320
Often, in libraries especially, packages contains classes that are organized around a single concept. Examples: xml, sql, user, config, db. I think we all feel pretty naturally that these packages are correct in the singular.
com.myproject.xml.Element
com.myproject.sql.Connection
com.myproject.user.User
com.myproject.user.UserFactory
However, if I have a package that actually contains a collection of implementations of a single type - such as tasks, rules, handlers, models, etc., which is preferable?
com.myproject.tasks.TakeOutGarbageTask
com.myproject.tasks.DoTheDishesTask
com.myproject.tasks.PaintTheHouseTask
or
com.myproject.task.TakeOutGarbageTask
com.myproject.task.DoTheDishesTask
com.myproject.task.PaintTheHouseTask
Nicole
  • 28,111
  • 95
  • 143
Use the plural for packages with homogeneous contents and the singular for packages with heterogeneous contents.
A class is similar to a database relation. A database relation should be named in the singular as its records are considered to be instances of the relation. The function of a relation is to compose a complex record from simple data.
A package, on the other hand, is not a data abstraction. It assists with organization of code and resolution of naming conflicts. If a package is named in the singular, it doesn't mean that each member of the package is an instance of the package; it contains related but heterogeneous concepts. If it is named in the plural (as they often are), I would expect that the package contains homogeneous concepts.
For example, a type should be named TaskCollection instead of TasksCollection, as it is a collection containing instances of a Task. A package named com.myproject.task does not mean that each contained class is an instance of a task. There might be a TaskHandler, a TaskFactory, etc. A package named com.myproject.tasks, however, would contain different types that are all tasks: TakeOutGarbageTask, DoTheDishesTask, etc.
Matthew Rodatus
  • 7,551
  • 32
    For a similar question, see http://english.stackexchange.com/q/25713. A _category_ is analogous to the singular and a _type_ is analogous to the plural. – Matthew Rodatus May 17 '11 at 15:11
    The very [link](http://download.oracle.com/javase/6/docs/api/java/beans/package-summary.html) you provided shows an exception to this rule. `beans` is plural, however `java.beans` contains all kind classes related to JavaBeans. – hellodanylo Sep 18 '12 at 12:11
  • Good answer, but I don't agree with the database relation logic. Relations in an ERD are singular because they are showing relationships between entities. Tables are a physical implementation of the relations, and they hold multiple rows, and should thus be plural IMO. The answer to "what is in this table?" is "users" not "user". Granted, it seems that singular naming is more common in the enterprise world (C#, Java) than it is in communities like Ruby, Python, Javascript, and PHP. – ryeguy May 21 '13 at 20:49
    So essentially name a package plurally if it has classes that really do serve different puprposes or whatever, but which are just similarly-themed, and name a package singularly if it just contains classes that heavily focus on coming together as a sort of "meta-class" for a single purpose? – Panzercrisis Oct 22 '13 at 18:09
  • Also AS3 wouldn't be an exception to the rule, would it? – Panzercrisis Oct 22 '13 at 18:11
    @SkyDan's comment points out something very important that is being entirely overlooked here. It appears to me that the plural naming of "java.beans" was actually a mistake, and it should instead have been named "java.bean", singular. – Vicky Chijwani Nov 21 '15 at 22:14
    @VickyChijwani @SkyDan since JavaBeans™ is a trademark, they probably wanted to keep the name as-is to refer to the technology itself, and hence they used `java.beans`. – Hejazi Jul 28 '16 at 07:52
  • From where that quote is taken? "Use the plural for packages with homogen..." – Rostislav V Mar 15 '19 at 08:19
  • Should i name a package 1- **helper** or **helpers**. 2- **utility** or **utilities** ? – Arash Jan 25 '20 at 19:51
This probably depends on a specific language. In .NET (C#) it most definitely should be a plural if a namespace-type name collision is likely (the type name expected but namespace found error). I've dealt with this, it's not pleasant and results in over-qualifying type names all over the code. Example.
Den
  • 4,827
  • 32
IMHO
It depends on whether the package represents a container or a collection.
  • com.my.proj.core.view <- collection
  • com.my.proj.views <- container
  • com.my.lib.task
  • com.my.proj.tasks
  • com.my.lib.widget
  • com.my.proj.widgets
IMHO
  • jaba.beans should contains many real beans.
  • jaba.bean should be a collection with many 'bean relative' classes in it.
I prefer singular, unless it 'must be' plural.
Singular may not always be 'best' but always 'right'.
kmrk
Naming things is one of the famous three hard problems.
Just as names of files are part of the user interface, and so should not contain characters like U+0004 or nonbreaking spaces, names of variables are part of the "developer interface", and should be chosen to increase understanding, reduce friction and ease development.
In this sort of situation one should consider the following, in this order:
  • Don't cause confusion
  • Comply with local policy if there is one
  • Follow best practices
  • Use your own preference
In this case I don't see it matters very much
The time you are spending on making the decision is better spent on other things.
Just pick one and move on.
Ben
  • 853
