36
If you have a number of years experience in working with Java and a number of years experience in working with C# and .NET, I would value your opinion on software development productivity differences between these two environments. One of our customers is considering replacing their existing software solution. As the replacement will require approx. 10 - 15 man years work, a choice for Java or .NET, based on productivity differences between the them, may significantly influence the investment required and time-to-market.
Would you be able to provide us, an indication of software development productivity differences between Java and C#/.NET? I would prefer to receive an answer as follows:
My experience is based on X years experience working with Java and X years experience working with C#/.NET. Java is X% more productive then C#.NET or C#/.NET is X% more productive than Java if you take the the following into account.
Josh K
  • 23,019
  • 65
  • 100
Edin Dazdarevic
  • 379
    I guess one important thing here also is **what** you are making. .NET might be better for some type of projects, and Java for others. – Øyvind Knobloch-Bråthen Feb 25 '11 at 12:50
    What kind of project is it? A lot depends on the libraries available for what you're trying to do. Language wise I strongly prefer C#, but I'm not claiming that .net is better than java for all kinds of projects. – CodesInChaos Feb 25 '11 at 12:52
  • Depending on the problems you are solving try to see what tools are available for debugging. Ex: WinDBG is very useful you are stuck with OutOfMemoryException in .net. I've no idea what tools are available in Java. –  Feb 25 '11 at 12:53
  • @CodeInChaos @oyvind - The system being built is typical enterprise application –  Feb 25 '11 at 12:53
  • A given programmer will generally write X lines of code per day regardless of the language. It's really just a question of which language requires fewer lines of code to do the same thing. – Gabe Feb 25 '11 at 12:54
    You cannot easily compare two developer with X years Java experience. ;) I have interview quite a few with the same number of years experience and they all had different strengths and weaknesses. – Peter Lawrey Feb 25 '11 at 12:55
    @Peter: He's asking for the years of experience because it serves as a 'good enough' metric to give weight towards an answer. –  Feb 25 '11 at 13:28
    IMO there is a very important strategic decision and shouldn't be based on programmer productivity at all. If you want a perfectly nice state-of-the-art Windows GUI, you can't choose Java even if statistics claimed it was 7% more productive. If you need a true cross-plattform product without the restrictions Mono comes with, Java is your baby, even if C# has the nicer syntax. – user281377 Feb 25 '11 at 13:34
    @Sergio, True, just pointout that while comparing tow developer with X Java expeirance is hard enough, never mind comparing two theoretical developers with X years Java vs X years C#. Additionally, Java has been around longer (it will be hard to find a develoepr with 15 years of C# experience), but you would want to look at a developers total years of relevant experience. – Peter Lawrey Feb 25 '11 at 13:43
    @Edin: "Enterprise application" is not very descriptive of what type of application it is... Is it Desktop only, client/server configuration, web services, web sites, possible satellite applications on mobile devices etc..? – awe Feb 25 '11 at 14:00
    It's "Java" not "JAVA" – Mahmoud Hossam Feb 25 '11 at 15:40
  • @awe: I think that "enterprise" means a mix of a little bit of everything (desktop, client/server, web services, web apps)... – Edin Dazdarevic Feb 25 '11 at 16:09
  • @Edin, "enterprise" can mean anything, depending on the enterprise. Please update your question to indicate the mix of platforms. – Marcie Feb 25 '11 at 16:17
  • JAVA = Just Another Vague Acronym – Malfist Feb 25 '11 at 18:27
  • I suspect a lot of it depends on the skill sets of the existing developers (if there are any) or the people whom you could conceivably hire to do the job. The complexity of the associated libraries for both Java and .NET should not be underestimated. This helps developers be more productive but both have a significant learning curve. – Jeremy Mar 23 '11 at 07:01
  • Do you have approximately the same expertise in Java as in C#? –  Aug 27 '11 at 07:37
11 Answers11
43
I've worked on projects both in college and in the Real World™ using Java and C# for 5 years now.
Hands down I enjoy using C# more because of it's succinctness and use of syntax sugar. You will rarely find a Factory.GetFactory(OfFactory.GetFactory(Factory)); code in C#. It's easier to read and follow along because the syntax is smaller and more succinct.
Which one will you be more productive with? That depends on the type of project.
Are you designing a desktop application for Windows? Then C# is the best choice because of it's powerful IDE Visual Studio and the .NET Framework makes creating GUI's very simple.
