30
A recent question on stackoverflow provoked a discussion about the immutability of primary keys. I had thought that it was a kind of rule that primary keys should be immutable. If there is a chance that some day a primary key would be updated, I thought you should use a surrogate key. However it is not in the SQL standard and some RDBMS' "cascade update" feature allows a primary key to change.
So my question is: is it still a bad practice to have a primary key that may change ? What are the cons, if any, of having a mutable primary key ?
Vincent Malgrat
  • 403
9 Answers9
27
You only need the primary key to be immutable if it's linked to a foreign key, or if it's used as an identifier outside the database (for example in an URL pointing to a page for the item).
On the other hand, you only need to have a mutable key if it carries some information that might change. I always use a surrogate key if the record doesn't have a simple, immutable identifier that can be used as key.
Guffa
  • 2,990
    Why do you "*need* the primary key to be immutable if it's linked to a foreign key"? As the OP mentioned, most RDBMSs have the "cascade" update feature. – Thanatos Nov 17 '11 at 09:25
    @Thanatos most (in fact all I've encountered) rdbms's will not allow mutable primary keys yet have cascading updates. A primary key, in generally accepted dba wisdom, should contain no information, be only a unique record identifier (so not even a timestamp, record range deferred from it, etc.). – jwenting Nov 17 '11 at 11:32
    @jwenting: Are we talking about the same thing? "most rdbms's will not allow mutable primary keys" includes what? MySQL and PostgreSQL both allow mutable primary keys, and honor cascading updates… as I think standard SQL says they should. Also, "generally accepted dba wisdom"? I've met plenty of DBAs who argue against surrogate keys, and plenty who argue against natural keys. – Thanatos Nov 18 '11 at 01:29
    @Thanatos Arguments in favor of *"all tables must have surrogate"* lack bibliographic references, they cite "generally accepted dba wisdom" but they never cite a book. Canonical books say you should use surrogate if: A. no natural key exist, B. multicolumn key is excedes 3 columns, or, C. You will be changing the key all the time. So: natural when they fit, surrogates when naturals won't fit. – Tulains Córdova Jun 04 '13 at 16:48
    @Guffa Hardware is cheap. Programmers are expensive. – Tulains Córdova Jun 04 '13 at 16:56
    @user61852: What? – Guffa Jun 04 '13 at 18:01
16
A primary key should be comprised of whatever tuples are necessary to determine uniqueness. Whether the data can change or not is irrelevant. Only the uniqueness of the record matters. That is the conceptual design of the database.
When we move into the realm of implementation, then the safest thing to do is simply use a surrogate key.
Chris Holmes
  • 2,244
Yes, in my opinion a primary key should be immutable.
Even if there are obvious candidate keys, I always use a surrogate key. In the few occasion's I haven't done this i've nearly always regretted it. And no matter how immutable you think the key is, you can't safeguard against data-entry errors - telling users that they can't edit that bit of information because it's a primary key doesn't wash sadly.
richeym
  • 3,007
  • Good point about data-entry errors – Tim Goodman Sep 29 '10 at 19:12
    richeym, seems like you are making the case why keys must NOT be immutable: users may want to change them. – nvogel Oct 01 '10 at 14:43
    @dportas - my point is that I like PK's to be immutable so always use surrogate keys even if I think there is an obvious key that can be derived from the table data (e.g. email, username). – richeym Oct 09 '10 at 08:43
It is not bad practice to have a key whose values may change.
The properties of a good key include stability. Immutability is ideal but not a prerequisite. Introducing an artificial key for the sake of immutability is bad practice.
Take the example of the International Standard Book Number (ISBN). It is very stable but not immutable: sometime book publishers make mistakes and -- horror! -- duplicate ISBN numbers can occur. Does this mean that ISBN should not be accepted as a candidate key in a computerized database? Of course not. One of the advantages of ISBN is that it has a trusted source that will resolve problems for all users globally.
There are other properies of a good key ISBN has that a meaningless auto-incrementing integer key will lack, e.g. familiarity (everyone in the book trade knows or is familiar with ISBN), verifiable (the ISBN is printed on all modern books), can be validated with reference to the DBMS (ISBN is fixed width and includes a checksum), etc.
jscs
  • 828
onedaywhen
  • 121
    ISBN is fixed width, except when it's not (see ISBN-10 vs ISBN-13). – user Nov 17 '11 at 10:53
  • So how would you recommend handling duplicate ISBNs? In all RDBMSes I am aware of, you would have to have a UNIQUE constraint on the field to use it as a primary key. – Wildcard Aug 15 '16 at 23:20
Caching mechanisms in between database and user will lose effectiveness if primary keys change.
spoulson
  • 129
Why not? Because you want to eliminate a column?
Just because the requirements call for three columns to be unique, doesn't mean it has to be the primary key. You may think that rule will last forever (Remember during that meeting when the pinhead department manager swore that would never change? You know, the one that just got fired.), but it won't.
I don't get paid for every cascade update I implement and a bonus if I code it myself.
The computer doesn't require any meaning for a key; IMHO, keys are for computers, let the people screw up the rest of the data.
JeffO
  • 36,816
  • 57
  • 124
    "keys are for computers, let the people screw up the rest of the data." +1, nice. –  Jun 04 '13 at 14:53
Yes, a primary key must be immutable, along with being non-null and unique. However, I have yet to find a database that enforced the immutability of primary keys so you can probably go ahead and change their values if you really want to.
Everything that can possibly be immutable should be. It helps to ensure correctness and helps when you want to make your application multithreaded.
dash-tom-bang
  • 2,543
As some comments already said it, one solution is to use a new primary key
For example (following the example of @onedaywhen), let's say that exists the table Books that store a list of books and we "used" to determine the ISBN as the primary key. However, some authors committed the mistake of typed a wrong ISBN so, they asked for change the ISBN, it involved the next tasks:
  • create a new registry in the table Books
  • point all references from the old ISBN to the new ISBN. (*)
  • And finally, delete the old registry from the table Books.
(*) this could be trivial to find all the references for a database model that uses Foreign Keys but some models lacks of it.
Table Books
ISBN  is the primary key
NAME is a simple field.
etc.
We change it as
Table Books
InternalBookId as the primary key
ISBN as a simple field or an indexed field.
etc.
Where the new InternalBookId could even been a autonumeric value.
The cons about it:
  • it adds a new field that uses more space / resource.
  • it could requires to rewrite the entire model.
  • the new model could be less self explained.
The pro
  • Allows to mutate the "primary key".
  • Allows to even drop or refactoring the "primary key", for example, to change Books to ISBN-13 is so simple as to drop the older column and to create a new one
New table:
Table Books
ISBN13 is a new field.
etc.
magallanes
  • 218
