This is part of a series of questions which focuses on a project called the Abstraction Project, which aims to abstract the concepts used in language design in the form of a framework.
Another page associated to it related to structural typing can be viewed here. The meta-topic associated to an inquiry about the framework and the proper place to post can be found here.
How easy should it be to use a Language Development Framework?
I've written large scale code generation frameworks which also included the ability to send the result to the language-specific compiler. The topic of ease of use comes up from one such framework example: CodeDOM, or the Code Document Object Model.
It is a framework written by Microsoft that describes common code structures, but generally left a lot out (expression coercions) and tended to be a bit abstract in its representation of certain constructs, to downright emitting bad code based upon what you were doing: earlier CodeDOM poorly handled emitting PrivateImplementationType on CodeMemberMethod, when the type used was a generic interface. CodeDOM was my original reason for writing my first code generator.
One thing I'm trying to do, to simplify the framework, is reduce the amount of work you need to do something, and focusing on actions versus the specific types that make up those actions.
Here's a side by side comparison of how the framework I'm writing works:
//Truncated...
 * From a project that generates a lexer, this is the
 * state->state transition character range selection logic.
var nextChar = nextMethod.Parameters.Add(new TypedName("currentChar", typeof(char).GetTypeReference()));
char start = rangeElement.B.Value.Start;
char end = rangeElement.B.Value.End;
 * 'start' <= nextChar && nextChar <= 'end'
currentExpression = start.LessThanOrEqualTo(nextChar).LogicalAnd(nextChar.LessThanOrEqualTo(end));
Versus CodeDOM:
//Truncated...
var nextChar = new CodeVariableReferenceExpression("nextChar");
var start = new CodePrimitiveExpression(rangeElement.B.Value.Start);
var end = new CodePrimitiveExpression(rangeElement.B.Value.End);
currentExpression = new CodeBinaryOperatorExpression(new CodeBinaryOperatorExpression(start, CodeBinaryOperatorType.LessThanOrEqual, nextChar), CodeBinaryOperatorType.BooleanAnd, new CodeBinaryOperatorExpression(nextChar, CodeBinaryOperatorType.LessThanOrEqual, end));
The focus of the framework is language enthusiasts, as well as those interested in generating code or applications. Given its focus on compilation, code generation, and language development, should the framework focus on ease of use or raw power?
My primary goal is to increase the availability of such tools, so those interested in the domain don't require a lot of experience in the language theory domain before they can start to work on their own language-centric projects.
Given that I'm the author of the framework, my view of "usability" is biased. Thus, I must ask another if the focus and goal make sense to others who aren't associated to the project.
    You should ask this question on http://codereview.stackexchange.com. – Robert Harvey Jul 29 '11 at 20:31
    The question, whether a framework should be easy to use at the expense of raw power, doesn't look to be at all a fit for Code Review.SE, where "Higher-level architecture and design of software systems" is [not on-topic](http://codereview.stackexchange.com) there, and is on-topic here. Code Review is for when you have working code and you want a critique. –  Jul 29 '11 at 21:32
  • The input to a code generator is just another programming language. The desire for code generation means that the language you are generating is insufficiently powerful. Better languages have built-in code generators. – kevin cline Jul 30 '11 at 16:40
  • @kevincline The typical use case for a code generator is a domain specific language which utilizes a general-purpose code generation framework. This is not really much of a choice, the alternative would be to compile to your own internal intermediate language and interpret it through a VM, or to translate it yourself into a lower level construct, but in the end you're doing the same thing. That's what this framework aims to do, when you need to do the work to generate code dynamically, you'd use this versus winging your own implementation of the same thing. – Allen Clark Copeland Jr Jul 30 '11 at 19:11
  • It's not so much that the source language is insufficient, it's that a language grammar is just text until an intermediary software is written to translate from the source text to the target platform. In this case it's the Common Language Infrastructure (CLI), or code in general-purpose languages that target the CLI. The framework aims to handle the grunt work of taking high level representations and translating them into sufficiently low-level constructs for IL generation. i.e. A compiler, just because you need a compiler doesn't mean your language is insufficiently powerful. It's required. – Allen Clark Copeland Jr Jul 30 '11 at 19:15
  • hmm, have you seen Eclipse Xtext? It is quite productive and as simple as these things can get imho. – Gabriel Ščerbák Jul 31 '11 at 10:21
  • @Gabriel Ščerbák Xtext seems simple from a glance, there's quite a lot it can do to get you started; however, some starter projects take a lot of things and assume they will be a certain way. I'm referring to the functional level of 'in the code' aspect of the framework, not the IDE aspect, as I'm no where near that level of completion. – Allen Clark Copeland Jr Jul 31 '11 at 14:18