Frankly, I'm glad I don't use Java anymore (it's been over a year now) because I remember how horribly verbose the code had to be. A quick example is exception handling. If your code can throw an exception you must account for every single exception possible. This quickly turns trivial code into a 20 line+ monstrosity.
C# isn't as hand holding, if you choose to leave your code open that's on you as a developer to decide.
C# also has made a lot of additions over the year that make it a joy to use. Lambdas, delegates, anonymous function (a la Ruby), lots of good little things you'll find as you go along.
    I remember that in Java from uni, a point Im glad to forget. Forced exception handling. yes it had a purpose, but code documentation can tell you if methods throw exceptions and it gives you a choice of what to do. – JonWillis Feb 25 '11 at 15:18
    haha, i'm a java programmer but i liked your example code. – Chuck Stephanski Mar 23 '11 at 08:38
    `If your code can throw an exception you must account for every single exception possible.` I don't see the downside of this, at least this raises awareness of problems...though, might just be me. – Bobby Mar 31 '11 at 08:46
    The checked exceptions mean you write error handling code as part of the main implementation, instead as bolting it on as an afterthought. This mean quite a lot maintenancewise. –  Aug 27 '11 at 07:39
  • I think it's just a disagreement on what exceptions mean--they can be expected circumstances (file does not exist) or unexpected errors (divide by 0). Java decided that exceptions should represent both and so has both checked and unchecked exceptions. This is a surprisingly controversial feature. – Tikhon Jelvis Jan 09 '12 at 09:19
  • Someone produced useless question and you are giving useless and misleading answer. The true question should be Java world/ecosystem vs NET world/ecosystem. This is question you should ask yourself making a choice. Given such a statement half of your pro NET arguments are groundless. Another half of your arguments are too simple and naive (Yet they are effective in terms of upvoting). Just compare your answer to mikera's answer and you will be ashamed. Be honest and add mikera's analysis near to yours. – alehro Nov 16 '12 at 17:06
29
I've worked extensively with both Java (since 1996) and .Net (since 2002) and in 2010 made a decision to go with Java in my company on the basis that it would be the most productive environment overall.
Note that I define software development productivity in terms of business value created per unit of cost/resource, on an end-to-end basis (i.e. you have to look at the productivity of the whole software lifecycle including deployment and maintenance, not just the initial coding!!).
Here are the key elements of my reasoning:
  • Syntax is a minor factor in productivity - while Java is certainly verbose and I prefer the syntax of C#, it simply doesn't matter much. Whether your developers type object.getSomeProperty() vs. object.SomeProperty or use an anonymous inner class vs. a lambda is simply not going to make any appreciable difference to your company's competitive advantage....
  • Library ecosystem is critical - developing a modern software product, you don't want to be developing lots of common components from scratch. The Java ecosystem has a clear advantage in terms of the number and quality of open source libraries (especially those developed by Apache, Google, the Eclipse Foundation and RedHat/JBoss)
  • Portability / deployment flexibility - I know I can deploy a JVM on pretty much any platform, including big cheap Linux clusters. With .Net, you are restricted to Windows environments. With the advances in cloud hosting options, I judged this to be a pretty important advantage.
  • Scala and Clojure are both viable options for development on the JVM if you want advanced language features. It's a realistic option to develop in Java but keep open the option to move to Scala or Clojure over time. To some extent these are "next generation" languages that I think are ahead of both Java and C#, so this reassured me that the Java platform has a good future in terms of language innovation. (Java 7 and 8 looked promising, but I wasn't exactly holding my breath....)
  • Maintenance costs actually seemed to be pretty favourable towards Java. Java has a simpler syntax than C# which means more verbosity but on the flipside means that people tend to write more maintainable code - it's simply harder to write "clever code". In addition, the Java world puts much greater weight on backwards compatibility than the .Net world, which is going to be advantage in terms of maintenance costs over multiple years.
  • Vendor independence - having seen companies being burned by vendor lock-in in the past, I felt it was an advantage to go with the relatively more open Java ecosystem rather than the Microsoft-dominated .Net world. For example, I'd rather have the choice of databases rather than being pushed into using SQL Server (and the push is quite strong, through both the tool support and typical skillset of .Net developers). Keeping your core product investment vendor independent is, in my view a smart long-term move. I judged (correctly as it turns out) that the OpenJDK would be the future of Java so I would effectively be building upon an open source platform.
