291
A colleague of mine today committed a class called ThreadLocalFormat, which basically moved instances of Java Format classes into a thread local, since they are not thread safe and "relatively expensive" to create. I wrote a quick test and calculated that I could create 200,000 instances a second, asked him was he creating that many, to which he answered "nowhere near that many". He's a great programmer and everyone on the team is highly skilled so we have no problem understanding the resulting code, but it was clearly a case of optimizing where there is no real need. He backed the code out at my request. What do you think? Is this a case of "premature optimization" and how bad is it really?
Craig Day
  • 563
    I think you need to distinguish between premature optimization, and unnecessary optimization. Premature to me suggests 'too early in the life cycle' wheras unncessary suggests 'does not add significant value'. IMO, requirement for late optimization implies shoddy design. –  Oct 17 '08 at 08:53
  • 154
    Yes, but evil is a polynomial and has many roots, some of them are complex. – dan_waterworth May 29 '11 at 12:31
  • duplicate of: [When is optimization not premature and therefore not evil?](http://programmers.stackexchange.com/questions/33020/when-is-optimization-not-premature-and-therefore-not-evil) – gnat Apr 17 '13 at 14:51
    You should consider, that Knuth wrote this 1974. In the seventies it was not that easy to write slow programs as it is nowadays. He wrote with Pascal in mind and not with Java or PHP. – ceving Oct 02 '13 at 13:51
    "which basically moved instances of Java Format classes into a thread local, since they are not thread safe" is not premature optimization. The "and 'relatively expensive' to create" is a secondary justification. Removing a danger to threading by itself probably justifies the change (weasel word 'probably' because I don't know what threading y'all are doing). A combination of removing a logic / race /threading risk along with reducing some performance risk should be acceptable. The only quibble would be if there were large, unresolved problems unrelated to these left to be resolved. – Kristian H Dec 11 '14 at 19:12
    @ceving In the 70 it was as easy as today to write slow programs. If you choose the wrong algorithm or the wrong data structure then BAM! Bad performance all over the place. One could argue the other way around. Today that are a lot more tools and should be inexcusable that a programmer still write software that suffers at the most basic save operation. Parallelism became almost a commodity and we still suffer. Slow performance can't be blamed on the language or tool or CPU or memory. It's a delicate balance of so many things which is why it's nearly impossible to optimize early. – Alex Jan 15 '15 at 12:19
    @alex You optimize already with the language you choose to write your code. If you banish every kind of optimization, everybody must start to code in [Scheme with first class environments](http://lambda-the-ultimate.org/node/3861). But if you choose C instead this is an optimization, because you say: "I do not need correct arithmetic. I calculate with residue class rings, because it is faster." Every piece of code is a trade-off: neither "premature" nor "optimization" can be exactly defined. Knuth expressed just a bias. You can not nail him down on every single word after 40 years. – ceving Jan 16 '15 at 08:04
  • That ThreadLocalFormat, had it stayed in the code, would probably never have left, because everytime someone tried to understand it their head would explode. Having something complex like that because it might save 2 milliseconds is a complete waste of time and damaging to the software in terms of understandability. – Oliver Watkins Apr 14 '15 at 14:10
  • [Program optimization#When to optimize @ Wikipedia](https://en.wikipedia.org/wiki/Program_optimization#When_to_optimize) – Palec Oct 13 '15 at 09:34
  • @OliverWatkins An extremely large portion of the code we run in webservers is library code. If it's well encapsulated and tested or else has simple inputs and outputs which are unlikely to need to change (e.g. a thread abstraction lib), we find it safe to treat as a black box. In our codebase at work we have a number of these; knotty, dense classes that act as well sealed boxes we have never had to reopen. Where an abstraction includes business logic is where I get scared about maintenance. – Adamantish Jan 27 '19 at 15:49
    You're taking your approach too far. We don't increment integer bit sizes literally bit-by-bit as we start needing larger numbers. There's a difference between premature optimization and being able to very simply create something that has ample performance. The difference lies in how much time it costs. If that developer was trying to ensure a handful of instantiations, and their solution happens to perform way better than what they need it for, it would be downright silly to disallow it because it's even better than what you need - unless he needed to spend significantly more time on it. – Flater Feb 01 '21 at 16:30
    Short version: Don't solve problems you don't have – Django Reinhardt Oct 25 '21 at 15:14
17 Answers17
414
It's important to keep in mind the full quote (see below):
We should forget about small efficiencies, say about 97% of the time: premature optimization is the root of all evil.
