I've just started using ReSharper (for C#) and I kind of like its code smells finder, it shows me some things about my writing that I meant to fix a long time ago (mainly variable naming conventions).
It caused me to reconsider some of my naming conventions for methods and instance variables. ReSharper suggests that instance variable be lower camel case and begin with an underscore. For a while I meant to make all my local variables lower camel case but is the underscore necessary? Do you find it comfortable? I don't like this convention but I also haven't tried it yet, what is you opinion of it?
The second thing it prompted me to re-evaluate is my naming conventions for GUI event handlers. I usually use the VS standard of ControlName_Action and my controls usually use hungarian notation (as a suffix, to help clarify in code what is visible to the user and what isn't when dealing with similarly named variable) so I end up with OK_btn_Click(), what is your opinion of that? Should I succumb to the ReSharper convention or there are other equally valid options?