  • Talent - this is subjective of course, but I was more impressed with the technical ability of developers in the Java world than in the .Net world. My impression on average was that .Net developers had a tendency to do whatever Microsoft provided easy tools or templates for, whereas the Java developers tended to care more about finding the right solution from a software engineering perspective. This is completely subjective and no doubt dependent on the specific locality/market and there were clearly many individuals that didn't fit this pattern, so YMMV of course.
  • Tools were about level. Microsoft have a lot of great, easy to use tools that would be particularly appealing for developing on Windows. However I am working primarily on server-side development, where I'd argue the Java tools have the edge. In particular, Maven has proved to be an extremely powerful tool in the Java ecosystem which I still don't think has a decent equivalent in the .Net world.
So while there were a lot of complex considerations, overall I'm pretty happy with the choice to go with Java, and would make the same choice today (As of early 2012).
Probably the only case now where I'd go with .Net would be if I was developing a Windows-only desktop application (where the .Net advantage is clearly huge).
mikera
  • 20,617
  • 75
  • 80
    +1: Great answer! It summarizes many of the issues that should be considered when evaluating productivity as a whole. Some syntactic sugar may make a language look cool and more "modern" but there are also other important factors that influence productivity. – Giorgio Jan 09 '12 at 10:47
    +1 for a way more comprehensive answer than previous ones. – NlightNFotis Oct 25 '12 at 12:35
    Since you mentioned Scala and Clojure you might as well mention F# too... – Mauricio Scheffer Oct 28 '12 at 04:02
    Great! Thorough analysis. Just what I was looking for. :) – xebo Feb 11 '13 at 13:57
19
My experience is based on 10 years experience working with Java and 3 years experience working with C#/.NET. Java is 0% more productive than C#.NET. This is based on writing back-end service-based applications.
C#/.NET is maybe 5% more productive than Java for writing user applications. But then I've not done this for a almost 5 years in Java and the new Netbeans UI editor could have closed the gap.
You want to increase productivity? CI (ideally Continuous Delivery) and automated tests. The productivity gained by language/platform/IDE choice on any major language/platform/IDE is fairly small.
gnat
  • 21,442
  • 112
  • 288
mlk
  • 1,049
  • Did you mean to say 0% for Java? Do you mean 0% more productive for back-end service-based applications, or Java overall? Just checking. – Jon Onstott Feb 25 '11 at 17:45
  • If you were to ask me to write a back end application (some rules, db access and what have thee) then the estimate would be identical for both C# and Java. If you asked for a windows end user application I'd make my estimate slightly larger for Java than C# (WPF/XAML and its support MVVM via binding I think is slightly more productive than the more manual binding and UI building in Java (as off 5 years ago)). – mlk Feb 26 '11 at 15:08
  • +1 for "The productivity gained by language/platform/IDE choice on any major language/platform/IDE is fairly small." – Adam Jaskiewicz Dec 06 '11 at 17:55
    -1 for the last sentence. For every (real world) problem class, you can choose two general purpose high level languages, where the increase in productivity from one to the other surpasses 100%. If you choose between C# and Java, you will find little difference (although I would argue that C# will prove significantly more productive in areas suitable for functional programming). If the choice is between C and OCaml, the difference gapes at you. – back2dos Jan 09 '12 at 10:20
I have: Java 10 years, C# 8 years
I vote Java for
  1. No Vendor lock in (you can change app/web servers from linux to windows to Unix)
  2. Interoperability/Interchangeable of third party packages, such as JasperReports JFreeChart, JSF or Spring
  3. Most innovation comes from here (Log4j, Ant, Spring, Hibernate, and on and on)
  4. Works on Multiple application servers (kind of like A). Such as JBoss, Tomcat, WebSphere, GlassFish, WebLogic
pat
  • 131
  • I don't know diddly about C#/.NET. But you raise a good point here. Not so much about what persistence provider or application server you can choose, but choosing between say Struts, JSF, Spring MVC, etc for your middle tier and JSP, Facelets, GWT, etc for your presentation tier. Do you have those kinds of options w/ .NET? – Chuck Stephanski Mar 23 '11 at 08:49
    What kind of "innovations" can be in a language with no lambdas? – SK-logic Mar 23 '11 at 13:06
    What kind of "innovations" can be in a language that finally got an MVC framework 10 years after every other language? – Kaleb Brasee Mar 27 '11 at 04:38
    There were other MVC frameworks before ASP MVC (e.g. MonoRail)... – EricSchaefer Apr 18 '11 at 05:19
