124
I am developing the UI for a .NET MVC application that will require international localization of all content in the near future. I am very familiar with .NET in general but have never had a project that required such a significant focus on international accessibility.
The projected is initially being done in English. What measures should I take at this point to make it easier to implement localization in the future?
smartcaveman
  • 1,522
    Great question! I'm facing a similar situation and would love to see the experts weigh in on this. –  Mar 09 '11 at 23:36
  • Anyone got any good standards for resource management? The localised value might include images, too, and not just strings. –  Mar 10 '11 at 12:19
    Is this a WPF/silverlight UI, or Winforms? From my (limited) experience the WinForms experience for localisation is much simpler than WPF/Silverlight. – Pete Stensønes Apr 01 '11 at 20:42
    If you end up storing your localized strings in the database, instead of resource files, you may want to take a look at this discussion: http://stackoverflow.com/questions/2458615/how-do-you-localize-internationalize-an-mvc-controller-when-using-a-sql-based-loc –  Apr 15 '11 at 18:10
    @Pete, @smartcaveman said he's "developing the UI for a .NET MVC application", so... – brunosp86 Apr 28 '11 at 17:54
  • This can be somewhat helpful: https://www.edx.org/course/developing-international-software-microsoft-dis50-1x – Pavel Voronin Nov 03 '15 at 10:42
12 Answers12
74
Some basic things you should take into account:
Externalize all string resources
All your resources should be contained in external files that can be handed off for localization. Don't forget about error messages, if you want these localized too.
Allow sufficient space for string expansion
Strings in some languages tend to be up to 30% longer (like Greek) for example, so ensure that you design your UI in such a way so that strings can expand if necessary. Here's a rather extreme example for French:
Ok -> Accepter (French - 400% expansion)
I'd recommend doing some kind of pseudo translation as a starting point (http://en.wikipedia.org/wiki/Pseudolocalization). Or you could translate your resources via Google Translate or Bing. This will give you a good indication of what actual translations will look like.
Watch out for text in images
If you use any images in your application - ensure they don't contain any text - this obviously cannot be translated.
Never hardcode any paths to Windows folders
Obvious, but I've seen it in the past. For example, C:\Program Files is translated on some international versions of Windows, e.g. it's C:\Programme on a German OS.
Avoid using locale specific terms
For example, if you ask someone for their 'High School' on a form, this has little meaning in western Europe.
Avoid creating strings via string concatenation
For example, this looks harmless:
strWelcome = ReadExternalString("Welcome");
strMessage = strWelcome + ", " + UserName;
But, the word order on Japanese for example would be different, so this may end up not making any sense.
Time / Date Settings
Always ensure to get the time / date format form the OS.
Jimmy Collins
  • 1,328
  • @Jimmy C, how do you go about building strings for language-independent logical consistency? – smartcaveman Mar 10 '11 at 18:33
    @Smart do something in your resource like "{0}, {1}" then when you localize it, use string.format and pass in the greeting and username. Plus this gives you the benefit of having "Current {0} speed is {1} {2}" and you can pass in "Engine", "50" and "MPH", and when you translate your sentence, you can move {0} etc around to where they make sense in that language – taylonr Mar 10 '11 at 18:45
    Good list JimmyC. "Never hardcode any paths to Windows folders" reminded me of "Always use Path.Combine" instead of string concatenation for windows paths. –  Apr 02 '11 at 06:49
  • @Jimmy-C Great answer! –  Apr 02 '11 at 15:52
  • @Jimmy C : Good answer, maybe you could expand on it to include some talk about right to left languages (hebru, Arabic) –  Apr 10 '11 at 14:27
  • Great answer! As a translator, I have a few extra suggestions: Use a simple format for string resources. XML, JSON are easy to prepare for translation. Pictures with text can not always be avoided (website banners). In that case, add a language code to the resource and a bit of code to grab the translated picture if it exists. String concatenation can be replaced by string formating ("Welcome, {0}!", userName), allowing the translator to move the name at it's proper place. – Sylverdrag Apr 10 '11 at 15:04
    Environment.GetFolderPath can be used to get valid paths to common paths such as My Documents without depending upon the English name for those folders. – Crippledsmurf Jun 29 '11 at 14:11
  • @caveman @taylonr: `String.Format` is a great recommendation, but when it comes to plural forms, check out open-source `Smart.Format` ... it extends `String.Format` with localizable plural formatting and more. It's easily extensible too. [SmartFormat](http://github.com/scottrippey/SmartFormat/wiki) – Scott Rippey Aug 09 '11 at 23:35
74
You are developing ASP.Net MVC application, are you? Other answers seem to be specific to desktop applications. Let me capture common things:
Locale detection
It is quite important that your application detect user's locale correctly. In desktop application, CultureInfo.CurrentCulture holds preferred formatting locale (the one that should be used to format numbers, dates, currencies, etc.) whereas CultureInfo.CurrentUICulture holds preferred User Interface locale (the one that should be used to display localized messages). For web applications, you should set both cultures to auto (to automatically detect locale from AcceptLanguage header) unless you want to implement some fancy locale detection workflow (i.e. want to support changing language on demand).
