Have you ever been developing something and just came to a point where you think that this is rubbish, the design is bad and although I will lose time it will be better to just start all over again?
What should you consider before making this step? I know it can be drastic in some cases, is it best to just totally ignore what you did before, or take some of the best bits from it? Some real life examples would be great.
kyndigs
  • 369
    I do it far too often - it's a luxury I have, only having worked on personal projects for the last six months or so. – sevenseacat Mar 04 '11 at 10:49
  • I would go so far as to say that you haven't really gotten into programming until you start throwing away so much work that you actually begin pondering how to reduce or eliminate these episodes. I find reading up on design patterns or taking entire days to plan out the design on paper before coding helps a lot. – Jog Jul 19 '14 at 03:53
11 Answers11
15
No.
I have discarded bad software without a second thought.
I rarely think I will "lose time" by discarding rubbish software.
It's rubbish. Discard it. It doesn't matter how precious it may have seemed because some effort has been invested in it. If it's rubbish, then all further effort is simply creating more cost not creating new value.
The revised design.
How to preserve the data.
False. Rubbish is rubbish. Discard it early and often. It's not drastic when the software is rubbish.
That's imponderable. It depends on specifics of what you did before and how bad it was.
Our current web site uses a trailing application_# naming scheme. The number is the major version number. When we make a database change, we -- essentially -- discard the entire previous version of the application. It's tied to the database pretty tightly.
We don't "incrementally" change the database. We discard the previous version and move forward.
Two of the modules is on major version 3. Two previous discards of rubbish software.
One of the modules is on major version 2. The previous had to be discarded as unworkably bad.
These are discards of the previous version and migration of the data to new tables with a different structure (hence the major version number).
We do it all the time. The quicker you get rid of rubbish software the more effective you become.
S.Lott
  • 45,264
  • 90
  • 154
    +1 Especially for "the quicker you get rid of rubbish software the more effective you become" – Gary Mar 04 '11 at 11:21
  • +1: I agree that sometimes you have to throw away and rewrite. I had positive experiences with this a few times: spent days trying to find bugs in messy code and then rewrote the whole thing in a few hours and it was working. – Giorgio Apr 13 '13 at 19:22
14
I do not think it is wise. Joel thinks so too. Mature code is brittle and tend to have many hacks. But usually mature code tend to be correct too. It is foolish to discard correctness in favor of design purity. Design purity means nothing to the end user, correct software means a lot.
If you feel the design is rubbish, identify the most rubbish part and mend it. To put it in another way, start mending broken windows instead of building a brand new house. The advantage of fixing bit by bit, is that you always have a working system. You have test cases (hopefully) to rely upon to verify correctness. It may take longer than building it from scratch, but you will always have correct software to ship.
aufather
  • 4,449
  • 26
  • There is a good counter-example to Joel's advice: Firefox. – LennyProgrammers Mar 04 '11 at 11:20
    +1 However, sometimes the mature code doesn't work and is riddled with obscure bugs. In that situation throwing the rubbish away and rewriting seems to be the better solution. Determining that tipping point is non-trivial. – Gary Mar 04 '11 at 11:24
    Mature code is like mature cheese: it tastes better but boy does it smell. – biziclop Mar 04 '11 at 11:35
    Firefox is actually a very good example of why rewrites are bad. The mozilla project took years to deliver a competitive browser, and in that time netscape utterly and totally failed. Even then, the resulting product (mozilla suite) was burdened by design problems (both UI and technical), and it took the firefox project until they got things on track. Firefox wasn't a rewrite, it was a refactoring of the mozilla codebase. – Joeri Sebrechts Mar 04 '11 at 12:07
  • I would say firefox shows why it is good. It looked bad when Joel wrote it because Netscape had disappeared off the map and Firefox had not shown itself up yet as a valid competitor to IE which was dominant. But now it is here, most people use firefox. – CashCow Mar 04 '11 at 12:46
    +1 You can fix/rewrite bit by bit until eventually you have a whole new application. Martin Fowler calls this a [strangler application](http://www.martinfowler.com/bliki/StranglerApplication.html). By the way, for a better counter-example to Joel's article why not choose Windows NT? – MarkJ Mar 04 '11 at 14:01
  • @Joeri Sebrechts: Netscape was a business failure before they released Mozilla. To me Firefox is a huge success. It just depends on the time frame, see also http://notes-on-haskell.blogspot.com/2007/08/rewriting-software.html Also massive refactoring is rewriting in my book. – LennyProgrammers Mar 04 '11 at 14:10
  • The question was not about mature software in particular. – David Thornley Mar 04 '11 at 16:55
    Joel's piece (while an extremely worthwhile read) is really not relevant to this question. Joel is talking about rewriting *existing, working software* because you think you can do a better job if you start from scratch. Kyndigs was asking about the situation where you are developing something, and feel you should abandon your design and backtrack. Completely different situations. – Carson63000 Mar 04 '11 at 20:48
  • @Lenny: I think we're saying the same thing. Clearly firefox is a very successful project, and clearly it is a failed rewrite. When you consider firefox as a separate project from what netscape was doing, they're a success story. Viewed as a rewrite, they failed to deliver what netscapees hoped. To be clear: firefox is not the reason netscape failed, netscape is the reason netscape failed. Firefox just didn't do anything to save netscape, demonstrating that rewrites can't save a dying business. – Joeri Sebrechts Mar 04 '11 at 22:26
This happens all the time.
A criticism of the Waterfall Model is formulated as “Many of the [system's] details only become known to us as we progress in the [system's] implementation. Some of the things that we learn invalidate our design and we must backtrack.”
