21
If I write a public-facing commercial website, and use a GPL javascript library and/or binaries without modifying them (such as plupload), would I be required to make the source for my website available? Is that considered distribution?
That component is just an example. I know a commercial license is available, but would I need a commercial license if I wasn't modifying the source code of the component?
Adam Lear
  • 31,939
  • 101
  • 125
Andrew Lewis
  • 533
    Why is a question about the GPL closed as a duplicate of a question about the LGPL? – Robert Harvey Oct 01 '13 at 21:08
  • @RobertHarvey correct duplicate is [Can I use GPL software in a commercial application](http://programmers.stackexchange.com/questions/47032/can-i-use-gpl-software-in-a-commercial-application) – gnat Jan 07 '15 at 19:14
    @gnat the duplicate link to http://programmers.stackexchange.com/questions/131264/what-constitutes-distributing-for-lgpl-v3 is correct. You find that the answer there includes the case for GPL. In your link the question 'what is distribution' is not touched. – Adam Apr 15 '16 at 14:16
GPLv2 does not mandate that. Actually, there is a modified version(AGPL) that is specifically designed to force web apps to release the code. If the binaries are running on the server, you don't have any obligation under vanilla GPLv2.
Atilla Filiz
  • 468
No, and it doesn't matter what the license says (in the United States). As a matter of law, you are not copying the covered work and you are not distributing the covered work. So you don't need a license. In the United States, the ordinary use of a work does not require any sort of license.
The GPL only applies to people who agree to it. Generally, you agree to the GPL because you want to do something that copyright law says you may not do without a license such as distributing or modifying a work. If you aren't doing anything that copyright law reserves to the copyright holder, you have no need for any license.
David Schwartz
  • 4,676
  • 26
  • If this answer would be correct, there wouldn't be an industry for web software because nobody would feel obliged to comply with anything nor pay any product.... So what's the missing point here ? If you put a software on a server, technically you do a copy of it, so you are bound by the license. And the client browser loads the code (i.e. a copy into memory) for executing it, it is a distribution (it wouldn't be distribution if it would be server side code). By the way, I'm not a lawyer, so my opinion shall not be considered as legal advice. – Christophe Jun 06 '16 at 18:16
  • @Christophe No, those are not legally considered copying. Anything that's necessary for the ordinary use of the covered work is considered use. If you can legally obtain a lawfully made copy of a work, you have the legal right (in the United States) to the ordinary use of that work, unless you specifically agree to give that right up. – David Schwartz Jun 06 '16 at 18:28