    Oh BTW: Lambdas/Closures are a language feature, you are talking about frameworks. – EricSchaefer Apr 18 '11 at 05:20
    @SK-logic, you do not require lambdas to write an O/R layer. –  Aug 27 '11 at 07:40
    @SK-logic: "Innovation" does not mean adding features to a language that wasn't designed for them just because they have become fashionable. IMHO lambdas are good in Haskell, Lisp, or Scala. But in C#, C++, Java?? Maybe they should be added to C and Assembly too. – Giorgio Dec 06 '11 at 18:23
    @Giorgio, lambdas fit perfectly any language with GC. There is no place for them in C++ and C, of course. – SK-logic Dec 06 '11 at 19:30
  • @Giorgio: There's no reason not to add lambdas to Java. You already have anonymous classes which can be (horribly verbose) lambdas. In fact, I think Java is finally getting a proper lambda syntax in the next version. Of course, that's what they promised for Java 7 too :) – Tikhon Jelvis Jan 09 '12 at 09:22
  • @Tikhon Jelvis: What I mean is the following: A lambda expression is a name-less function. Why add name-less functions if Java does not have functions in the first place? Is this "orthogonal"? I would find it OK if Java also had normal "named" functions. Otherwise it seems an ad-hoc addition to me. – Giorgio Jan 09 '12 at 09:55
  • @Tikhon Jelvis: Besides that, I tend to like more _minimalistic_ languages, i.e. languages that are as expressive as possible with as few features as possible (KISS + YAGNI). I used to like Java because it took certain features from C++ while throwing away others. I would not like Java to change and start incorporating all kinds of new features because they become fashionable. I prefer to look at a new languages designed on purpose for new features and paradigms. That's why I like Scala (which I am learning at the moment) and I do not like what is happening to Java and C++. – Giorgio Jan 09 '12 at 10:05
  • @Giorgio Having to provide names for functions that do overly trivial things is a pain, and make it not even worth it to do functional style programming. "value => !string.IsNullOrEmpty(value)" is short and to the point. Do you really want itty bitty little functions all over the place to replace them? – Chris Pitman Feb 14 '12 at 20:10
  • @Chris: As I have explained above, I am not against lambdas, which I find very useful and use all the time in Haskell, Scala, or Scheme, but I am not sure if they fit with the design of Java. Why spoil Java instead of moving to Scala or Clojure, which offer much better functional programming and can interoperate with Java? – Giorgio Feb 15 '12 at 20:36
I have 10+ years of experience with Java (since version 1.1, really!) and 7 years of experience with .NET (C# mostly).
You have a very though decision to make but mostly you should try to break down into a couple of scenarios:
Desktop Application
If you are developing a desktop application you have to go with the major platform you will be working with. If it's a Microsoft platform use .NET, there are no better solution than the platform developed by the mother ship itself. If it's a Linux or Multi-platform scenario consider Java or moving to a web based solution.
Web Based Application
This is a very hard decision to make because each one has their own strength and weakness. Here's a few:
C#
Strength: Currently has more momentum building new features into the language and the platform/framework. Everything comes from one vendor and definitely this is an advantage. You can also put to use some very powerful components like DevExpress for example (Java doesn't get even close to have something like what the DX team has put together over the years and this represents a huge productivity boost).
Weakness: For enterprise application .NET is not as mature as Java. You don't have that many vendors building enterprise software in .NET as you have for Java.
Java
Strength: More mature (already explained) and has a big community with several great open source projects that can help. Several .NET so called open source projects are really just a copy-cat of projects from Java.
Weakness: Oracle owns Java (I know, not the JCP) and that is definitely a risk to be considered. Their intentions are not very clear and I personally don't like where the language is going right now (I know a lot of Java developers have similar concerns).
Server Side Application
It's basically the same arguments as the Web Based Applications but because you don't have to worry too much about UI Java gets stronger in this case. But again, if the platform is mostly Windows .NET might be a better choice.
Overall Considerations
Overall, in my opinion, .NET has the advantage mostly because of the tight integration of Visual Studio 2010 (hands down the best IDE out there), MS SQL, Entity Framework, IIS and so on. This all represent a huge productivity boost and I have tons of experience proving that. Also I work with mostly Java developers that turned to .NET and they share basically the same opinion.