You should be careful though to know this effect from just being frustrated that you don't reach your goal as soon/easily as you've hoped.
LennyProgrammers
  • 5,649
  • Good comment, but I am not sure about how often this happens. Many of the people who design the software are extremely smart, it would be reasonable to expect that they don't often make design mistake (I read that software architects don't write lot of code, so they might make coding mistakes). About implementation/coding mistakes, there are many super stars, so I think a good combination would reduce mistakes that require start all over to some level that is not really 'all the time'. Not sure if I have something that needs to be corrected here. – InformedA Jul 19 '14 at 05:23
I have been in this field for over thirty years, and I still believe that planning to throw one away is still a solid software engineering practice. Eighty-percent of a useful system's lifetime is spent in maintenance mode. Brittle systems are more expensive to maintain than non-brittle systems. However, one should also be mindful of another Brooksism; namely, "The Second-System Effect."
bit-twiddler
  • 2,648
First thing I normally do in such a situation - take a deep breath and have a break.
Have some fun with friends, go to gym, visit a concert - anything to free my brains from programming. Then look at the project next day. If it's still bad, start it all over.
But don't remove old repositories. I find some handy tricks even in my earliest and most noobish code. And of course it will remind you in future how much you learned.
Nikita Barsukov
  • 1,265
I think this happens very often, and there are ways to beat this. That's precisely the reason why prototypes exist. And beating them is easier too, you only need to get a bit organized and a little disciplined.
The way to look at it is, programming is fundamentally all about problem solving. So you must start out with a clearly defined problem on paper. No ambiguous definitions allowed. Once you do that you must decide what are the probable solutions to it on paper. Keep planning minimal but sufficient.
After this begin with the first set of features, release them, test them. Take feedback, start with the next set of features. Every time something goes wrong you know where to correct it. I think this is what we call as agile, albeit there is more to agile.
Starting a large project as whole going half way and then discovering things going wrong is pretty much expected.
kamaal
  • 1,125
I believe in the "third implementation" law. First implementation is always a prototype-quality. Second round of rebuilding from scratch addresses the most basic issues found in a prototype and finally shows fundamental design flaws. That flaws are addressed by a third reimplementation-from-scratch. It should not necessarily be your own re-implementation, a competing system may address your issues as well.
SK-logic
  • 8,497
  • Wasn't "build one to throw away" originally proposed by Fred Brooks in the classic book The Mythical Man Month? And, 25 years later in the silver anniversary edition of the book, didn't he describe that as the biggest mistake in the whole book?? – MarkJ Mar 04 '11 at 14:04
  • Nowdays it is much easier to throw things away. Code is more dense, and it is easier to refactor parts of the old code into reusable components. My personal favourite approach is to use DSLs - then I can throw away and reimplement a DSL from scratch, keeping the high level declarative code written in that DSL from the previous iteration. – SK-logic Mar 04 '11 at 14:09
  • @MarkJ, "Plan to Throw One Away" is still an integral part of the Anniversary Edition of the Mythical Man-Month. – bit-twiddler Mar 04 '11 at 15:55
If it is so bad that fixing bugs and adding new features is unacceptably slow, you have to do something. Otherwise, don't leap into action yet.
Either way, it's worth making a plan.
You have to start out with declaring what you are trying to achieve and what is an acceptable level of success. Otherwise rewriting might descend into an endless cycle of refinement of increasingly unimportant bits of code.
The next step is to sketch up a design that fits the previously established criteria.
Then you have to try to figure out how to break down the changes into smaller steps so that you don't have to stop everything for a year while you're busy rewriting everything from scratch. If the original system's modular enough and the modules are at least laid out correctly, you can almost certainly find a way.
Refine your design based on the result of the previous step and check if it still meets the requirements.
If the situation is really bad, you can start to implement it, if it isn't, file it away as a plan for the future.
biziclop
  • 3,351
If it's something with a bad design or implementation, it will make you lose more time than if you do it properly.
Every small change that you try to do will take longer than needed because of bad dependencies, isolation, coupling, etc.
If you do it from scratch, you do things faster, better, easier, your morale will go up and your productivity will go up too!
You have to think about one thing first: rebuild it as a whole or a subpart of the system? The latter is easier, faster and less risky. After one part, you choose another one to improve and keep going until you've got something good! The former might produce better/faster results but you also increase the chances of getting stuck somewhere and not being able to do it all, wasting a big amount of time!
When I was doing my master thesis I completely rebuilt my application three times - which wasn't the main point of the thesis - but these changes were totally worthy!
Each time I did it all over again, I learned something new, I improved something, I realized something could be done better the next time, etc.
It took me a lot of time (specially because I was doing these improvements by myself, under my responsibility - if things would have gone wrong, it would have been my problem and my time lost).
If the code was written properly with tested units that are known to work, you can keep those parts safe in the knowledge that they do work, and use it when you need it.
It may be possible to decouple it enough to extract the bits you need as usable.
CashCow
  • 1,610
Throwing everything away is usually a bad idea. Rewriting parts of the system may be a good idea. Refactoring is often a good idea.
The way I see it, the question is not whether the code is good or not. Code you wrote more than a week ago is always a terrible mess because you have since learned something new which you wish you had used.
The question is whether the tech debt you've accumulated is making it hard to get work done. If your system is hard to run or changes are harder than they should be, that means you probably need to fix something. But unless things are difficult across the board, don't rewrite everything. Just rewrite the parts that are causing you pain.
azani
  • 159