Yet we should not pass up our opportunities in that critical 3%.
What this means is that, in the absence of measured performance issues you shouldn't optimize because you think you will get a performance gain. There are obvious optimizations (like not doing string concatenation inside a tight loop) but anything that isn't a trivially clear optimization should be avoided until it can be measured.
The biggest problems with "premature optimization" are that it can introduce unexpected bugs and can be a huge time waster.
There is no doubt that the grail of efficiency leads to abuse. Programmers waste enormous amounts of time thinking about, or worrying about, the speed of noncritical parts of their programs, and these attempts at efficiency actually have a strong negative impact when debugging and maintenance are considered. We should forget about small efficiencies, say about 97% of the time: premature optimization is the root of all evil.
Yet we should not pass up our opportunities in that critical 3%. A good programmer will not be lulled into complacency by such reasoning, he will be wise to look carefully at the critical code; but only after that code has been identified. It is often a mistake to make a priori judgements about what parts of a program are really critical, since the universal experience of programmers who have been using measurement tools has been that their intuitive guesses fail. After working with such tools for seven years, I've become convinced that all compilers written from now on should be designed to provide all programmers with feedback indicating what parts of their programs are costing the most; indeed, this feedback should be supplied automatically unless it has been specifically turned off.
Dave Jarvis
  • 743
Scott Dorman
  • 1,489
    Being from Donald Knuth, I wouldn't be surprized if he had some evidence to back it up. BTW, Src: Structured Programming with go to Statements, ACM Journal Computing Surveys, Vol 6, No. 4, Dec. 1974. p.268. http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.103.6084&rep=rep1&type=pdf – mctylr Mar 01 '10 at 17:57
  • 59
    I had a 20k rep user today tell me that using a `HashSet` instead of a `List` was premature optimization. The use case in question was a statically initialized collection thats sole purpose was to serve as a look-up table. I don't think I'm wrong in saying there is a distinction in selecting the right tool for the job versus premature optimization. I think your post confirms this philosophy: `There are obvious optimizations...anything that isn't trivially clear optimization should be avoided until it can be measured.` The optimization of a HashSet has been thoroughly measured and documented. – crush Jan 23 '14 at 14:33
    @crush: yes: `Set` is also more semantically correct and informative than `List`, so there's more than the optimization aspect to it. – Erik Kaplun Apr 28 '14 at 02:38
    I would like to add that premature optimization should not be confused with designing your entire application architecture to run fast in general, scale and be easily optimizable. – Erik Kaplun Apr 28 '14 at 02:39
    Yep. Basically what Knuth meant under "premature optimization" would sound more accurate as "optimization before profiling". Original quote abused too much as an excuse not to optimize code at all. – KolA Apr 13 '19 at 09:16
    @crush I think that HashSets being measured and documented is irrelevant to the point. `selecting the right tool for the job` should also take into account the cost of using the tool and whether or not the problem being solved is worth this cost. – CaTs Mar 01 '21 at 00:57
140
Premature micro optimizations are the root of all evil, because micro optimizations leave out context. They almost never behave the way they are expected.
What are some good early optimizations in the order of importance:
  • Architectural optimizations (application structure, the way it is componentized and layered)
  • Data flow optimizations (inside and outside of application)
Some mid development cycle optimizations:
  • Data structures, introduce new data structures that have better performance or lower overhead if necessary
  • Algorithms (now its a good time to start deciding between quicksort3 and heapsort ;-) )
Some end development cycle optimizations
  • Finding code hotpots (tight loops, that should be optimized)
  • Profiling based optimizations of computational parts of the code
  • Micro optimizations can be done now as they are done in the context of the application and their impact can be measured correctly.
