I have done a middle sized Java project (ca. 300 classes) with multiple Maven modules with my domain classes auto generated (ca. 100 classes) from a DSL done with the superb Eclipse Xtext project and I would do it again :)
Here I will give hints how I (till today) successfully come around the cumber stones mentioned:
Since my project was build with maven I used the maven way to handle auto generated code, that means even my xtext dsl and generator project is handled by maven and at every full build I create all generated code new (as it should be). See:
building xtext projects with maven tycho. So in my project I only have to do a "maven package".
I divided my generated code and my hand typed via inheritance (i dislike the c# way to span a class in multiple files):
/* Generated code, will not be in revision control */
abstract class AbstractFoo {
//getters and setters
//collection accessors
//helper methods like toString equals hashCode
/* Generated one time, will be in revision control */
class Foo extends AbstractFoo{
//business logic if needed
With an Xtext generator project it is possible to define files that should only be created one time, so my concrete classes i have created only one time and kept then in my Git repo. The generated concrete class is nothing more then a 2 liner so you can use the class even if you add no methods to it.
For the two templates (abstract and concrete) I have created two test class templates one for the abstract class and one for the concrete, but the concrete test class is again only just generated one time and a two liner.
In my maven module where the generated code is located i have used this layout (almost the maven conventions):
myproject/src/main/java -> concrete generated classes, one time
myproject/src/test/java -> generated tests, one time
myproject/target/generated-sources/mydsl -> abstract generated classes, always
myproject/target/generated-sources/mydsltests -> auto generated tests, always
So when i change the template only the template in the Xtext generator project will change in my revision control, since I do not include the (always) generated sources.
So I would suggest you to give Eclipse Xtext a try, when you start with the example projects you will have something prototypish running in less then one hour.