Externalize strings
All strings should come from resources, that is Resx files. In Winforms App it is easily achievable by setting form Localizable property to true. You would also need to manually (unfortunately) externalize strings that come from your models. It is also relatively simple. In Asp.Net you would need to externalize everything manually...
Layouts
You definitely need to allow for string expansion. In Winforms world it is achievable via TableLayoutPanel which should be used to make sure that layout will adjust automatically to accommodate longer text. In web world, you are a bit out of luck. You might need to implement CSS Localization Mechanism - a way to modify (override) CSS definitions. This would allow Localization folks to modify style issues on demand. Make sure that each HTML element in rendered page has unique id - it will allow to target it precisely.
Culture specific issues
Avoid using graphics, colors and sounds that might be specific for western culture. If you really need it, please provide means of Localization. Avoid direction-sensitive graphics (as this would be a problem when you try to localize to say Arabic or Hebrew). Also, do not assume that whole world is using the same numbers (i.e. not true for Arabic).
ToString() and Parse()
Be sure to always pass CultureInfo when calling ToString() unless it is not supported. That way you are commenting your intents. For example: if you are using some number internally and for some reason need to convert it to string use:
int i = 42;
var s = i.ToString(CultureInfo.InvariantCulture);
For numbers that are going to be displayed to user use:
var s = i.ToString(CultureInfo.CurrentCulture); // formatting culture used
The same applies to Parse(), TryParse() and even ParseExact() - some nasty bugs could be introduced without proper use of CultureInfo. That is because some poor soul in Microsoft, full of good intentions decided that it is a good idea to treat CultureInfo.CurrentCulture as default one (it would be used if you don't pass anything) - after all when somebody is using ToString() he/she want to display it to user, right? Turn out it is not always the case - for example try to store your application version number in database and then convert it to instance of Version class. Good luck.
Dates and time zones
Be sure to always store and instantiate DateTime in UTC (use DateTime.UtcNow instead DateTime.Now). Convert it to local time in local format upon displaying:
DateTime now = DateTime.UtcNow;
var s = now.ToLocalTime().ToString(CultureInfo.CurrentCulture);
If you need to send emails with time reference in body, be sure to include time zone information - include both UTC offset and list of cities:
DateTime someDate; // i.e. from database
var formattedDate = String.Format("{0} {1}",
             someDate.ToLocaleTime().ToString(CultureInfo.CurrentCulture),
             TimeZoneInfo.Local.DisplayName);
Compound messages
You already have been warned not to concatenate strings. Instead you would probably use String.Format() as shown above. However, I must state that you should minimize use of compound messages. That is just because target grammar rules are quite commonly different, so translators might need not only to re-order the sentence (this would be resolved by using placeholders and String.Format()), but translate the whole sentence in different way based on what will be substituted. Let me give you some examples:
// Multiple plural forms
English: 4 viruses found.
Polish: Znaleziono 4 wirusy. **OR** Znaleziono 5 wirusów.
// Conjugation
English: Program encountered incorrect character | Application encountered incorrect character.
Polish: Program napotkał nieznaną literę | Aplikacja napotkała nieznaną literę.
Other concatenation issues
Concatenation is not restricted to strings. Avoid laying out controls together, say:
Remind me again in [text box with number] days.
This should be re-designed to something like: Remind me again in this number of days: [text box].
Character encoding and fonts
Always save, transfer, whatever text in Unicode (i.e. in UTF-8). Do not hard-code fonts - Localization might need to modify them and it will turn off default font fall-back mechanism (in case of Winforms). Remember to allow "strange" characters in most fields (i.e. user name).
Test
You will probably need to implement so called pseudo translation, that is create resources for say German culture and copy your English strings adding prefix and suffix. You may also wrap placeholders to easily detect compound strings. The purpose of pseudo translation is to detect Localizability issues like hard-coded strings, layout issues and excessive use of compound messages.