Not all early optimizations are evil, micro optimizations are evil if done at the wrong time in the development life cycle, as they can negatively affect architecture, can negatively affect initial productivity, can be irrelevant performance wise or even have a detrimental effect at the end of development due to different environment conditions.
If performance is of concern (and always should be) always think big. Performance is a bigger picture and not about things like: should I use int or long?. Go for Top Down when working with performance instead of Bottom Up.
Pop Catalin
  • 1,515
optimization without first measuring is almost always premature.
I believe that's true in this case, and true in the general case as well.
Jeff Atwood
  • 6,757
  • 45
  • 49
  • Here Here! Unconsidered optimization makes code un-maintainable and is often the cause of performance problems. e.g. You multi-thread a program because you imagine it might help performance, but, the real solution would have been multiple processes which are now too complex to implement. – James Anderson May 02 '12 at 05:01
  • unless it's documented. – nawfal Jul 02 '14 at 13:18
  • Yes. totally agree. It first has to be measured. There is no way you know where the bottlenecks are until you test something end to end and measure each of the steps. – Oliver Watkins Apr 14 '15 at 14:13
    Measurements can lie. I've seen seasoned specialists spend weeks reading traces and running profiles to hit a wall where they thought there was nothing more to gain. Then I read over the entirety of the code and in a few hours made a few holistic changes to gain a 10x improvement. The profiles showed no hot-paths because the entire code was poorly designed. I've also seen profilers claim hotpaths where there shouldn't have been any. A person "measuring" would have optimized the hotpath, but they should have realized the hotpath was a symptom of other poor code. – Bengie Sep 13 '18 at 18:15
54
Optimization is "evil" if it causes:
  • less clear code
  • significantly more code
  • less secure code
  • wasted programmer time
In your case, it seems like a little programmer time was already spent, the code was not too complex (a guess from your comment that everyone on the team would be able to understand), and the code is a bit more future proof (being thread safe now, if I understood your description). Sounds like only a little evil. :)
John Mulder
  • 301
    Only if the cost, it terms of your bullet points, is greater than the amortized value delivered. Often complexity introduces value, and in these cases one can encapsulate it such that it passes your criteria. It also gets reused and continues to provide more value. –  Oct 17 '08 at 10:36
    Those first two points are the main ones to me, with the fourth point being a negative consequence of doing premature optimization. In particular, it is a red flag whenever I see someone re-implementing features from a standard library. Like, I once saw someone implement custom routines for string manipulation because he was concerned that the built-in commands were too slow. – jhocking May 29 '11 at 12:47
    Making code thread safe is not optimization. – mattnz May 01 '12 at 22:47
52
I'm surprised that this question is 5 years old, and yet nobody has posted more of what Knuth had to say than a couple of sentences. The couple of paragraphs surrounding the famous quote explain it quite well. The paper that is being quoted is called "Structured Programming with go to Statements", and while it's nearly 40 years old, is about a controversy and a software movement that both no longer exist, and has examples in programming languages that many people have never heard of, a surprisingly large amount of what it said still applies.
Here's a larger quote (from page 8 of the pdf, page 268 in the original):
The improvement in speed from Example 2 to Example 2a is only about 12%, and many people would pronounce that insignificant. The conventional wisdom shared by many of today's software engineers calls for ignoring efficiency in the small; but I believe this is simply an overreaction to the abuses they see being practiced by penny-wise-and-pound-foolish programmers, who can't debug or maintain their "optimized" programs. In established engineering disciplines a 12% improvement, easily obtained, is never considered marginal; and I believe the same viewpoint should prevail in software engineering. Of course I wouldn't bother making such optimizations on a one-shot job, but when it's a question of preparing quality programs, I don't want to restrict myself to tools that deny me such efficiencies.
Yet we should not pass up our opportunities in that critical 3%. A good programmer will not be lulled into complacency by such reasoning, he will be wise to look carefully at the critical code; but only after that code has been identified. It is often a mistake to make a priori judgments about what parts of a program are really critical, since the universal experience of programmers who have been using measurement tools has been that their intuitive guesses fail.
