Here is a logical statement:
term1 AND (term2 OR term3) OR term4
What is an effective way of storing this information in a data structure?
For example, should I use a graph, with a property on each edge defining the operator to the next term? (This suggestion doesn't make sense IMO, but it's a data structure that might be useful for this)
Trindaz
  • 195
I used an object graph to code something similar before. Each object in the graph has its own structure.
For example:
BinaryLogicalExpression : BooleanExpression
  Left : BooleanExpression
  Right : BooleanExpression
  Operator : BinaryLogicalOperator
ArithmeticExpression : Expression
  Left : Expression
  Right : Expression
  Operator : ArithmeticOperator
// for modelling brackets...
LogicalGroupExpression : BooleanExpression
  GroupedExpression : BooleanExpression
// to hold constant values...
IntegerConstant : Expression
  Value : int
StringConstant : Expression
  Value : string
I'd then use a series of Visitor implementations to traverse the object graph for evaluation and processing of the expression.
Expression
  Accept(ExpressionVisitor visitor);
ExpressionVisitor
  Visit(BinaryLogicalExpression e);
  Visit(ArithmeticExpression e);
  Visit(StringConstant e);
  Visit(IntegerConstant e);
  etc...
Using an object graph and Visitor makes it easy to serialize such expressions to XML or similar hierarchical data structure.
Ed James
  • 1,351
an array could be used, so:
term1 AND ( (term2 OR term3) OR term4 )
would be:
[ {term1},
  { 'OR' : [ { 'OR' : [ {term2} , {term3} ] },
             {term4}
in PHP:
array('term1',array('OR'=>array(array('OR'=>array('term2','term3')),'term4')));
this notation is used in the CakePhp framework =).
Good Luck
I'd try trees, nest them so that each level has the operator on a left branch and all the data on a right branch ala Lisp.
In C you might do something like this:
enum NodeType {OPERATOR, VARIABLE};
enum Operator {AND, OR, NOT, IFF, PLY};
struct Node {
    enum NodeType typ;
    enum Operator op;
    struct node *left;
    struct node *right;
Parentheses don't appear explictly in the structure. Any struct Node instance with typ == OPERATOR effectively parenthesizes the two terms that left and right elements point to. You would also have to decide on a convention for the NOT operator: only one of left, right point to the negated term.
Bruce Ediger
  • 3,535