Paweł Dyda
  • 1,518
    Regarding **Compound Messages** - I had to do multiple-plural forms once. I extended `String.Format` so that it could support this cool syntax: `"There {0:was|were} {0} {0:virus|viruses} found."` Each language can load its own rules, so you could do `"Znaleziono {0} {0:wirusy|wirusów}."` The source is on GitHub: http://github.com/scottrippey/SmartFormat/wiki – Scott Rippey Aug 09 '11 at 23:13
    @Scott Rippey Have you noticed that the Polish example reads "Znaleziono 4 wirusy. **OR** Znaleziono 5 wirusów." <- Polish, like many other languages, has more than two plural forms and the rules to distinguish between them can be complex as well. Here I must leave Polish since I do not speak it, but in my language, the plural form for 101 things is the same as that for 1 thing. You might take a look at how GNU gettext tackles this problem: http://www.gnu.org/s/hello/manual/gettext/Plural-forms.html – gregopet Aug 10 '11 at 05:32
    @gregopet My Polish example was contrived, because I don't speak it, but that's exactly what the SmartFormat project does. Here's a better example: `"{0} {0:plik|pliki|plików}"`. The formatter has a Polish rule that determines which of the 3 forms to use, and correctly determines the special cases. I'm currently working on adding more rules, so the `gettext` article will prove very useful, thank you. – Scott Rippey Aug 15 '11 at 22:42
  • For pseudo-localization, I built a free online pseudolocalization tool at http://www.pseudolocalize.com – JerSchneid May 25 '14 at 03:38
24
Special Considerations for Asian Languages
In addition to all the great answers already here, some watch-out's for Asian languages:
Beware of different lengths of text
Chinese and Korean text tends to be much shorter than the equivalent English text (since you usually need fewer blocky characters to write the same thing), so a page may actually look empty in Chinese but jammed full in German... You need to do some dynamic sizing here to look good.
However, Japanese text usually tends to be much longer, even longer than the equivalent English text in terms of character count.
Beware of baseline layout and the "slided up" look
Asian characters are usually laid out on the baseline, which do not include descenders (i.e. the lower part of y, g, q, j etc.) When you format a screen element -- usually buttons -- with text inside, and if that text is only Asian languages (i.e. no Western alphabets), then the text will look like it is shifted upwards.
Formatting of numbers and localized numeric units
Handle number formatting differently. Different Asian countries have different ways of formatting numbers. Same with currencies. For example, in East Asia, 10,000 (wan) is a common unit. In India, 100,000 (lakhs) is common.
Local currencies
Some countries' currencies have a lot of zeros and no decimal point (e.g. Japan, Indonesia, Italy), while others have up to two digits after the decimal point.
Beware of different word orders
Word order may not always be the same. Best to do use {0}, {1} etc. in string formatting instead of hard-coding word order if your string comes from a combination of different pieces of data.
Use locale-specific sort
Sorting is different per language and per locale -- you should always rely on the O/S's locale-specific sort.
Be very cautious with full-width/half-width characters
Beware of the differences between "full-width" and "half-width" characters. Brackets, punctuation etc. can have "full-width" versions that are different from standard ASCII. If you do searching or string splitting based on these letters, you'll need to first convert all full-width symbols to half-width equivalents.
A period is not a dot... a comma is not a comma...
Beware of data input gotcha's -- for example, in Chinese, a period is not a dot ".". A comma is full-width, not ",". Don't try to search for western punctuation if the user doing the data-entry may accidentally turn on Asian language IME.
Phone numbers
Don't assume anything in phone number formatting. There is not always an area code etc. and it can be formatted differently. Usually, have a format string per country.
Don't assume people will only have one mobile phone number, or one fax number etc. It is not this way in Asia.
Addresses -- denser than you may think
For addresses, don't assume anything. There may not always be a zip code. Zip codes may not always be numbers. A country may not have provinces/states. A country may be just a big city (e.g. Singapore). For certain Asian countries, the smallest unit of a home may be "Room X, Unit Y, Section Z, Floor A, Block B, Group C, Estate D". In general, be very liberal in number of fields and number of characters allowed in addresses.
Salutations
Salutations are not only restricted to Mr., Mrs. etc. Although you're probably safe in using "M" and "F" for sex -- we are not that wierd yet...
    The last paragraph made me smile. – BoltClock Apr 07 '11 at 07:13
  • Oh, we (i18n guys) didn't even started yet... We were only able to scratch the surface :) If we were to talk specific issues like GB18030 support, our post would be too long for SO to handle :) Thanks for your note anyway, I missed quite a few items. – Paweł Dyda Apr 08 '11 at 13:00
  • About the last, I believe the UK now officially accepts "Other" as a sex. Think transgenders. – Bart Friederichs Oct 29 '12 at 13:31
Some basic steps are to make sure any string that is displayed on the screen is not a literal in your code. If you're doing Winforms each form will have a UI resource. For dialogs, reports etc, make sure you use the project resource files.
So instead of "Upload failed" in your code, you might have something like Resources.UploadFailed
This way you can create a new resource file for each language you use (and .Net will help with this.) And have the localized string in each file.
