14
I recently suggested a method of chaining be implemented for a certain class in a certain project so readability of the code could be improved. I got a "fluent interfaces should not be implemented just for convenience, but for semantics" answer and had my suggestion shot down. I answered that I was not suggesting a fluent interface but method chaining itself (both can be confused with each other, read at bottom) to improve readability and coding comfort, suggestion was shot down again.
Anyhow, this got me thinking that maybe I could be incurring in a bad practice by always returning "this" in methods that are not supposed to return anything (e.g. setters).
My question is: can applying the previous convention be regarded as bad practice or abuse?, why?. I don't think there are any performance drawbacks, or are there?.
gnat
  • 21,442
  • 112
  • 288
dukeofgaming
  • 13,943
  • 50
  • 77
    Look at this question for a nice discussion http://programmers.stackexchange.com/questions/48419/method-chaining-vs-encapsulation – KeesDijk May 30 '11 at 08:40
  • @KeesDijk Thanks, I edited my question a little so its not to similar to that one, as I'm more interested in the case of chaining methods from the same class – dukeofgaming May 30 '11 at 09:01
    at SO, they told me, that chaining is not for C++ - http://stackoverflow.com/questions/5760551/c-calling-a-chain-of-functions-at-different-class-inheritance-levels - what do you think about? – kagali-san May 30 '11 at 16:05
    @mhambra It looks like you would only need to be careful when implementing method chaining and define clear standards for that. – dukeofgaming May 30 '11 at 21:49
No
As Kent Beck points out, code is read far more often than it is written.
If method chaining makes your code more readable, then use method chaining.
Steven A. Lowe
  • 33,808
  • 84
  • 151
    Great book.. +1 – Rein Henrichs May 30 '11 at 18:25
    **BUT**, what if your are the only one finding method chaining more readable? If this is a matter of sytilistic issue, then you'll have stick to a set of coding conventions: this means, writing in the same fashion as existing code, for consistency. – coredump Nov 09 '14 at 19:43
  • @coredump It sounds like the OP's already been told to do that, but I think Steven was just saying this for *if* method chaining makes it more readable. – Panzercrisis Dec 16 '14 at 13:57
    @Panzercrisis OP's been told to refrain using method chaining due to convenience vs. semantics. Steven's answer basically says "do it anyway" and only consider readability of OP's code by itself, without considering the team's opinion or consistency. What if OP wants to rewrite every existing class in the project so that it suits his taste regarding code readability? That's how I understand the convenience/semantics argument: there should be a "technical" reason to have method chaining (btw, that argument also sounds as if the other person is making up an an excuse for his/her own preferences) – coredump Dec 16 '14 at 14:55
Yes, there are drawbacks
Code that is easy to read is good, but also beware of what the code communicates as well. When an object's methods always return the object, it communicates a couple of things:
  1. I require advanced configuration that isn't necessarily obvious in which order things should be set or configured
  2. Each subsequent method call builds on the last
Valid Use Case: Ad Hoc Database Queries
Class libraries exist in most every language that allow you to query a database without resorting to hard coded SQL. Take the Entity Framework for .NET as an example:
DBContext db = new DBContext();
List<Post> posts = db.Posts
    .Where(post => post.Title.Contains("Test"))
    .OrderBy(post => post.DateCreated)
    .ToList();
This is a fluent interface where each subsequent method call builds on the previous one. Reading these calls logically makes sense in the context of querying a database.
Invalid Use Case: Syntactical Sugar For Setting Properties
Now let's use the same pattern with the Post class:
public class Post
    public string Title { get; set; }
    public DateTime DateCreated { get; set; }
    public string Body { get; set; }
    public Post SetTitle(string title)
        Title = title;
        return this;
    public Post SetDateCreated(DateTime created)
        DateCreated = created;
        return this;
    public Post SetBody(string body)
        Body = body;
        return this;
Now let's look at how you would use this class:
Post post = new Post()
    .SetTitle("Test")
    .SetDateCreated(DateTime.Now)
    .SetBody("Just a test");
When I see this code, I immediately ask this question: "After calling SetBody, does it query the database? Do I need to call another method to say 'I'm done?'"
What do the chained method calls communicate to the code using the Post class?
  1. I have a complicated setup
  2. Each method call builds on the previous one
Is this actually true? No. The Post class does not have a complicated setup. Setting the title, date created and body do not build on each other towards a more complicated end goal. You've mashed a square peg into a round hole.
