74
We use compilers on a daily basis as if their correctness is a given, but compilers are programs too, and can potentially contain bugs. I always wondered about this infallible robustness. Have you ever encountered a bug in the compiler itself? What was it and how did you realize the problem was in the compiler itself?
...and how do they make compilers so reliable?
blueberryfields
  • 13,200
  • 51
  • 87
EpsilonVector
  • 10,763
  • 56
  • 103
    Well, they compile the compiler in it... – Michael K Feb 25 '11 at 16:06
    They aren't infallible. There are compiler bugs - it's just that they are very rare. – ChrisF Feb 25 '11 at 16:07
    Bugs become rarer as you descend the code stack: application bugs are more common than compiler bugs. Compiler bugs are more common than CPU (microcode) bugs. This is actually good news: can you imagine if it were the other way around? – Fixee Feb 25 '11 at 17:39
  • You might learn something by observing how a compiler that *does* have a lot of bugs (like sdcc!) is different from a compiler like gcc which is much more robust and reliable. – Ben Jackson Feb 25 '11 at 21:03
  • I had a compiler bug bite me once, it messed up some floating point code in a really weird way. Can't remember the details, but I looked at the code it produced and thought: WTF! – Skizz Feb 25 '11 at 21:16
    [VC++6 had a bug.](http://stackoverflow.com/q/4075276/365102) – Mateen Ulhaq Feb 26 '11 at 00:03
  • @muntoo: I remember crashing it through the usage of local static variables - "compiler encountered an error". Had to reorganize my code to make it compilable. –  May 05 '11 at 08:06
    "We use compilers on a daily basis ..." which might mean that any bugs have long ago been found, reported & corrected – Mawg says reinstate Monica Oct 23 '18 at 14:28
  • The most reliable compiler I find to be the Delphi compiler. Some C++ compilers are also more reliable than others, but generally the C++ compilers are just unreliable (3077 in gcc? come on!) https://gcc.gnu.org/bugzilla/buglist.cgi?component=c%2B%2B&limit=0&order=bug_status%2Cpriority%2Cassigned_to%2Cbug_id&product=gcc&query_format=advanced&resolution=--- – Gabriel Oct 31 '19 at 11:08
  • @Ultralisk To be fair, it lists all non-resolved *issues*, which includes invalid ones, feature-requests, and potentially duplicates. Also, whether a bug in an experimental feature should count full is up to debate. – Deduplicator Mar 19 '20 at 16:15
  • @Deduplicator - when speaking about bugs: even if half are duplicates (I doubt), 1500 is a huuuuuuuge number. – Gabriel Mar 19 '20 at 16:19
19 Answers19
102
They get tested thoroughly via usage by thousands or even millions of developers over time.
Also, the problem to be solved is well defined (by a very detailed technical specification). And the nature of the task lends itself easily to unit / system tests. I.e. it is basically translating textual input in a very specific format to output in another kind of well defined format (some sort of bytecode or machine code). So it is easy to create and verify test cases.
