Does anybody have suggestions on creating a flowchart representation of a REST-style web interface? In the interest of supplying thorough documentation to co-developers, I've been toying around in dia modeling the interface for modifying and generating a product resource:
This particular system begins to act differently with user authentication/resource counts, so before I make modifications, I'm looking for some clarification:
  • Complexity: how would you simplify the overall structure to make this easier to read?
  • Display Symbol: is this appropriate for representing a page?
  • Manual Operation Symbol: is this appropriate for representing a user action like a button click?
Any other suggestions would be greatly appreciated.
My apologies for the re-post. The main stackexchange site suggested this question was better presented on programmers.
TheLQ
  • 13,478
  • 55
  • 87
James Kassemi
  • 203
I feel Message Sequence Chart/Sequence diagram is better suited for documenting RESTful API interaction. What you have is a state diagram, while RESTful API by definition is stateless.
vartec
  • 20,760
  • 52
  • 98
    The server in a RESTful architecture is stateless, however, the system itself is not. State is stored at the client, and possible state transitions are encoded within the representation of a resource so that the client can initiate the transition to a new state by making a request to the server. I think a state diagram is quite effective at communicating the overall system state, even if it doesn't precisely document the requests and responses between the client and server components. – Adam Jaskiewicz Jul 27 '11 at 20:42
    @Adam: you're right about overall system. But the question explicitly asks about documenting REST interface, not the whole system. – vartec Jul 28 '11 at 07:37
  • Thanks, vartec, the MSC effectively documents the REST interface in this instance. I'm still curious to hear improvements to this model's documentation of the client's state. – James Kassemi Jul 28 '11 at 23:30
    RESTful systems that implement the hypertext constraint cause the client to act as a state machine. I have found using state machine type diagrams to be a far more effective tool for documenting RESTful client/server interactions. – Darrel Miller Aug 02 '11 at 12:08
  • Is there possible to describe `if`-s and `while`-s in this diagram? – hellboy Jun 10 '15 at 18:16
I definitely think a state machine is the right way to document that interactions of a RESTful system. However, I am still working on the right way to represent the hypermedia factors in the diagram. Here are a couple of experimental diagrams that I have done.
Maze
My two pennies on the subject, as I am working with this at the moment:
  • focus on resources and their relations
    • and not on the action, and thus the HTTP method
    • when you follow a link, no matter if you did a GET or POST, your next possible states are dictated primarily by the current resource, and much less by the request's HTTP method
With that in mind:
  • remove some obvious links (i.e. to self, to root)
  • remove the relations' label if it just states "this [car] has a [owner]", where the source resource is car and the target resource is owner. It doesn't add anything
  • an interactive graph can be of great help with a complex state diagram (example)