Another good bit from the previous page:
My own programming style has of course changed during the last decade, according to the trends of the times (e.g., I'm not quite so tricky anymore, and I use fewer go to's), but the major change in my style has been due to this inner loop phenomenon. I now look with an extremely jaundiced eye at every operation in a critical inner loop, seeking to modify my program and data structure (as in the change from Example 1 to Example 2) so that some of the operations can be eliminated. The reasons for this approach are that: a) it doesn't take long, since the inner loop is short; b) the payoff is real; and c) I can then afford to be less efficient in the other parts of my programs, which therefore are more readable and more easily written and debugged.
Michael Shaw
  • 5,116
    In fact, Knuth is very much pro-optimization (some observations in [this tweet](https://twitter.com/pervognsen/status/1252736617510350848) and replies)—and he wrote that sentence more in the sense of "sure, sure, I agree premature optimization is bad, let's agree to call it the most evil thing, but look, a careful use of `goto` in inner loops can give a 12% speedup; why would you give that up?" – ShreevatsaR Jun 17 '21 at 06:50
27
I've often seen this quote used to justify obviously bad code or code that, while its performance has not been measured, could probably be made faster quite easily, without increasing code size or compromising its readability.
In general, I do think early micro-optimizations may be a bad idea. However, macro-optimizations (things like choosing an O(log N) algorithm instead of O(N^2)) are often worthwhile and should be done early, since it may be wasteful to write a O(N^2) algorithm and then throw it away completely in favor of a O(log N) approach.
Note the words may be: if the O(N^2) algorithm is simple and easy to write, you can throw it away later without much guilt if it turns out to be too slow. But if both algorithms are similarly complex, or if the expected workload is so large that you already know you'll need the faster one, then optimizing early is a sound engineering decision that will reduce your total workload in the long run.
Thus, in general, I think the right approach is to find out what your options are before you start writing code, and consciously choose the best algorithm for your situation. Most importantly, the phrase "premature optimization is the root of all evil" is no excuse for ignorance. Career developers should have a general idea of how much common operations cost; they should know, for example,
  • that strings cost more than numbers
  • that dynamic languages are much slower than statically-typed languages
  • the advantages of array/vector lists over linked lists, and vice versa
  • when to use a hashtable, when to use a sorted map, and when to use a heap
  • that (if they work with mobile devices) "double" and "int" have similar performance on desktops (FP may even be faster) but "double" may be a hundred times slower on low-end mobile devices without FPUs;
  • that transferring data over the internet is slower than HDD access, HDDs are vastly slower than RAM, RAM is much slower than L1 cache and registers, and internet operations may block indefinitely (and fail at any time).
And developers should be familiar with a toolbox of data structures and algorithms so that they can easily use the right tools for the job.
Having plenty of knowledge and a personal toolbox enables you to optimize almost effortlessly. Putting a lot of effort into an optimization that might be unnecessary is evil (and I admit to falling into that trap more than once). But when optimization is as easy as picking a set/hashtable instead of an array, or storing a list of numbers in double[] instead of string[], then why not? I might be disagreeing with Knuth here, I'm not sure, but I think he was talking about low-level optimization whereas I am talking about high-level optimization.
Remember, that quote is originally from 1974. In 1974 computers were slow and computing power was expensive, which gave some developers a tendency to overoptimize, line-by-line. I think that's what Knuth was pushing against. He wasn't saying "don't worry about performance at all", because in 1974 that would just be crazy talk. Knuth was explaining how to optimize; in short, one should focus only on the bottlenecks, and before you do that you must perform measurements to find the bottlenecks.
Note that you can't find the bottlenecks until you have written a program to measure, which means that some performance decisions must be made before anything exists to measure. Sometimes these decisions are difficult to change if you get them wrong (for example, if you choose to write your software in JavaScript instead of C#/Java, your code will have a much lower performance ceiling, which might be fine or frustrating depending on whether you hit that ceiling and how hard it is to overcome it when it is reached). For this reason, it's good to have a general idea of what things cost so you can make reasonable decisions when no hard data is available.