Moreover, usually the bugs are easy to reproduce too: apart from the exact platform and compiler version info, usually all you need is a piece of input code. Not to mention that the compiler users (being developers themselves) tend to give far more precise and detailed bug reports than any average computer user :-)
Péter Török
  • 46,427
  • 160
  • 185
    Plus much of the compiler code can probably be proven correct. – biziclop Feb 25 '11 at 16:10
  • @biziclop, good point, this is another consequence of the special nature of the task. – Péter Török Feb 25 '11 at 16:19
  • The first complete compiler was written in 1957 for the FORTRAN language by John Backus. So, you see, compiler technology is over 50 years old. We have had quite some time to get it right even though, as others point out, compilers do have bugs. – leed25d Feb 25 '11 at 16:48
  • @biziclop, in fact, some components like lexers and parsers can even be autogenerated from a grammar, which again lowers the risk of bugs (provided the lexer/parser generator is robust - which they usually are, for much the same reasons listed above). – Péter Török Feb 25 '11 at 17:32
    @Péter: Lexer/parser generators seem to be rather rare in the more widely used compilers - most write lexer and parser by hand for various reasons, including speed and lack of a sufficiently smart parser/lexer generators for the language in question (e.g. C). –  Feb 25 '11 at 17:39
  • I think languages like C# were already fairly reliable by version 1.0, before it was tested by thousands of devs. Certainly compiler reliability wasn't one of the complaints of the language at the time. – Rei Miyasaka Feb 25 '11 at 21:33
  • @Rei, however, as others pointed out, even the C# 1.0 compiler was built upon the vast knowledge (and maybe even some of the code?) accumulated during decades of development of earlier compilers, most notably for C++. – Péter Török Feb 26 '11 at 12:51
  • @Péter the code's still from scratch. – Rei Miyasaka Feb 26 '11 at 17:23
    Interestingly, CompCert, the proven-correct C compiler, actually did have detectable lexer bugs, because that was one of the few parts that was not initially formally verified. http://www.cs.utah.edu/~regehr/papers/pldi11-preprint.pdf – Phil Miller Aug 30 '14 at 20:51
70
In addition to all the great answers so far:
You have an "observer bias". You don't observe bugs, and therefore you assume that there aren't any.
I used to think like you do. Then I started writing compilers professionally, and let me tell you, there are lots of bugs in there!
You don't see the bugs because you write code that is just like 99.999% of all the rest of the code that people write. You probably write perfectly normal, straightforward, clearly correct code that calls methods and runs loops and doesn't do anything fancy or weird, because you're a normal developer solving normal business problems.
You don't see any compiler bugs because the compiler bugs aren't in the easy-to-analyze straightforward normal code scenarios; the bugs are in the analysis of weird code that you don't write.
I on the other hand have the opposite observer bias. I see crazy code all day every day, and so to me the compilers seems to be chock full of bugs.
If you sat down with the language specification of any language, and took any compiler implementation for that language, and really tried hard to determine whether the compiler exactly implemented the spec or not, concentrating on obscure corner cases, pretty soon you'd be finding compiler bugs quite frequently. Let me give you an example, here's a C# compiler bug I found literally five minutes ago.
static void N(ref int x){}
N(ref 123);
The compiler gives three errors.
  • A ref or out argument must be an assignable variable.
  • The best match for N(ref int x) has invalid arguments.
  • Missing "ref" on argument 1.
Obviously the first error message is correct and the third one is a bug. The error generation algorithm is trying to figure out why the first argument was invalid, it looks at it, sees that it is a constant, and does not go back to the source code to check whether it was marked as "ref"; rather, it assumes that no one would be foolish enough to mark a constant as ref, and decides that the ref must be missing.
It's not clear what the correct third error message is, but this isn't it. In fact, it is not clear if the second error message is correct either. Should overload resolution fail, or should "ref 123" be treated as a ref argument of the correct type? I'll now have to give it some thought and talk it over with the triage team so that we can determine what the correct behaviour is.
You've never seen this bug because you would probably never do something so silly as to try to pass 123 by ref. And if you did, you probably wouldn't even notice that the third error message is nonsensical, since the first one is correct and sufficient to diagnose the problem. But I do try to do stuff like that, because I'm trying to break the compiler. If you tried, you'd see the bugs too.