I think it's also a good point that Microsoft is stronger than ever meaning .NET will be there for a while. So when looking 10-15 years ahead I feel more secure with .NET than Java.
Alex
  • 3,228
Java: 5 years (non continuous)
C#: 7 years
I don't believe you can quantify the productivity that way. That heavily depends on the individual developer and the project. Use what your developers know.
Edit:
Let's define "typical enterprise application" as:
  • multi tiered
  • client/server
  • DB backed
Both Java and C# can do that. It's not so much a matter of the language, but of the framework/runtime. Again, use what your developers know. They can learn a new language and a new framework, but it takes time to grok it. The would be true for a desktop app. Both languages can be used with numerous GUI toolkit/libs, but it they all have different approaches and philosophies.
EricSchaefer
  • 2,091
  • 30
    "That heavily depends on the individual developer" ... which is exactly why he wanted an opinion from people who have experience in both worlds ... "and the project." ... which should require an answer that points out what kind of projects will benefit from the different technologies. – awe Feb 25 '11 at 13:49
    It does not depend on this dev (aka me), but on the devs who are supposed to build the project. It also would be easier if he had stated what kind of project he is about to build... – EricSchaefer Feb 25 '11 at 13:58
  • @eric it's typical enterprise application – Edin Dazdarevic Feb 25 '11 at 14:12
  • @Edin, Java does have JavaEE edition with inbuilt enterprise features. You can quickly develop applications with this framework. However it does alot of stuff by Magic, you must conform to its rules. And if things break don't expect the exception messages to be useful as the stacktrace is huge. Accessing a DB with wrong name or DB is off, the stacktrace is so big you cannot see what caused the initial problem. – JonWillis Feb 25 '11 at 15:20
  • I'm not sure there is any such thing as a "typical enterprise application". – Marcie Feb 25 '11 at 16:18
    Sure there is a "typical enterprise application", take this data from point a, allow the user to mess it up, then put it in point b. ;) – mezmo Feb 25 '11 at 17:02
I'm a recently graduated student from university, but have had commercial experience with both languages, giving a total of about 3 years java and 4 years C# .Net (note .net means you can use C#, VB.net, C++ CLI, and J# and F#).
I'll state now my overall preference is C# over Java, whilst both have similar syntax I like the power of the .Net framework over the cross OS compatibility of Java. You must strongly consider ,what you need to build ? Is this just a desktop application? Are you needing connectivity to other clients, so other desktops, mobiles, websites?
**Discussion on IDE lost as question at Stackoverflow was closed. End gist of it was Java has many free IDEs but they don't compare in my opinion to the power and addons of visual studio. But note Visual studio costs over per license.
You need to look at what skills your development team has already, as this will have an initial impact. Which is faster is here nor there given an experienced user in either language/framework. Which I guess brings the point that you must not consider the language, as the language is just syntax, but the tools and the framework that the language is making use of.
HalfWebDev
  • 199
JonWillis
  • 429
    £1000 per licence for VS? If you're getting MSDN subscriptions, you get far more software and tools available for the cost. I really doubt anyone pays the retail shelf-price of VS2010. – James Love Feb 25 '11 at 13:11
  • AFAIK you can't easily write extensions for VS. Not needed for most of us, yeah. But I work with several languages, and eclipse can do all of them. They don't all run on the JVM. – Michael K Feb 25 '11 at 14:42
  • @JamesLove, Very true, I did not consider the other applications provided with an MSDN license. Having MSDN provided for means I do not really consider the cost or the advantages of MSDN, but it is a key point worth mentioning. – JonWillis Feb 25 '11 at 15:14
    @Michael, I've never tried to wrtie VS extensions. However I do use or have tried a variety of plugins for Visual studio. These include Resharper, CodeRush, Gallio, VisualSVN, AnkhSVN, testDriven.Net, and many more. – JonWillis Feb 25 '11 at 15:16
    @JonWillis agreed, there are a plethora of extensions out there. On top of that list, I also use (on a daily basis) Productivity Power Tools, CKS:Dev for SharePoint and WSPBuilder. The gallery (at http://visualstudiogallery.msdn.microsoft.com/) has a couple of thousand on there, so it can't be that hard to write more extensions for VS (full framework is actually provided for doing so, and there's ample community support). – James Love Feb 25 '11 at 15:27
    For a project planned to be 10-15 man years work, an initial cost for VS licenses is peanuts. – awe Feb 28 '11 at 07:42
    Visual Studio 2010 Professional without MSDN is $550. – Boris Yankov Aug 27 '11 at 13:10
I've flipped back and forth between Java and .NET, starting with Java 1.2 up to 1.6, and .NET 1 up to 4.0, over about 10 years of professional work experience (being a C/C++ programmer before that).