How early to optimize, and how much to worry about performance, depends on the job. When writing scripts that you'll only run a few times, worrying about performance at all is usually a complete waste of time. But if you work for Microsoft or Oracle and you're working on a library that thousands of other developers are going to use in thousands of different ways, it may pay to optimize the hell out of it, so that you can cover all the diverse use cases efficiently. Even so, the need for performance must always be balanced against the need for readability, maintainability, elegance, extensibility, and so on.
Qwertie
  • 327
    Amen. Premature optimization is thrown around far too liberally these days by people who try to justify using the wrong tool for the job. If you know the right tool for the job ahead of time, then there is no excuse for not using it. – crush Jan 23 '14 at 14:42
17
Personally, as covered in a previous thread, I don't believe early optimization is bad in situations where you know you will hit performance issues. For example, I write surface modelling and analysis software, where I regularly deal with tens of millions of entities. Planning for optimal performance at design stage is far superior than late optimization of a weak design.
Another thing to consider is how your application will scale in the future. If you consider that your code will have a long life, optimizing performance at design stage is also a good idea.
In my experience, late optimization provides meagre rewards at a high price. Optimizing at design stage, through algorithm selection and tweaking, is way better. Depending on a profiler to understand how your code works is not a great way of getting high performance code, you should know this beforehand.
SmacL
  • 221
  • This is certainly correct. I guess that premature optimization is when code is made more complex / hard to understand for unclear benefits, in a way that has only local impact (design has global impact). – Paul de Vrieze Oct 17 '08 at 10:12
    It's all about definitions. I take optimization as designing and writing code to perform in an optimal manner. Most here appear to treat it as hacking about with the code once they have found it is not fast or efficient enough. I spend a lot of time optimizing, usually during design. –  Oct 17 '08 at 10:27
    Optimize the design at the start, Optimize the code at the end. – BCS Dec 19 '08 at 20:58
  • You are quite correct in your case, however for most programmers, they believe they will hit performance issues, but in reality they never will. Many worry about performance when dealing with 1000 of entities, when a basic test on the data would show that performance is fine until they hit 1000000 entities. – Toby Allen Jan 26 '13 at 15:32
    "Planning for optimal performance at design stage is far superior than late optimization of a weak design" and "late optimization provides meagre rewards at a high price" very well put! Probably not true for 97% of all systems produced, but it is for many - disconcertingly many - systems. – Olof Forshell Mar 10 '15 at 12:33
16
In fact I learned that premature non-optimization is more often the root of all evil.
When people write software it will initially have problems, like instability, limited features, bad usability and bad performance. All of these usually get fixed, when the software matures.
All of these, except performance. Noone seems to care about performance. The reason is simple: if a software crashes, someone will fix the bug and that's it, if a feature is missing, someone will implement it and done, if the software has bad performance it is in many cases not due to missing microoptimization, but due to bad design and no one is going to touch the design of the software. EVER.
Look at Bochs. It's slow as hell. Will it ever get faster? Maybe, but only in the range of a few percent. It will never get performance comparable to virtualization software like VMWare or VBox or even QEMU. Because it's slow by design!
If the problem of a software is that it is slow, then because it is VERY slow and this can only be fixed by improving the performance by a multitude. +10% will simply not make a slow software fast. And you will usually not get more than 10% by later optimizations.
So if performance is ANY important for your software, you should take that into account from the beginning on, when designing it, instead of thinking "oh yes, it's slow, but we can improve that later". Because you can't!
I know that does not really fit to your specific case, but it answers the general question "Is premature optimization really the root of all evil?" - with a clear NO.
Every optimization, like any feature, etc. has to be designed carefully and implemented carefully. And that includes a proper evaluation of cost and benefit. Do not optimize an algorithm to save a few cycles here and there, when it doesn't create a measurable performance gain.
Just as an example: you can improve a function's performance by inlining it, possibly saving a handful of cycles, but at the same time you probably increase the size of your executable, increasing the chances of TLB and cache misses costing thousands of cycles or even paging operations, which will kill performance entirely. If you don't understand these things, your "optimization" can turn out bad.