Eric Lippert
  • 45,799
  • 87
  • 126
    Good error messages after the first one are very hard to do. –  Feb 28 '11 at 23:08
  • Sureöy there must be energy better spent then making compilers completely "fool"-proof :) – Homde Feb 28 '11 at 23:33
    @MKO: Of course. Lots of bugs don't get fixed. Sometimes the fix is so expensive and the scenario is so obscure that the cost isn't justified by the benefits. And sometimes enough people have come to rely on the "buggy" behaviour that you have to keep maintaining it. – Eric Lippert Mar 01 '11 at 07:12
  • mmm...bugs which end up in error messages are "fine". It's always possible to fiddle the code a little bit to make it work. What about bugs in which the compiler *accepts* the source code and produce "wrong" assmebly output. That's scary – Gianluca Ghettini May 28 '16 at 08:40
  • Are you really saying 99.999% of the code people write is "clearly correct"? My experience is pretty much the opposite. – aij Apr 19 '17 at 18:53
    @aij: Correct in the sense of "clearly legal C# code". For example, have you ever written a program containing an interface that inherited two interfaces where one interface had a property and the other had a method of the same name as the property? Quick, without looking at the spec: *is that legal*? Now suppose you have a call to that method; *is it ambiguous*? And so on. People write code that doesn't do what they mean all the time. But only rarely do they write code where you'd have to be a spec expert to say whether it is even legal C#. – Eric Lippert Apr 19 '17 at 19:59
  • @aij: This scenario comes to mind of course because the C# 3 compiler had a bug in cases where you had an interface that inherited both a property and a method of the same name, and overload resolution did not correctly report the ambiguity error required by the specification. But since 99.999% of C# programmers will never get into that situation in the first place, and would not know the compiler was wrong if they did, **they don't notice the bug**. – Eric Lippert Apr 19 '17 at 20:02
55
Are you kidding me? Compilers have bugs too, loads really.
GCC is probably the most celebrated of open source compilers in the planet and take a look at its bug database: http://gcc.gnu.org/bugzilla/buglist.cgi?product=gcc&component=c%2B%2B&resolution=---
Between GCC 3.2 and GCC 3.2.3 take a look at how many bugs got fixed: http://gcc.gnu.org/gcc-3.2/changes.html
As for others like Visual C++, I don't even want to begin.
How do you make compilers reliable? Well for a start they have loads and loads of unit tests. And the whole planet uses them so no dearth of testers.
Seriously though, compiler developers I like to believe are superior programmers and while they are not infallible they do pack in quite a punch.
Fanatic23
  • 7,533
  • 56
21
I've encountered two or three in my day. The only real way to detect one is to look at the assembly code.
Although compilers are highly reliable for reasons other posters have pointed out, I think compiler reliability is often a self-fulfilling assessment. Programmers tend to view the compiler as the standard. When something goes wrong, you assume its your fault (because 99.999% of the time it is), and change your code to work around the compiler problem rather than the other way around. For example, code crashing under a high optimization setting is definitely a compiler bug, but most people just set it a little lower and move on without reporting the bug.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
    +1 for "viewing the compiler as the standard." I've long maintained that there are two things that truly define a language: the compiler and the standard library. A standards document is just documentation. – Mason Wheeler Feb 25 '11 at 17:28
    @Mason: That works well for languages with one implementation. For languages with many, the standard is vital. The real-life impact is that, if you complain about something, the vendor will take you seriously if it's a standards issue, and brush you off if it's undefined behavior or something like that. – David Thornley Feb 25 '11 at 17:52
    @Mason - That's only because so few languages have a standard to and/to which they abide. That, btw, IMHO, is not a good thing - for any kind of serious development, that is expected to last more than one OS generation. – Rook Feb 25 '11 at 22:17
    @David: Or more accurately, one *dominant* implementation. Borland defines Pascal and Microsoft defines C# regardless of what ANSI and ECMA say. – dan04 Feb 25 '11 at 23:11
  • Standards are just features over which everyone's gone bored fighting over of. – Rook Mar 01 '11 at 01:40
    C, C++, or Fortran code crashing under high optimization is much more often wrong input code than compiler bugs. I very often work with recent and pre-release compilers, often for very new hardware, and see optimization-associated failures pretty regularly. Because these languages have notions of undefined behavior and don't specify the handling of non-conforming programs, one has to check crashes pretty carefully, eventually against the assembly. In 80-90% of cases, the application code is wrong, and not the compiler. – Phil Miller Aug 30 '14 at 20:57
15
Compilers have several properties which lead to their correctness:
  • The domain is very well known, and researched. The problem is well defined, and offered solutions are well defined.