  • @Alexander Morou I am not sure I understand what you mean. Xtext isn't just for building IDEs, it uses ANTLR to generate lexers and parsers, uses EMF for code generation and as AST representation and provides various language related APIs. There is for example also a type system framework from Markus Völter. – Gabriel Ščerbák Jul 31 '11 at 14:41
  • @Gabriel Ščerbák: Well, I think you misunderstood me. I'm not referring to building Integrated Development Environments. I'm referring to writing a language at the code level, after you have the parser phase finished. So Xtext basically uses ANother Tool for Language Recognition (ANTLR) for the parser phase, but what does it use to handle static type analysis, target platform code generation (i.e. CIL in the case of .NET,) and so on? When I said I'm not that far, I mean I don't have tools built to handle things visually. – Allen Clark Copeland Jr Aug 01 '11 at 12:47
  • @Alexander Morou As I said, Xtext is built on top of EMF (Eclipse Modeling Framework) and provides APIs to (manipulate and) validate the model - which is basically a static code analysis. As it is a tool more oriented to modeling than programming langauges, the code generation is about text (Java source code) templates and transformations to other models (e.g. an expression language with semantics defined through templates) or you can write an interpreter. The visual (IDE) aspects are handled by the Eclipse platform. – Gabriel Ščerbák Aug 01 '11 at 22:00
  • @Gabriel Ščerbák: Right, but the focus of what I'm trying to say is: from what I can tell, the Xtext framework for developing a language covers multiple fronts (visually, through code, and so on). For the sake of the discussion as it is, I'm focusing on the synthesis of a document model that describes code (**not** CodeDOM,) and the analysis that is involved with verifying the expressions/statements, rewrites associated to higher-level concepts into more general-purpose code. – Allen Clark Copeland Jr Aug 06 '11 at 01:54
  • @Gabriel Ščerbák: All of this operates on a conceptual level, ideally never entering text as it focuses on direct compilation. I plan on using Reflection.Emit as the primary compiler functionality. There are cyclic object model issues I have to overcome (such as a [creation order issues](http://blogs.msdn.com/b/lucian/archive/2009/11/29/the-limitations-of-reflection-emit.aspx).) I have answers for them from a static compiler standpoint, but I have to come up with answers that help from a Read Eval Print Loop (REPL) viewpoint. – Allen Clark Copeland Jr Aug 06 '11 at 02:04
Its tough to build a language-development framework. You have to decide what kinds of things you'd like it to support, then you have to decide which of those you sort of know how to do, and how to integrate those together into a coherent whole. Finally, you have make enough investment so it works with real languages (e.g., typical computer languages as well as DSLs), and actually does something useful. My hat is off to you for trying.
You might compare you effort with the one I started 15 years ago, the DMS Software Reengineering Toolkit. DMS is intended to provide general purpose parsing, analysis, and transformation of code. Given an explicit langauge specification, it will parse code, build ASTs, regenerate code from ASTs (prettyprint), transform code using patterns written in the targeted programming language, build symbol tables, compute control and data flow, etc. By adding custom code, one make DMS carry off a wide variety of effects. (See the tools at the site; they're all DMS in one form or another).
Here's a technical paper on DMS as is was several years ago. (We keep improving it)
While DMS itself has been hard to build, we found that it took a correspondingly large chunk of engineering to define real langauges to DMS, including IBM COBOL, C# 4.0, Java 1.7, C++11 (and many others).
What we think it does (reasonably well): lower the cost of building tools by 1-2 orders of magnitude. What this means is that tasks that might otherwise take 1-10 years can be contemplated by mere mortals as 1 month-1 year projects. What still isn't easy:
  • Defining new langauges
  • Handling all the idiocies of current languages
  • Making it easy to write the custom code specific to your task
  • Defining new, complex analyses
  • Handling partial programs, or programs containing errors
  • (To your initial point) Make it easy for nonexperts to use these tools
So, there's lots of room for improvement. Let many flowers bloom.
Ira Baxter
  • 1,910
This question may have been answered in The Mythical Man Month, the "Conceptual Integrity" section. If not, it is at least highly relevant to your question. Even though Brooks describes architecting a whole computing system, the essay applies perfectly well to frameworks and new languages.
I believe a positive correlation exists between rate of adoption of any technology and its conceptual integrity and ease of use. There should be a case study of recent technologies like languages, frameworks, and OSs, to prove this correlation, but know of none yet.
maxpolk
  • 433
  • My only issue with this answer is, it doesn't provide any real value. Is references a section of a book and from your description would only be applicable once the software package has been released. It doesn't give me an answer in prior to release, as it's basically saying 'it will do well if it is easy to use and relevant to the domain.' I can't say how well it will do because it's not to a point yet where you can use it. The thing with compilers is, you do lots and lots of work, only to realize you're only half way up the mountain, and that's the easy part. – Allen Clark Copeland Jr Aug 15 '11 at 19:07
