesn't totally defeat readability. Yes readability/maintainability is of utmost importance and it's about where you draw the line.
I'll reiterate the points made by others here as the futility of both good and bad optimizations:
  1. Your dependencies to a specific problem can change and any time spent on optimizing before completing the logical section of your application is a waste of time. I mean optimizing at a relatively early stage. Today you have an List<T> and by the time your app ships you had to change it to LinkedList<T> and now all the benchmarking was a waste of time and effort.
  2. Mostly the real bottleneck of your application (read as measurable difference) could be 5% of your code (mostly the sql ones) and optimizing the other 95% doesn't give your customers any benefit.
  3. Usually "technically" better performing code means more verbosity which in turn means more error prone code which in turn means harder maintainability and more time spent which in turn means you earn less money.
  4. The carbon footprint you save for the whole world thru 1% performance gain is easily dwarfed by greenhouse gases your team will have to emit on debugging and maintaining that code.
The negatives of bad optimization in particular are:
  1. It doesn't often given you the performance you expect. See this question on SO, where optimizations have gone wrong. In fact it can have adverse effects. That's the problem with undocumented behaviour.
  2. Mostly modern compilers will do it for you anyway.
I'll give some examples of bad and good optimization:
The bad -
  1. use of smaller integer types instead of Int32.
  2. ++i used instead of i++
  3. for instead of foreach (the worst I have seen, totally defeats logic)
  4. avoiding closed out variables
    string p;
    foreach (var item in collection)
        p = ...;
  5. using char instead of string during string concatenation, like:
    string me = 'i' + "me myself"; // something along that line - causes boxing
The good (from .NET world. Should be self-explanatory) -
  1. Double lookup
    if (Dictionary<K, V>.TryGetValue(K, out V))
        do something with V
    instead of
    if (Dictionary<K, V>.ContainsKey(K))
        do something with Dictionary<K, V>[K]
  2. Load 'em all
    DirectoryInfo.EnumerateFiles();
    instead of
    DirectoryInfo.GetFiles();
  3. Two stage casting:
    s = o as string;
    if (s != null)
        proceed
    instead of
    if (o is string)
        s = (string)o;
  4. If the order doesn't matter
    instead of
    if (expensiveFunction() || counter < X)
  5. Boxing
    void M<T>(T o) //avoids boxing
    instead of
    void M(object o)
If you ask me if these give a noticeable performance benefits, I would say no. But I would suggest one should use them because it stems from an understanding of the behaviour of these constructs. Why make two calls when you can do just 1? From a philosophical standpoint its good coding practice. And 1 & 3 are slightly less readable too in strict terms, but do they trump readability? No, not much, so I use. Now that's the key - maintaining a decent performance to readability ratio. And when it's that, its about where you draw the line.
nawfal
  • 148
"Worth it" needs context, like how much simpler it is to write and read and maintain vs. how much faster it makes something to the user markedly more responsive, interactive, requiring less time for them to wait.
Saving a few pennies to purchase a can of soda won't do me much good if I have to travel a distance to save those pennies, especially given that I rarely ever drink soda these days. Saving a few pennies per can on a purchase of a million can of sodas could be a huge deal.
Meanwhile saving a few pennies when two people are right next to me and one offers the exact same thing for a few pennies cheaper and the other doesn't, and I choose the more expensive one because I like their hat better seems like a foolish case of pessimization.
What I often find people calling "micro-optimizations" seem to be curiously devoid of measurements, and context, and user-end discussion, when there should absolutely be all three to consider such optimizations if they aren't trivial to apply. To me a proper micro-optimization these days relate to things like memory layouts and access patterns, and while they might seem "micro" in focus, they are not micro in effect.
I managed to, not so long ago, reduce an operation down from 24 secs to 25 milliseconds (about 960 times faster), with identical outputs (secured by automated tests), with no change to algorithmic complexity, for volumetric heat diffusion skinning, through "micro-optimizations" (the biggest of which came from a change in memory layout which got it down to about 2 seconds, then the rest were things like SIMD and further analysis of cache misses in VTune and some further rearrangement of memory layout).
Wolfire explains the technique here, and he struggled with the time required: http://blog.wolfire.com/2009/11/volumetric-heat-diffusion-skinning/
My implementation managed to be able to do that in milliseconds while he was struggling to get it down to less than a minute: enter image description here
After I "micro-optimized" it down from 24 secs to 25ms, that was a game-changer in workflow. Now artists can change their rigs in realtime at over 30 FPS without waiting 24 secs every time they made any little change to their rig. And that actually changed the whole design of my software since I no longer needed progress bar and things of this sort, it just all became interactive. So that might be a "micro-optimization" in the sense that all of the improvements came without any improvement to algorithmic complexity, but it was a rather "mega-optimization" in effect that made what was formerly a painful, non-interactive process into a realtime, interactive one which completely changed the way users worked.