  • Automated testing is sufficient for proving compilers work correctly
  • Compilers have very extensive, typically public, automated and unit tests, which have been accumulating over time to cover more of the error space than for most other programs
  • Compilers have a very large number of eyeballs watching their results
blueberryfields
  • 13,200
  • 51
  • 87
    Also in many cases the code is old, GCC is well over 20 years old, as are many of the others, so a lot of the bugs have been worked out over a long time frame. – Zachary K Mar 05 '11 at 16:58
13
They don't. We do. Because everybody uses them all the time, bugs are found quickly.
It's a numbers game. Because compilers get used so pervasively, it is highly likely that any bug will be triggered by someone, but because there's such a large number of users, it is highly unlikely that that someone will be you specifically.
So, it depends on your viewpoint: across all users, compilers are buggy. But it is very likely that someone else will have compiled a similar piece of code before you did, so if their was a bug, it would have hit them, not you, so from your individual point of view, it looks like the bug was never there.
Of course, on top of that, you can add all the other answers here: compilers are well researched, well understood. There is this myth that they are hard to write, which means that only very smart, very good programmers actually attempt to write one, and are extra careful when they do. They are generally easy to test, and easy to stress test or fuzz test. Compiler users tend to be expert programmers themselves, leading to high quality bug reports. And the other way around: compiler writers tend to be users of their own compiler.
Jörg W Mittag
  • 101,921
  • 218
  • 318
12
In addition to all the answers already, I'd like to add:
I believe a lot of times, the vendors are eating their own dog food. Meaning, they are writing the compilers in themselves.
DevSolo
  • 2,814
I've run into compiler bugs often.
You can find them in the darker corners where there are fewer testers. For example, to find bugs in GCC you should try:
  • Build a cross-compiler. You will find literally dozens of bugs in GCC's configure and build scripts. Some result in build failures during the GCC compile and others will result in failure of the cross-compiler to build working executables.
  • Build an Itanium version of GCC using profile-bootstrap. The last couple of times I tried this on GCC 4.4 and 4.5 it failed to produce a working C++ exception handler. The non-optimized build worked fine. No one seemed interested in fixing the bug I reported and I gave up fixing it myself after trying to dig through what was breaking in the GCC asm memory specifications.
  • Try building your own working GCJ from the latest stuff without following a distro build script. I dare you.
Zan Lynx
  • 1,300
  • We find lots of problems with IA64 (Itanium). We don't have very many customers for that platform, so cutting back optimization level is our usual bugfix. This gets back to the other answers, compilers for popular languages for popular architectures have usually had enough user exposure and enough support to be pretty good, but as you go to the less popular architectures and/or languages you should expect reliability to suffer. – Omega Centauri Feb 25 '11 at 22:44
  • @Omega: Cutting back the optimization seems to be what everyone does. Unfortunately, Itanium *requires* high-optimizing compilers in order to to perform well. Oh well... – Zan Lynx Feb 25 '11 at 22:46
  • I hear you. Frankly the architecture was already obsolete when it came out, fortunately AMD forced Intels hand with x86-64 (which despites its many warts isn't so bad). If you can break up your source files you might be able to isolate were the problem(s) is and find a workaround. Thats what we do if it is an important platform, but for IA64, not. – Omega Centauri Feb 25 '11 at 22:57
  • @Omega: Unfortunately, I really really like Itanium. It's a wonderful architecture. I consider the x86 and x86-64 to be obsolete but of course they'll never die. – Zan Lynx Feb 25 '11 at 23:06
  • The x86 is a bit weird. They keep adding new stuff to it, so it grows one wart at a time. But, the out of order execution engine works pretty well, and the new SSE=>AVX stuff provides some real capability for those willing to code for it. Admittedly there are a lot of transistors devoted to doing semi-obsolete stuff, but thats a price one pays for legacy compatibility. – Omega Centauri Feb 28 '11 at 23:12
Several reasons:
  • Compiler writers "eat their own dog food".
  • Compilers are based on well understood principles of CS.
  • Compilers are built to a very clear spec.
  • Compilers get tested.
  • Compilers are not always very reliable.
