I just ran across an answer to another question that references the Halting Problem. He starts with this snippet:
def halts( code_block ):
    # Some magical code
def whistler():
    while halts(whistler):
        sys.whistle( 1 )
and then explains how the routine halts cannot be defined correctly because it essentially ends up being logically equivalent to "this sentence is false". Aside from the Python-style syntax, this is basically the standard explanation of the halting problem, and I've never understood the concept. Every time I look at that type of example, I think "but why in the world would anyone approach the problem in that way in the first place?"
If I wanted to determine a difficult property of a piece of code, such as answering the question of whether or not it halts, there's no way I would put the analysis inside the code to be analyzed! First off, that leads to contradictions like this example, and second, adding analysis code changes the nature of the thing being analyzed. I would almost certainly go about looking for the answer to the question with external tools, not internal ones.
So yes, I understand that there's no way to write a correct implementation of halts in the example above. But let's restrict ourselves solely to the realm of code that actually can be written correctly, instead of hypotheticals. What's an example of code that can actually be written and executed, for which it is impossible to determine by external analysis whether the code will end up in an infinite loop or whether it will terminate?
Mason Wheeler
  • 82,151
  • 234
  • 309
    `function foo(){if (Math.random() < 0.5) while (true);} foo();`? – zzzzBov Jun 07 '11 at 01:24
  • @zzzzBov: This can be predicted easily enough if you know the state of the PRNG that Math.random implements. ;) – Mason Wheeler Jun 07 '11 at 02:04
  • Why not start with http://en.wikipedia.org/wiki/Liar_paradox? – Job Jun 07 '11 at 02:29
  • There are counting arguments that may be simpler to understand, although they require proofs by contradiction too. -- To get what you want, you'd need a program that is equivalent to solving an independent mathematical problem, such as the continuum hypothesis. But think about it this way: Many open problems in mathematics can be stated as programs that may or may not halt: Showing if it halts or not would be the same as solving a long standing problem in mathematics! – Macneil Jun 07 '11 at 03:16
  • What I never understood is what they mean by "giving a program to another program". I always understood it like one program getting source-code of another program, parsing it and analyzing it and saying "Hey, here is an infinite loop hard-coded! This thing will run forever!". But now I saw a video that was more like "a program A gets a program B and to check if B halts, A actually runs B". Just a so basic distinction that every single video about the topic seems to don't care to explain clearly. – Rafael Eyng Dec 06 '20 at 03:06
The trick here is that this is a proof by contradiction : assume A, demonstrate it would imply a paradox, conclude assumption was wrong.
So the idea is not that we "would approach the problem in that way" or that we "would put the analysis inside the code to be analyzed". The idea is rather: suppose someone came up with a program and said "Look, I wrote a program that tell if any given program will halt or not". "Oh really? Lemme see what happens if I plug it into itself?" KABOOM!
There's no need to actually take an existing example: this already proves there's no way such a program could exist.
On a side note, it does not mean we cannot try to write such a halts function. It just means it is impossible to write a halts function that will work for any program.
Julien Guertault
  • 720
    "…it is impossible to write a `halts` function that will work for **any** program." In my opinion, that crucially important *any* is thoroughly under-emphasised in descriptions of the Problem. I'd even go so far as to wager you could write a `halts()` that works for the majority of programs. – Jon Purdy Jun 07 '11 at 05:05
    I wouldn't go that far, but yes, there are branches of code you could definitely write a checking code for. I heard there are softwares doing that, with a "is ok" / "is ko" / "cannot tell" coloring for instance. – Julien Guertault Jun 07 '11 at 05:52
  • _"Oh really? Lemme see what happens if I plug it into itself?" KABOOM!_ That did nothing for me. No "kaboom" in my head. An actual explanation would be better – Rafael Eyng Dec 06 '20 at 02:55
You are stating the answer to your question without realizing it.
This is the essence of the halting problem. There is no way to write the halts function. There is no #some magical code. It cannot exist. The proof of the halting problem is a restriction on the realm of code that can be written.
This is another important distinction to make. The halting problem says it is not possible to write a program that determines if any program will halt.
It is possible to write a program that determines if a particular program halts.
David
  • 329
  • "It is possible to write a program that determines if a particular program halts" while I agree with the idea, stating it that way is a bit misleading, since *there are particular programs for which it is impossible to do*. – Julien Guertault Jun 07 '11 at 05:47
If I wanted to determine a difficult property of a piece of code, such as answering the question of whether or not it halts, there's no way I would put the analysis inside the code to be analyzed! [...] I would almost certainly go about looking for the answer to the question with external tools, not internal ones.
If Turing's halting problem is really analogous Gödel's incompleteness theorems... then I think what it's really telling you is that you can never solve the problem without going to that external "layer" of meaning or representation.
Thus you cannot make an analyzer that works on itself, you can only make a meta-analyzer, and a meta-meta-analyzer for that, and a meta-meta-meta-analzyer for that, etc. (And you can't make reciprocal analyzers either.)
That's why the "nesting" is part of the problem.
Darien
  • 3,453
  • That is indeed the point. A "simple" Turing complete language cannot decide halting. A "higher-order" logical language is required. And in some cases, the halting proofs are quite subtle. – S.Lott Jun 07 '11 at 00:36
The Collatz Conjecture, sometimes called the Syracuse Problem. http://en.wikipedia.org/wiki/Collatz_conjecture
Simple, and undecidable.
Need more? Here's a big list of problems you could write potentially correct algorithms for. Without a proof that your algorithm terminates, however, you don't ever really know if it's correct.
http://en.wikipedia.org/wiki/List_of_undecidable_problems
S.Lott
  • 45,264
  • 90
  • 154
    Actually, the conjecture *may* have been recently proved true by Gerhard Opfer, a former student of Collatz. – Jon Purdy Jun 07 '11 at 00:54