Measurement, User-End Requirements, Context
I really liked Robert's comment here and maybe I failed to make the point I wanted:
Well, c'mon. Nobody is going to argue that this kind of change isn't "worth it." You were able to demonstrate a tangible benefit; many so-called micro-optimizations cannot.
This is, in spite of working in a very performance-critical field with often real-time requirements, the only time I consider any micro-optimization which requires going out of my way.
And I'd emphasize not only measurements but the user-end side of it. I'm an oddball in that I came to my current field (and formerly gamedev) as a user/fan first, developer second. So I was never that excited by the usual things that excite programmers like solving technical puzzles; I found them a burden, but would bear through them through the user-end dream I shared with other users. But that helped me to make sure if I was optimizing anything, it'd have a real impact on the users with real benefits. It's my safeguard against micro-optimizing aimlessly.
That is actually as important as the profiler in my opinion, because I had colleagues who did things like micro-optimize subdivision of a cube into a billion facets only to choke on real-world production models like characters and vehicles. Their result was impressive in some "tech demo" sense, but almost useless to actual users, because they were profiling and measuring and benchmarking cases that didn't align with real-world use cases. So it's so important to understand what's important to users first, either by learning to think and use the software like one or collaborating with them (ideally both, but at least collaborate to them). The most important thing to me if we want to get micro and start shaving cycles and cache misses and so forth is to start becoming really good at prioritizing where we go out of way to do that (which naturally corresponds with knowing all the places we shouldn't do that, for which both profiler and user-end understanding are very important).
    Well, c'mon. Nobody is going to argue that this kind of change isn't "worth it." You were able to demonstrate a tangible benefit; many so-called micro-optimizations cannot. – Robert Harvey Dec 21 '18 at 03:01
    @RobertHarvey It was kind of the point I was hoping to make, since what some people call "micro-optimization" isn't necessarily microscopic in effect, but it's so dependent on context, measurements, etc. `isset` vs. `strlen` seems more miniscule in focus absent the context and measurements. :-D –  Dec 21 '18 at 03:03
    @RobertHarvey I was hoping to say, maybe albeit indirectly, that if there's a negative context to "micro-optimizations", it's the type that tends to be devoid of those measurements, contexts, and user-end needs. I could go on about the last case too since I had a colleague who optimized the hell out of something which was cool, except no one used it. I even think proper optimization requires some user-end understanding, otherwise we could be profiling and tuning things that users don't care about. –  Dec 21 '18 at 03:12
    Some optimizations are driven by pressing need, while others are driven by curiosity (intellectual pursuit and adventurism). We need both. In Dragon Energy's story, it was probably not a "pressing need", since artists apparently did not complain loudly about not seeing any rendering results until 24 seconds after each edit. In fact, users might not know how fast it could have been, until a programmer invested in all the effort to beat the speed record. Limiting ourselves to driven demand makes business sense, but doing so will miss some amazing optimization opportunities or game-changers. – rwong Dec 21 '18 at 03:33
    Speaking of business sense, there is also the issue of monetization. Every move (e.g. a programmer working on performance optimization) costs money, and the cost need to be recouped in order to make business sense. Thus, one has to ask whether the game-changing speed improvement can be "sold", or how much money would be "saved", if the programmer must obtain approval from a business manager. – rwong Dec 21 '18 at 03:36
  • @rwong That's an excellent point I'm prone to overlook. My specialty and focus was always rather skewed towards R&D with some breathing room (I developed a track record starting from uni), so I wasn't always exposed to the more practical side of running a business (was "sheltered" a bit for a good while). It's something I've come to slowly appreciate a bit more over the years. My industry is very, very heavily revolving around R&D and kind of seeking those "game-changers" repeatedly, and I've always found a bit of freedom to pursue them without having to present the business benefits. –  Dec 21 '18 at 03:40
I think that there is a big difference between good programing and micro-optimization.
If there are two ways to do the same task, one being faster than the other and both having the same readability, you should use the faster. Always. And this is good programing. There's no reason to not use a better algorithm to solve a problem. And even documenting it is easy: give the algorithm name, everybody will be able to google it and find more information about how it works.
And good algorithms are already optimized. They will be fast. They will be small. They will use the minimum required memory.
Even if using them your program still don't have that performance, them you can consider micro-optimizing it. And you'll have to really know the language to be able to micro-optimize.