Kramii
  • 14,029
  • 44
  • 64
They are usually very good at -O0. In fact if we suspect a compiler bug, we compare -O0 versus whatever level we are trying to use. Higher optimization levels go with greater risk. Some are even deliberately so, and labeled as such in the documentation. I've encountered a great many (at least a hundred during my time), but they are becoming much rarer recently. Nevertheless in pursuit of good specmark numbers (or other benchmarks important to marketing), the temptation to push the limits is great. We had problems a few years back where a vendor (to go unnamed) decided to make violation of parenthesis default -rather than some special clearly labeled compile option.
It can be hard to diagnose a compiler error versus say a stray memory reference, a recompile with different options may simply scramble the relative positioning of data objects within memory, so you don't know if it is your source code's Heisenbug, or a buggy compiler. Also many optimizations make legitimate changes in the order of operations, or even algebraic simplifications to your algebra, and these will have different properties with respect to floating point rounding and under/overflow. It is hard to disentangle these effects from REAL bugs. Hard core floating point computing is tough for this reason, because bugs and numerical sensitivty are often not easy to disentangle.
Omega Centauri
  • 237
Compiler bugs aren't all that rare. The most common case is for a compiler to report an error on code that should be accepted, or for a compiler to accept code that should have been rejected.
kevin cline
  • 33,608
  • 71
  • 142
  • unfortunately we can't see the second class of bugs: the code compiles = everything's fine. So probably half the bugs (assuming a split ratio of 50-50 between the two bug classes) aren't found by people but by mean of the compiler unit tests – Gianluca Ghettini May 28 '16 at 08:46
Yup!
The two most memorable were the first two I ever ran across. They were both in the Lightspeed C compiler for 680x0 Macs back about 1985-7.
The first one was where, in some circumstances, the integer postincrement operator did nothing - in other words, in a particular piece of code, "i++" simply didn't do anything to "i". I was pulling my hair out until I looked at a disassembly. Then I just did the increment a different way, and submitted a bug report.
The second was a bit more complicated, and was a really an ill-considered "feature" that went awry. The early Macs had a complicated system for doing low-level disk operations. For some reason I never understood - probably having to do with creating smaller executables - rather than the compiler just generating the disk operation instructions in-place in the object code, the Lightspeed compiler would call an internal function, which at runtime generated the disk operation instructions on the stack and jumped there.
That worked great on 68000 CPUs, but when you ran the same code on a 68020 CPU, it would often do weird things. It turned out that a new feature of the 68020 was a primitive instruction 256-byte instruction cache. This being early days with CPU caches, it had no notion of the cache being "dirty" and needing to be refilled; I guess the CPU designers at Motorola didn't think about self-modifying code. So if you did two disk operations close enough together in your execution sequence, and the Lightspeed runtime built the actual instructions at the same location on the stack, the CPU would erroneously think it had an instruction cache hit and run the first disk operation twice.
Again, figuring that out took some digging around with a disassembler, and a lot of single-stepping in a low-level debugger. My workaround was to prefix every disk operation with a call to a function that did 256 "NOP" instructions, which flooded (and thus cleared) the instruction cache.
Over the 25-ish years since then, I've seen fewer and fewer compiler bugs over time. I think there are a couple of reasons for that:
  • There's an ever-increasing set of validation tests for compilers.
  • Modern compilers are typically divided into two or more parts, one of which generates platform independent code (e.g. LLVM's targeting what you might consider an imaginary CPU), and another which translates that into instructions for your actual target hardware. In multi-platform compilers, the first part gets used everywhere, so it gets tons of real-world testing.
Bob Murphy
  • 16,028
  • 51
  • 77
Found a glaring error in Turbo Pascal 5.5 years ago. An error present in neither the previous (5.0) nor the next (6.0) version of the compiler. And one that should have been easy to test, as it wasn't a cornercase at all (just a call that's not that commonly used).
