I tried VIM and liked it but something stopped from using it: I had to type ESC to often, very often, something like each 5 seconds, and it was highly uncomfortable, so I stopped using it as a primary text editor (now I use emacs, nice for programmer as I am).
After my sad experience with VIM, I could get why some much intensive users love vim. But now I suppose that maybe, after a bigger training, the frequency of mode switching could decrease dramatically.
So, to verify this hypothesis, I am asking to you, old vim users, how frequently do you switch the mode?
BenjaminB
  • 1,706
  • Here is a list of some interesting VIM plugins for Web developers. These plugins surely saves a lot of time.. http://www.fortystones.com/vim-plugins-web-developers-programmers/ –  Aug 29 '11 at 09:16
9 Answers9
I've been using vi/vim for nearly 30 years now, and I must say I've never found the mode switching an issue. And you don't think emacs has modes????
As to your question, I really couldn't say. I suppose my work pattern is:
  • open a file
  • move around in command mode until I find the right place
  • go into insert mode and write some text
  • go into command mode and savethe file
  • compile
  • in command mode (note probably NOT in insert mode) fix syntax errors
  • repeat as needed
So I tend to do reasonable sized blocks of work in each mode. It's not like I'm typing a character, switching to command, issuing a command, going to insert, typing another character.
Neil Butterworth
  • 4,056
I can't tell you how often I switch modes, because it's almost second nature. It's not something I do consciously and I think most people agree on this. I did remap Caps Lock to Esc and it is much better, highly recommended.
Maybe the first week was like that as you paint it. I forced myself to use it for everything and it stopped being frustrating after a week. If you want to master it, I suggest the same. There are some good blog posts out there about setting up a comfortable environment (mainly about the tons of options configurable in .vimrc).
Tamás Szelei
  • 7,737
  • 38
  • 42
I switch modes... always. Esc is the most popular key on my keyboard. Even in browser, typing this very message, I've hit Esc a couple of times, because it's already a habit. And I don't care! Smoking, for instance, would be a much worse habit.
However, if it really bothers you that much, I suggest you to see a shrink.
P Shved
  • 7,427
  • 35
  • 50
Most vim users would be switching between insert and visual mode all the time. Esc does suck to type a often. The day I started using Ctrl-c in place of Esc was the day my productivity increased tenfold. I think reaching for the Esc key a lot would mildly strain my left hand too...
J.K.
  • 13,063
  • 40
  • 56
You can remap ESC to whatever key combination you want :
I have the following code in my .vimrc :
" remap ESC to ii to avoid leaving home row to leave insert mode
" i to enter insert mode, ii to leave
inoremap ii <Esc>
vnoremap ii <Esc>
snoremap ii <Esc>
When you are in Insert, Visual or Select mode you can use 'ii' instead of ESC.
As long as you are not editing a file with variables containing 'ii' it works fine.
If I remember correctly, when Vi was developed the ESC key was at the same place that the CAPS lock on current keyboards. It was much easier to reach. As a consequence some people are using CAPS lock to switch mode.
Xavier T.
  • 1,612
  • Good, I will test soon. – BenjaminB Aug 24 '11 at 17:42
  • This is language-dependent; I've seen a lot of "ii"s in assorted Finnish names, and suspect it's reasonably common in the language, so it would be a pain when typing comments also. – David Thornley Aug 29 '11 at 16:03
  • @David Thornley : I agree. Still it should be possible for any language to find a two key combination that should work. I have seen people mentioning `jk` as a replacement for escape. It works well too. ( And if all 2 keys combination are equally likely in your language of choice, you can use a 3 keys combination ). That being said I suppose that most people writing comments are usually writing them in English, since this is the lingua franca of our time, particularly for software. – Xavier T. Aug 29 '11 at 16:20
It depends on what I am doing.
When I'm banging out new code I am in Insert mode most of the time.
When I'm editing code on the PC I make use of the arrow keys quite a lot so I can stay in insert mode quite a lot. Its a bad habit, but one that's hard to break.
When coding on my iPhone over SSH, I don't have the arrow keys so have to come out of Insert mode pretty often to navigate.
You get used to it. Even when coding in Visual Studio I find myself pressing escape every 10 seconds.
Mongus Pong
  • 1,418
    "When coding on my iPhone over SSH" I sure hope this is a last ditch effort and not a regular thing. I tried that a few times and could not manage to handle it. – Chris Jun 14 '11 at 11:21
  • @Chris, yeah we've just had a baby so I have to take whatever chances to code that I can get! I very rarely find myself in front of a laptop in my spare time any more. – Mongus Pong Jun 14 '11 at 11:39
  • I can totally understand that! – Chris Jun 14 '11 at 13:41
The trick for me is to stay in command mode by default. Switch to insert/replace mode, enter text, switch straight back. If I leave the screen and come back, I'm in command mode; if I'm moving around the document, I'm in command mode. And so on.
That's not to say that I don't spend a fair amount of time in insert mode. It just means that while I'm there, I'm aware that I'm not in command mode and that I need to hit escape when I stop typing.
Why is this useful to you? What I quickly found is that I stop thinking of it as switching "modes" and started thinking of i/a/o (etc) as commands, which are followed by a string of characters and completed using ESC.
pdr
  • 53,387
  • 137
  • 224
I'm a new VIM user, and switch modes just about as often. Though, I hasn't remapped my keys, the default secondary Ctrl-[ works well for me.
However, what I find important, isn't that I need to switch modes often. It's simply that I rarely need to switch context. When I'm working, I'm working, and the mechanics doesn't really matter.
tylermac
  • 338
to change the mode ,you can use ctrl-[ to replace the esc
It will work better! stick with it and you will done!