At one time, like .NET 2.0, I would say that Java and C# would be about the same, especially for back-end work. The language constructs were still very similar. .NET would have probably gained the edge in desktop UI programming, because of the WinForms designer in Visual Studio, and Java would have had the edge in Web / Server stuff, primarily because you weren't stuck with IIS.
Now moving in to .NET 3.5 and 4, I give the productivity edge to .NET, hands-down. This is primarily, in my opinion, because .NET is a much quicker evolving language, since MS can make language decisions relatively quickly, as opposed to pushing changes through the politics of the JCP. Big improvements are the var keyword, the entirety of Linq, Extension Methods, the Null-coalescing operator ??, dynamic, and probably a lot more great stuff that really boosts productivity.
Now, that said, the "most productive" language for a project is almost always the one that the most developers are the most comfortable and experienced with. The learning curve is always the biggest productivity killer.
rally25rs
  • 549
One thing that I have noticed is many C#/.NET shops have a "not invented here" attitude and ban all third party/open source libraries while many Java shops are more willing to use open source libraries. Also there seem to be more libraries available for Java. Even if you look at some cool third party libraries in .NET e.g. NHibernate, NPOI, Spring.NET, etc. they are ports of the Java libraries and hence are behind them. It certainly seems like many of these innovations came first to Java and after time a .NET port was created. From a library perspective it certainly seems Java wins in terms of new innovative discoveries.
Still Microsoft does make some official libraries e.g. ASP MVC, LINQ, etc.. But often like with ASP MVC third party libraries like Struts, Spring MVC, etc. were already out for Java and Microsoft was late entering the model view controller web paradigm.
Of course, many of these libraries save a ton of time and make you more productive. Core language to core language C# and Java are not that different and for me it is too close to call. Throw in the army of third party libraries and the scale certainly tilts towards Java. Still with an open shop a lot of that tilt balances out. It's just a lot of .NET shops have the not invented here attitude while a lot of Java shops are whatever it takes to get the job done... This is even true within the company I work, the .NET team does not get much (due to management) while the Java team has many approved third party libraries/utilities. Also with .NET a lot more of the good stuff is not free (e.g. prior to NPOI if you wanted to work with Microsoft office documents, most of the solutions [not counting office automation] were not free. Whereas java had POI since 2001 I don't think NPOI came out until 2008, it's hard to tell based on the npoi project site.
Cervo
  • 1,748
  • "Not invented here". Based on what grounds? I work in a mix between C# and Java and I've seem greater abuses from Java folks, e.g. creating an IConverter and implementing logic to convert a string to double, and vice versa. – George Silva Jan 09 '12 at 13:05
  • For several reasons I prefer C# over Java, yet, I prefer the "migrated" Java To C# libraries over the native C#, usually, better designed, tested & applied in real world. – umlcat Oct 27 '14 at 18:05
With the similarity in syntax and tools, the producivity gains from either C# or java are not of an order of magnitude to make a significant difference to your 10 - 15 man years work project. I would look more closely at issues like:
  1. What are the requirements of the project and what language capabilities meet those requirements (e.g. cross platform vs rich Windows client).
  2. What can I put in place as a project approach/methodology that is going to enable my team to work productively.
  3. What can I do about the work environment to make sure I employ, retain and fully utilise the best team possible for a significant project.
I would suggest that, in my opinion, the premise behind the question, that "productivity differences between (C# and Java) may significantly influence the investment required and time-to-market" is not true. I do not doubt there would be some difference but it would not be significant.
AlexC
  • 1,337
I asked myself this question a lot : which is better ? C# or Java ?
I will give you an advice and this advice is the conclusion of my research : None of them is better, only the language you know well and you can do a lot of fascinating applications with is the best.
Learn how to program and then train yourself a lot using one language and when you become perfect in writing code with it, think about other languages and believe me, you will learn the other languages like a piece of cake.
Matthieu
  • 4,559
  • 35
Salah