Stupid optimization is more evil than "premature" optimization, yet both are still better than premature non-optimization.
gnat
  • 21,442
  • 112
  • 288
Timo
  • 101
From a different perspective, it is my experience that most programmers/developers do not plan for success and the "prototype" is almost always becomes Release 1.0. I have first hand experience with 4 separate original products in which the classy, sexy, and highly functional front-end (basically the UI) resulted in wide-spread user adoption and enthusiasm. In each of these products, performance problems began to creep in within relatively short times (1 to 2 years) particularly as larger, more demanding customers, began to adopt the product. Very soon performance dominated the issues list, although new feature development dominated management's priority list. Customers became more and more frustrated as each release added new features which sounded great but were almost inaccessible due to performance issues.
So, very fundamental design and implementation flaws that were of little or no concern in the "proto-type" became major stumbling blocks to long-term success of the products (and the companies).
Your customer demo may look and perform great on your laptop with XML DOMs, SQL Express, and lots of client-side cached data. The production system will probably crash a burn if you are successful.
In 1976 we were still debating the optimal ways of calculating a square root or sorting a large array and Don Knuth's adage was directed at the mistake of focusing on optimizing that sort of low level routine early in the design process rather than focusing on solving the problem and then optimizing localized regions of code.
When one repeats the adage as an excuse for not writing efficient code (C++, VB, T-SQL or otherwise), or for not properly designing the data store, or for not considering the net work architecture, then IMO they are just demonstrating a very shallow understanding of the real nature of our work. Ray
Ray
There are two problems with PO: firstly, the development time being used for non-essential work, which could be used writing more features or fixing more bugs, and secondly, the false sense of security that the code is running efficiently. PO often involves optimising code that isn't going to be the bottle-neck, while not noticing the code that will. The "premature" bit means that the optimisation is done before a problem is identified using proper measurements.
So basically, yes, this sounds like premature optimisation, but I wouldn't necessarily back it out unless it introduces bugs - after all, it's been optimised now(!)
harriyott
  • 281
Since there is no problem understanding the code, then this case could be considered as an exception.
But in general optimization leads to less readable and less understandable code and should be applied only when necessary. A simple example - if you know that you have to sort only a couple of elements - then use BubbleSort. But if you suspect that the elements could increase and you don't know how much, then optimizing with QuickSort (for example) is not evil, but a must. And this should be considered during the design of the program.
m_pGladiator
  • 181
    Don't agree. I'd say never use a bubble sort. Quicksort has become a defacto standard and is well understood, and is as easy to implement as a bubble sort in all scenarios. The lowest common denominator is not that low any more ;) –  Oct 17 '08 at 08:47
    For really small numbers of items, the recursion required for quicksort can make it slower than a decent bubblesort though... not to mention that a bubblesort is quicker in the worst-case scenario of quicksort (namely quicksorting a sorted list) – workmad3 Oct 17 '08 at 08:53
  • yeah, but that's just an example how to select algorithms for different needs ;) –  Oct 17 '08 at 08:54
  • True, but I would have quicksort as my default sort. If I thought bubblesort would improve performance, this would be an optimization, not the other way around. I choose quicksort as my default because it is well understood and generally better. –  Oct 17 '08 at 09:15
  • Secure code (military types n'all) and Real time stuff never uses quick sort because of it's worst cases O(). They use Heap sort or Merge sort or whatnot. – BCS Dec 19 '08 at 20:54
    My idea of a default sort is whatever the library gives me (qsort(), .sort(), (sort ...), whatever). – David Thornley Dec 19 '08 at 21:25
  • BTW, insertion sort is just as simple as bubble sort, is never slower and often faster, so I don't know why anyone would talk about bubble sort at all. Quick sort is a little more complicated and difficult to get right (my high school class was assigned to write a quick sort... and not one of us students got it right on our first try), but now that all standard libraries have one, there's little excuse not to use it. Btw, don't write a quick sort yourself, it's too easy to write a quicksort that runs in O(N^2) time on sorted data or data with many duplicate items. – Qwertie May 01 '12 at 22:07
I believe it's what Mike Cohn calls 'gold-plating' the code - i.e. spending time on things which could be nice but are not necessary.
