(I think the problem described below is also affecting VS although I only tested it in MD)
I have some trouble regarding circular dependencies. I know they are bad practice and should be avoided. In recent MonoDevelop Releases, you can't even create circular dependencies. However, I can't find an easy way out in the following Scenario:
Application A uses the managed extensibility framework (MEF) to dynamically add functionality via Plugins, which can be developed by 3rd parties, and are loaded by just placing the .Dll into the bin/ folder (DirectoryCatalog in MEF terms).
As I am the Developer of Application A, I ship some default Plugin(s) along with my application. Plugins may deliver LOTS of functionality to extend Application A, so I have every Plugin in a new .csproj Project.
To develop a plugin, one (myself or any other 3rd party) must implement a class that implements an interface. The interface, lets call it Interface A, is defined in Application A and is less than 50 lines of code. Thus, Plugin A requires Application A as a dependency, because Interface A is defined in the Assembly of Application A. Since I want to use the Plugin A in my Application A, I add it as a reference, too. And voila, there is a cross reference between the two.
I've come up with solutions, but I am not happy with them:
1) Create a seperate project and put ONLY the interface file in it. I dislike that because I don't see a 50line .cs to be a seperate project and consider this as "over-modularization"
2) Do not reference the Plugin at all within Application A (this is possible, as Application A only uses Interface A - the actual class instance is loaded by MEF).
This, however, leaves me with some trouble: I cannot work on Application A and easily go to the code of Plugin A to fix sth. or add a feature which I often do - because I load core functionality into Plugins (one of the main goals of MEF is to allow modularization). I could however, start a 2nd instance of VS / MD. But this gets bad the more plugins I add, I will end up having 10 instances of IDEs open - I doubt any machine could handle this.
So has anybody a recommendation on how to organize this correctly?
