I am specifically looking for language influences (as opposed to framework). At first glance C# seems to be an evolution of C/C++ or Java. But we know C# has the same designer as Delphi, and he even acknowledged some similarities and said "good ideas don't just go away." The one example I see of something in C# that is not in Java or C/C++ is properties. Is that it? Are there others?
It's a real shame that some of them actually did. Look at how long it took the .NET folks to reimplement the dynamic capabilities that Delphi's had available in the `variant` type since pretty much forever... – Mason Wheeler Jul 28 '11 at 19:03
Thankfully they did not stick with the BEGIN and END... – Newtopian Jul 28 '11 at 19:57
2@Newtopian: So you prefer punctuation over readable words? More of an APL kind of programmer? – Jim McKeeth Jul 28 '11 at 21:01
Turbo Pascal (ancestor of Delphi) was written by [Anders Hejlsberg](http://en.wikipedia.org/wiki/Anders_Hejlsberg), chief architect of the C# language at Microsoft. Connect the dots. – Robert Harvey Jul 28 '11 at 21:29
@Robert: Right, but I am curious if that influence shows up anywhere specifically in the language. – Jim McKeeth Jul 28 '11 at 21:34
Almost certainly. But I'd say Java probably had more influence over the overall language design than Turbo Pascal did. – Robert Harvey Jul 28 '11 at 21:35
5APERSANDJim COLON yesCOMMA I much prefer punctuation over their english pronounciationEXCLAMATIONMARK because I think it makes the whole thing much more readablePOINT COLON DASH SEMICOLON – Newtopian Jul 28 '11 at 23:11
Not that much which is visible to the programmer, but behind the scenes, quite a bit, but a lot of them were in the IDE and windows forms control design, rather than the language itself, I have been using Delphi 7 for about 10 years and C# for about 5 so I have picked up on a few:
1) The anchors property is identical to Delphi
2) The form default position
3) The object hierarchy for the controls
4) The form designer in general feels very similar - cant put my finger on it exacly.
Some things in the language itself I have noticed:
1) Certain data types, aka Currency / Decimal
Some things in the language that are very different:
1) Constructor inheritence (delphi used to inherit all constructors to base objects they didnt have to be defined again in descendant classes)
2) Delphi had the ability to downgrade the visibility of a method or property in descendant classes, but keep polymorphism intact, C# does not allow this (I miss this very much)
I have probably missed heaps of things, please add them if you think of them.
- 271
- 1
- 1
I wish language designers would recognize as distinct the outside-world interface inherited from base class, the outside-world interface of the derived class, and the interface the base class presents to the derived class. If various classes will have overlapping sets of abilities, it's much easier to wrap a common base class or interface which exposes all those abilities along with member to say which ones are actually usable, than to wrap a variety of classes which expose different combinations of those abilities; there's no reason, though, why derived classes should have to... – supercat Jan 19 '15 at 00:05
...expose--as members of their own type (as opposed to the base type)--members which will not actually be usable with their own type. If a base-class contract says that any derived class whose `CanWoozle` property returns true must provide a usable `Woozle()` implementation, but a particular derived class always returns false for `CanWoozle` and has a legitimately-unusable `Woozle` implementation, there's no reason the derived class should have to expose its `Woozle` member. – supercat Jan 19 '15 at 00:12
Anders was with Borland until Delphi 3 - he was the original architect of Delphi as well as Turbo Pascal. If you load Delphi 1, bring up the about box and type AND you get a picture of Anders that winks at you.
When he left Borland for MS he initially did J++ which "upset" Sun a little bit. Then he created C#. The dots you should join go from Borland Object Pascal -> Java/J++ -> C#
C# is Microsoft's attempt to create a better Java. As an old Delphi coder I'd accept that they probably succeeded.
- 6,122
- 2
- 25
- 27
1I disagree that C# is an attempt to "make a better Java". Though there are Java experts on the C# design team, we very rarely make explicit comparisons to Java when designing language features. – Eric Lippert Aug 17 '11 at 23:07