He advised against it.
P.S. 'Gold-plating' could be bells-and-whistles kind of functionality spec-wise. When you look at the code it takes form of unnecessary optimisation, 'future-proofed' classes etc.
Ilya Kochetov
  • 197
    I think "gold-plating" is different than optimizations. Optimizations are generally all about trying to get the most performance while "gold-plating" is about adding the "bells and whistles" (all the extra functionality) that isn't critical to the product but looks/feels cool to do. – Scott Dorman Oct 17 '08 at 09:16
I've found that the problem with premature optimization mostly happens when re-writing existing code to be faster. I can see how it could be a problem to write some convoluted optimization in the first place, but mostly I see premature optimization rearing its ugly head in fixing what ain't (known to be) broke.
And the worst example of this is whenever I see someone re-implementing features from a standard library. That is a major red flag. Like, I once saw someone implement custom routines for string manipulation because he was concerned that the built-in commands were too slow.
This results in code that is harder to understand (bad) and burning a lot of time on work that probably isn't useful (bad).
jhocking
  • 2,641
Most of those who adhere to "PMO" (the partial quote, that is) say that optimizations must be based on measurements and measurements cannot be performed until at the very end.
It is also my experience from large systems development that performance testing is done at the very end, as development nears completion.
If we were to follow the "advice" of these people all systems would be excruciatingly slow. They would be expensive as well because their hardware needs are much greater than originally envisaged.
I have long advocated doing performance tests at regular intervals in the development process: it will indicate both the presence of new code (where previously there was none) and the state of existing code.
  • The performance of newly-implemented code may be compared with that of existing, similar code. A "feel" for the new code's performance will be established over time.
  • If existing code suddenly goes haywire you understand that something has happened to it and you can investigate it immediately, not (much) later when it affects the entire system.
Another pet idea is to instrument software at the function block level. As the system executes it gathers information on execution times for the function blocks. When a system upgrade is performed it can be determined what function blocks perform as they did in the earlier release and those that have deteriorated. On a software's screen the performance data could be accessed from the help menu.
Check out this excellent piece on what PMO might or might no mean.
I suppose it depends on how you define "premature". Making low-level functionality quick when you're writing is not inherently evil. I think that's a misunderstanding of the quote. Sometimes I think that quote could do with some more qualification. I'd echo m_pGladiator's comments about readability though.
The answer is: it depends. I'll argue that efficiency is a big deal for certain types of work, such as complex database queries. In many other cases the computer is spending most of its time waiting for user input so optimising most code is at best a waste of effort and at worst counterproductive.
In some cases you can design for efficiency or performance (perceived or real) - selecting an appropriate algorithm or designing a user interface so certain expensive operations happen in the background for example. In many cases, profiling or other operations to determine hotspots will get you a 10/90 benefit.
One example of this I can describe is the data model I once did for a court case management system which had about 560 tables in it. It started out normalised ('beautifully normalised' as the consultant from a certain big-5 firm put it) and we only had to put four items of denormalised data in it:
  • One materialised view to support a search screen
  • One trigger-maintained table to support another search screen that could not be done with a materialised view.
  • One denormalised reporting table (this only existed because we had to take on some throughput reports when a data warehouse project got canned)
  • One trigger-maintained table for an interface that had to search for the most recent of quite a large number of disparate events within the system.
This was (at the time) the largest J2EE project in Australasia - well over 100 years of developer time - and it had 4 denormalised items in the database schema, one of which didn't really belong there at all.
Premature optimization is not the root of ALL evil, that's for sure. There are however drawbacks to it:
  • you invest more time during development
  • you invest more time testing it
  • you invest more time fixing bugs that otherwise wouldn't be there
Instead of premature optimization, one could do early visibility tests, to see if there's an actual need for better optimization.
gnat
  • 21,442
  • 112
  • 288