EDIT I forgot to mention when you're doing your UI, make sure you don't just cram things in there. Depending on the languages you are localizing to, real estate could be a problem. I worked on a project that had German and Portuguese as the 2 biggest offenders for string growth. If we weren't careful strings that were fine in English, French and Italian would blow up in German.
taylonr
  • 354
    From my L10n experience, Russian is the worst case scenario. Howeverm in Winforms with proper user of TableLayoutPanels one can handle string growth gracefully. – Paweł Dyda Apr 08 '11 at 13:03
  • Yeah, my experience was limited to 7 languages: English, German, Portuguese, Italian, French, Spanish, and Japanese. But I can see Russian being bad as they tend to have a lot of suffixes and prefixes – taylonr Apr 08 '11 at 13:12
I suggest you run FXCop or Visual Studio Code Analysis (they're quite the same) on your assemblies.
They are good at detecting .NET code that does not use the proper culture oriented overloads, like this one: CA1305: Specify IFormatProvider.
I must add that these tools are also frustrating because they usually detect zillions of issues in your code, but still, even if you don't follow each rule, you should learn a lot.
In addition to the specific how to load resources I'd make sure that you test with a pseudo-localized version to begin with. Otherwise you're not likely to notice the places where internationalization considerations were omitted until the end.
Jeremy
  • 361
In addition to all the other helpful hints, here are some that are missing:
Take into account that some countries use more than one language. For example, in Canada, a user would expect to be able to easily switch between English and French.
If you ask the user a question that expects a single letter answer, don't expect the user to press the 'Y' key to say Yes.
Be very aware in Stored procs that dates in the SQL DB are in USA format
Placing text strings in the DB allows you to later add additional languages without redeploying.
When sending written text files for translation, always include a description of context to ensure the translator selects the correct word. Eg without context, you could translate "pitch:" into something to do with sound or a place on which you play soccer
Address labels always need converting. Province in Canada, State in America, County in the UK
You need to consider:
  1. Routing for multilanguage
  2. Move all hardcode string to resource file
An example for a property:
Model:
[Display(Name = <Resource for display name>.<field for this property>)]
[Required(ErrorMessage = <Resource for error message>.<field for this validate message>)]
public string TestProperty { get; set; }
View:
@Html.LabelFor(m=>m.TestProperty)
@Html.EditorFor(m => m.TestProperty)
@Html.ValidationMessageFor(m => m.TestProperty)
Here's something not mentioned in the rest of the answers.
Depending on the complexity of your application and its localization, I would highly advise implementing an alternative resource provider and keeping localized resources in a database. With the default ASP.NET localization scheme all resources are kept in RESX files, which:
  1. Are a pain in the butt to edit in Visual Studio
  2. Limit the distribution and management of localized resources after the application is compiled/shipped/run.
As a possible use case, consider providing language packs for your application and the ability to import and export languages through the UI. RESX files wouldn't help here.
In scenarios like this an alternative resource provider is very helpful. More info on how to implement one can be found here. Of course this is a rare case more commonly seen in enterprise applications, but still valid.
Slavo
  • 151
    Thank you for taking the time to look over these great answers answers and still contributing something new and helpful. – smartcaveman Jul 06 '11 at 17:27
  • +1; I've built an extensive web application in Asp.NET and we ended up doing translations via the database. New features were often added but as our translators weren't experts in the particular terminology used we were able to quickly address angry customer emails of the sort "Why are you using word Y for X which is plainly wrong?". – gregopet Aug 10 '11 at 05:42
The most important thing is managing the content in various languages. I have developed couple of websistes myself and managing the content in various language is the biggest challenge.
I am using Database to store the resources/content. It gives me the flexibility of adding any language support I want. I have implemented the logic of falling back to the english language if a resource in particular language is not found.
You can later use a translator to convert the english value into any language.
Summary of things to consider in internationalization:
  • All information should be internationalized. Take into consideration that the graphics may have information that we want to internationalize.
  • The size of the fields or strings, depending on the language because it can cause us a problem.
  • The order of words depends on the language we are, so an order in one language will be the same in another.
  • We must take into account that the date format will change from one language to another
Do the Turkey test:
Software internationalization is difficult under the best of circumstances, but it always amazed me how often one particular country came up in discussions of internationalization problems: Turkey...
If you care a whit about localization or internationalization, force your code to run under the Turkish locale as soon as reasonably possible. It's a strong bellwether for your code running in most – but by no means all – cultures and locales...
If your site/program runs well with a Turkish client you can be sure that it will run on most other platforms.
gnat
  • 21,442
  • 112
  • 288
Carra
  • 4,261