In general, certainly the commercial compiler builders (rather than hobby projects) will have very extensive QA and testing procedures in place. They know their compilers are their flagship projects and that flaws will look very bad on them, worse than they'd look on other companies making most other products. Software developers are an unforgiving bunch, our tool suppliers let us down we're likely to go look for alternatives rather than wait for a fix from the supplier, and we're very likely to communicate that fact to our peers who might well follow our example. In many other industries that's not the case, so the potential loss to a compiler maker as a result of a serious bug is far greater than that to say a maker of video editing software.
jwenting
  • 9,783
  • 45
Yep, I encountered a bug in the ASP.NET compiler just yesterday:
When you use strongly typed models in views there is a limit to how many parameters templates can contain. Obviously it can't take more than 4 template parameters, so that both examples below make it too much for the compiler to handle:
ViewUserControl<System.Tuple<type1, type2, type3, type4, type5>>
Would not compile as is but will if type5 is removed.
ViewUserControl<System.Tuple<MyModel, System.Func<type1, type2, type3, type4>>>
Would compile if type4 is removed.
Note that System.Tuple has many overloads and can take up to 16 parameters (it's crazy I know).
Compiler bugs happen, but you tend to find them in odd corners...
There was a weird bug in the Digital Equipment Corporation VAX VMS C compiler in the 1990's
( I was wearing an onion on my belt, as was the fashion at the time)
An extraneous semicolon anywhere preceding a for loop would be compiled as the body of the for loop.
f(){...}
g(){...}
void test(){
  int i;
  for ( i=0; i < 10; i++){
     puts("hello");
On the compiler in question, the loop executes only once.
it sees
f(){...}
g(){...}
void test(){
  int i;
  for ( i=0; i < 10; i++) ;  /* empty statement for fun */
     puts("hello");
That cost me lots of time.
The older version of the PIC C compiler we (used to) inflict on work experience students couldn't generate code that used the the high priority interrupt correctly. You had to wait 2-3 years and upgrade.
The MSVC 6 compiler had a nifty bug in the linker, it would segmentation fault and die from time to time for no reason. A clean build generally fixed it ( but sigh not always).
Tim Williscroft
  • 3,563
  • 26
When the behaviour of your software is different when compiled with -O0 and with -O2, then you have found a compiler bug.
When the behaviour of your software is just different from what you expect, then chances are that the bug is in your code.
mouviciel
  • 15,473
  • 64
    Not necessarily. In C and C++, there's an annoying amount of unspecified and undefined behavior, and that can legitimately vary based on optimization level or phase of the moon or movement of the Dow Jones indexes. That test does work in more tightly defined languages. – David Thornley Feb 25 '11 at 17:54
I've seen several compiler bugs, reported a few myself (specifically, in F#).
That said, I think compiler bugs are rare because people who write compilers are generally very comfortable with the rigorous concepts of computer science that make them really conscious about the mathematical implications of code.
Most of them are presumably very familiar with things like lambda calculus, formal verification, denotational semantics etc. -- stuff that an average programmer like me can only barely comprehend.
Also, there's usually a fairly straightforward mapping from input to output in compilers, so debugging a programming language is probably a lot easier than debugging, say, a blog engine.
Rei Miyasaka
  • 4,541
  • 32
I found a bug in the C# compiler not too long ago, you can see how Eric Lippert (who is on the C# design team) figured out what the bug was here.
In addition to the answers already given, I'd like to add a few more things. Compiler designers are often extremely good programmers. Compilers are very important: most programming is done using compilers, so it's imperative the compiler is of high quality. It's therefore in the best interest of companies making compilers to put their best people on it (or at least, very good ones: the best ones might not like compiler design). Microsoft would very much like their C and C++ compilers to work properly, or the rest of the company can't do their jobs.
Also, if you're building a really complex compiler, you can't just hack it together. The logic behind compilers is both highly complex and easy to formalize. Hence, these programs will often be built in a very 'robust' and generic way, which tends to result in less bugs.
Alex ten Brink
  • 2,121
In some domains, such as avionics software, there are extremely high certification requirements, on the code and hardware, as well as on the compiler. About this last part, there is a project which aims at creating a formally-verified C compiler, called Compcert. In theory, this kind of compiler is as reliable as they come.
Quonux
  • 101
Axel
  • 101