And there's always room for spending some more money on hardware. Hardware is cheap, programmers are expensive. Don't spend too much time / money by optimizing when you can just buy hardware.
woliveirajr
  • 223
I'll put it this way - micro-optimisation is a process of optimising something that is not a bottleneck at all. For example, if your program calls two functions A and B, and A takes 100 milliseconds to complete and B takes 2 microseconds, and you keep optimising function B. That is not only not important, that is absolutely wrong. But optimising function B is called optimisation and not micro-optimisation. Importance of optimisation depends. Say you have nothing else to do and your program is bug-free, then yes, it is important. But generally you have priorities. Let's say you need to add/write function C. If you think that writing function C will make you more money than making your program faster without that functionality, then go for optimisation. Otherwise pursue functionality. Also, experienced programmers focused on performance don't spend much time optimising, they just write fast programs. Of at least they know what tools to use and what to do not to spend years doing meaningless (read micro) optimisations.
  • this post is rather hard to read (wall of text). Would you mind [edit]ing it into a better shape? – gnat May 22 '13 at 18:07
There's micro-optimisations and micro-optimisations. In VB (both VB6 and VB.NET, but ignoring the IsNullOrEmpty offering from the framework) I always use Len(str) <> 0 rather than str <> "". However, I normally don't "fix" others code where they've used the latter.
Yes, the latter is more readable, but, in this case, the former is not unreadable.
Performance should be a consideration when designing the code, but not at the detrement of readability and maintainability.
Mark Hurd
  • 343
I started programming nearly 31 years ago, where memory and CPU are scarce. Maybe this is why I agree with your father.
I do believe a good coder needs to worry about optimisation in every line of code. But I would add to this sentence: as much as it worths and always trying to favor readability over optimisation in places where computations are not critical.
For example, in another thread, a guy asked about the code below, which solution he would choose: CPU or Memory.
public class Main {
    public static int totalRevenue;
    public static int totalProfit;
    public static int option1(int numSold, int price, int cost) {
        // Option 1 (memory)
        totalRevenue += numSold * price;
        totalProfit += numSold * price - numSold * cost;
        return numSold * price;
    public static int option2(int numSold, int price, int cost) {
        // Option 2 (time)
        int saleRevenue = numSold * price;
        totalRevenue += saleRevenue;
        totalProfit += saleRevenue - numSold * cost;
        return saleRevenue;
This code generates the following bytecode:
public class Main {
  public Main();
    Code:
       0: aload_0
       1: invokespecial #1                  // Method java/lang/Object."<init>":()V
       4: return
  public static int option1(int, int, int);
    Code:
       0: getstatic     #2                  // Field totalRevenue:I
       3: iload_0
       4: iload_1
       5: imul
       6: iadd
       7: putstatic     #2                  // Field totalRevenue:I
      10: getstatic     #3                  // Field totalProfit:I
      13: iload_0
      14: iload_1
      15: imul
      16: iload_0
      17: iload_2
      18: imul
      19: isub
      20: iadd
      21: putstatic     #3                  // Field totalProfit:I
      24: iload_0
      25: iload_1
      26: imul
      27: ireturn
  public static int option2(int, int, int);
    Code:
       0: iload_0
       1: iload_1
       2: imul
       3: istore_3
       4: getstatic     #2                  // Field totalRevenue:I
       7: iload_3
       8: iadd
       9: putstatic     #2                  // Field totalRevenue:I
      12: getstatic     #3                  // Field totalProfit:I
      15: iload_3
      16: iload_0
      17: iload_2
      18: imul
      19: isub
      20: iadd
      24: iload_3
      25: ireturn
For the sake of understandability, 'iload_' load data from stack and 'istore_' save data into stack.
It's easy to notice that you really saved one memory allocation in one solution spending more CPU cycles. That kind of question may arise even for experienced programmers.
But there is a catch in this example: stack memory is pre-allocated in blocks, not at byte level. Each time a thread runs, it will allocate a certain amount of memory to use in stack operations. So unless you are lucky enough to have these 4 bytes overflow your stack (and requiring you to setup a larger stack size), you will be ending up spending the same memory amount to run both examples. But in the second one, you are spending more cycles doing math calculations and your code is much less readable.
I brought it here to give a sample that discussing about optimisations in small portions of code is not evil. Some guy closed that question pointing to this thread. But this thread don't answer that specific question. It only discuss about "don't worry about optimisation". And due to this stupid mantra, people feel that is right not go to deep understanding.
There is a reasonable answer to that question, and maybe one can even give a better answer about the internals. Once learned, a good programmer will be able to repeat that pattern instinctively, and will become a better programmer. Programmers must have critical thinking about their code and must try to understand, as much as possible, how machine will process it.
I'm not advocating here that we all need to optimize little things. Remember that I recommended to favor readability over micro-optimisations.
I just believe that repeating the mantra "don't worry about optimisation" don't make things better. It only make programers lazy. Programmers must be instigated to know how things work behind the scenes. This way people can pursue to write better code, and wisely choose when not to optimise.
