12
I'm on a TDD project, so I try to stick as much as possible to the good pratices involved with that kind of development. One of them is avoiding as much as possible static and global.
I'm facing this problem: I've an object "article" that can have "options" (additionnal "micro-articles") linked to it.
I can't figure out how to have a good approach that will not be counter productive or generate too much queries because I would be in a situation where everything is so decoupled that I'll basically need to make 1 query per object.
From my actual perspective, I see 3 options:
1) Build inside article:
class Article
    public function getArrOption(){
        //Build an array of Options instance.
        //return an array of Options.
Pro: Straight forward
Const: Maintenability: The article object now contain the building logic for the Option object. This will probably lead to code duplication.
2) Using an optionFactory
class Article
        return OptionFactory::buildFromArticleId($this->getId());
Pro: Building logic is not out of the Article class
Const: I'm breaking the "static is hard to mock" rule, making my Article class hard to test.
3) Separate all logics.
//Build the array of Option instance in a controller somewhere, using a Factory:
$arrOption = OptionFactory::buildFromArticleId($article->getId());
Pro: Article only handle his own responsability, and doesn't care about his "father" link to the options. Things are really decoupled
Const: Will require more code inside the Controller everytime I'll need to access the Options. That mean that I should never use a Factory inside an object, and that sound kind of utopic to me...
What's the best way to go ? ( Did I've miss something ? ) thanks.
Edit:
Not to mention that if I can't call factory inside class, I can basicaly never use the lazy initialization pattern too...
yannis
  • 39,547
  • 40
  • 183
  • 216
FMaz008
  • 413
  • I'm not sure if it's pertinent, but I'm coding in PHP, so the "application" is state less. We must reload all the data between each page if it's not stored in a session cookie. That mean that we can't *pre-load* everything like in an application language. – FMaz008 Apr 07 '11 at 19:49
  • @job: Well it's because a static call **inside** a method is mostly impossible to replace when unit testing. The goal is to use dependency injection. But a factory is usually static, so it can't be injected. – FMaz008 Apr 07 '11 at 19:51
  1. Static isn't "bad", it's unmockable. You can still use it where mocking doesn't make sense.
  2. That isn't a Factory pattern, it looks like a Repository pattern, although it may not be. Factory is where you have multiple classes with the same interface / base class and you want to separate out the logic which decides which class to return. Repository gets the data from its repository, abstracting out the implementation of that repository (the Article doesn't need to know if its options are stored in the same DB, another one, an XML file, a CSV file, whatever).
  3. You've ignored the possibility of giving the Article class an ObjectFactory (or Repository, or whatever) object in the constructor on which it can call the buildFromArticle method.
My PHP is rusty, but I think it looks like this:
class Article
    private $_option_repository;
    public function __construct($option_repository) {
        $_option_repository = $option_repository;
        return $_option_repository->buildFromArticleId($this->getId());
I think this fulfils all of your pros above.
pdr
  • 53,387
  • 137
  • 224
  • So it's ok to have instances of Factory/Repository/Mapper ? I'll need a dependency container or something because if we need to inject all the factory/repository/mapper for all the possible object that can be returned by an object, that quickly made a lot. ( Article -> OptionGroup -> Option -> Article , etc.. ) – FMaz008 Apr 07 '11 at 20:09
    It's more than ok, it's preferable. I generally reserve static use to removing repeated code, where it's small enough to be tested in multiple classes. And yes, an IOC / DI Container is going to make your life a lot easier. Use one. – pdr Apr 07 '11 at 20:12
Here's a quote from paper that argues that you never need static methods, that abstract factories have been demonstrated to be confusing, and suggests a slight language change towards dependency injection as the solution.
Tight coupling between instances and their classes breaks encapsulation, and, together with the global visibility of static methods, complicates testing. By making dependency injection a feature of the programming language, we can get rid of static methods altogether. We employ the following semantic changes:
(1) Replace every occurrence of a global with an access to an instance variable;
(2) Let that instance variable be automatically injected into the object when it is instantiated.
"Seuss: Decoupling responsibilities from static methods for fine-grained configurability"
Wayback Machine Link
nes1983
  • 149
    While this link may answer the question, it is better to include the essential parts of the answer here and provide the link for reference. [Link-only answers](http://meta.stackoverflow.com/tags/link-only-answers/info) can become invalid if the linked page changes. – gnat Dec 21 '12 at 10:54
