Just read a presentation about using Python for Scientific Computing. I am currently using MATLAB (student license FTW, which will expire when I graduate soon).
So I was wondering how matured SciPy and NumPy are with respect to relying on them for all the Scientific Computing I need to do. The advantage is that it's free. I am mainly focused on Signal Processing, Audio, Acoustics kind of computing.
I can imagine that the NumPy and SciPy projects are evolving with respect to the support for more complex techniques. So, how fast are they evolving, are there large communities behind them?
Finally, are there other solutions?
notthetup
  • 211
    if that presentation is online, can you point me to it? Thanks. – temptar May 09 '11 at 09:49
    NumPy and SciPy are mature. Matlabs lacks many things that Python has. Why not have them both? The syntax will remain 95% the same. http://www.vetta.org/2008/05/scipy-the-embarrassing-way-to-code/ – Job May 09 '11 at 12:27
  • @temptar http://lac.linuxaudio.org/2011/download/python_for_audio_signal_processing.pdf – notthetup May 09 '11 at 15:42
  • I also just found out about Julia.. Which is something I'm gonna try out next.. http://julialang.org/ – notthetup May 15 '13 at 03:01
You should look into Sage; it is the open source alternative to Matlab, Mathematica and others. The core language is python, so you can use all python libraries natively, and it has bindings for most free and non-free mathematical software so you can use Matlab, Mathematica and others inside it. It has a lot of support from within the mathematical community and its lead developer is very highly thought of and committed to the project.
    Sage is just a wrapper for lots of other tools. Unless you're doing advanced mathematics, you're probably better off using those tools directly. – endolith May 14 '13 at 13:54
  • (I was referring to things like http://andrejv.github.io/wxmaxima/ rather than using maxima through sage, which is much clunkier) – endolith Apr 18 '14 at 02:06
In short: Python is a much better language than Matlab, and has more complete general-language features, but Matlab has a more complete set of scientific computing tools than Python.
Octave also has more complete scientific tools than Python, and is a closer language to Matlab if you're already familiar with it, but also shares the language's flaws. Octave and SciPy are free, Matlab is very not free.
Me too, and I've found SciPy lacking. Some examples:
  • Documentation is poor or non-existent for many functions
  • Filter design tools convert to transfer function representation internally, so higher-order filters suffer from numerical error problems. (fixed)
  • Other functions like freqs only accept tf representation, which, again, causes numerical error problems.
  • Doesn't support filters in second-order-sections representation
  • FFTs are not as fast
  • Lots of functions from Octave/Matlab don't exist yet in SciPy, and can't be directly translated from Octave because of GPL vs BSD licensing
But I still prefer SciPy, because the language is much nicer to use, and does most of what I need. It's free and open-source, and actively developed, and you can contribute easily just by pushing "Edit" on Github. Since I'm primarily using this to learn and practice signal processing, I don't consider it a problem that I have to contribute documentation (old vs new) or improvements myself. That's the sort of thing I want to learn anyway.
Also, while in the process of trying to fix some of these things, I've uncovered some flaws in Matlab's filter design tools: 1 2 So open-source development with lots of test cases has its advantages, too.
endolith
  • 152
Under the "Other Solutions" topic: Have a look, also, at Octave and SciLab. These are usually close enough to Matlab to make translation of scripts fairly painless.
However, moving to Python seems like a good idea, too! There seems to be some work on integrating with Python in SciLab.
Peter K.
  • 3,828
Also under "other solutions":
I'm very much on the Python-for-science bandwagon, but my free/open source "I don't have a Matlab license" substitute often ends up being R instead.
I find it somewhat frustrating syntax-wise (indices start at 1? assignment is done "varname <- value"? Come on ...), but it is fairly ubiquitous at least in my scientific discipline, ecology, where scientists may not be generally programming-literate (& hence bewildered when I send them a Python module), but do use Matlab/R-type statistical packages - I have ported Matlab code to R for signal processing-type applications (not personally for audio in specific, but I do know bird researchers using it for that).
Beekguk
  • 311
Python with SciPy/NumPy is a pretty mature platform for scientific computing.
The one place where arguably it's pretty weak is upper level statistics - I haven't been terribly impressed with the offerings in that area, and despite my deep love for Python have not adopted it as a statistics workbench at all. The good news is you can get around this by calling R from Python.
With the addition of R (or another statistics language - the only other one I'd consider unless you really had a specific requirement would be SAS, and that's pricey), the combination of the two is a very solid, open-source and actively developing platform. R does work a little bit differently than most programming languages, because of a slightly different philosophy. It's designed for how statisticians think, rather than programmers. Hence things like indices starting at one - that's often because that's also "Subject 1", "ID0001" etc.
Fomite
  • 2,616