The drawback to self-referential method chaining is that you communicate that multiple method calls are required to do something, and that each call builds off the last. If this is not true, then method chaining could be communicating the wrong thing to other programmers.
When your coworkers said:
Fluent interfaces should not be implemented just for convenience, but for semantics
They were absolutely correct. A fluent interface, or method chaining, communicates something in and of itself which might not be true.
Greg Burghardt
  • 34,276
  • 63
  • 114
  • This assumes that method chaining and complex configuration always go hand in hand. They're distinct entities and the presence of one should not make you assume the other. – Jack Dec 16 '14 at 14:05
  • It's not just "complex configuration," it's also "subsequent method calls build off the previous one". Method chaining has a meta communication about it that isn't always true to the purpose of a class. – Greg Burghardt Dec 16 '14 at 14:07
    Subsequent method calls building off of previous ones is distinct from method chaining as well, and I don't think that treating the syntax of method chaining as strong communication for the semantics of order-dependent series of side-effecting operations is reliable or useful. It's a syntactic shorthand, nothing more. Use it where it makes things shorter and more readable. – Jack Dec 16 '14 at 14:16
    I understand you think method chaining is separate, but I'm saying that other programmers who weren't inside your head and use other class libraries that _do_ implement method chaining for these reasons could end up making assumptions about your code that are untrue. Be aware that method chaining could imply something that you, the code author, did not intend. Code that communicates clearly is just as important as code that is easy to read. Don't sacrifice one for the other. – Greg Burghardt Dec 16 '14 at 14:24
  • The link is so tenuous that it's a stylistic issue, not a hard and fast rule. This is not a case of "do it or don't do it", this is a case of "be consistent with the style of your team.' Or, if this is a third party library, a case of "read the docs". Assuming method chaining means there's order-dependent side effects is a good way to shoot yourself in the foot, so trying to avoid that implication - especially for code that's internal to the team and consistent with their style - is not a strong enough reason to sacrifice readability. – Jack Dec 16 '14 at 14:33
  • Everything you've said is a con for the Post class could equally be said about the DB example. But I don't think it's a con at all, not complicated, it's pretty obvious that each action is it's own entity, in turn being acted on by the next method. – OJFord Dec 16 '14 at 16:02
  • @OllieFord: The same could _not_ be said about the DB example. The method chaining is used to encapsulate something much more complex than just one single action: Setting up a database query. It's a con for the Post class, a Pro for the DBContext. – Greg Burghardt Dec 16 '14 at 16:07
  • Perhaps I'm misunderstanding the intended implementation - but all I'm seeing is a getter returns some collection, is filtered returns some subset collection, is filtered by different method returns some ordered collection, is converted to list returns list. How's this more special than any other sequence of operations on a sequence of entities? – OJFord Dec 16 '14 at 16:18
  • It doesn't return a collection. It returns a query builder object that eventually generates some SQL executed against the database. The `ToList()` method call actually converts the query builder object into SQL, executes, then maps the results to objects in C#. It a very complex, multistep process. – Greg Burghardt Dec 16 '14 at 16:38
    `When an object's methods always return the object, it communicates a couple of things` - I think this is a personal opinion; it's hard to claim that everyone looking at chained methods will assume the same things. – Sam Dufel Dec 16 '14 at 19:47
The main drawback is a loss of clarity. For instance:
x.foo();
x.bar();
x.baz();
Since none of those statements return a value (or if they do, it's been ignored), they can only be useful if they produce side effects. Contrast that to:
x.foo()
 .bar()
 .baz();
First, it's not clear that bar and baz operate on objects of the same type as x, unless you know for a fact that x's class is the only class with those methods. Even if that's the case, it's not clear the methods operate on x, or new objects.
Highlighting the parts of the code that have side effects is useful, since you need to track those side effects to reason about the program. You have to weigh the potential loss of clarity against the potential gain in ease of writing code, but also consider that code is read more than it's written.
Doval
  • 15,347
  • 43
  • 58
Consider all the stylistic elements of programming languages (as opposed to hand-coding machine language), and it weakens the "semantics not convenience" argument.
A whole lot of what we do as engineers is providing convenience around semantics.
sea-rob
  • 6,841
  • 47
