23
I had a search but didn't find what I was looking for, please feel free to link me if this question has already being asked.
Earlier this month this post was made:
http://net.tutsplus.com/tutorials/php/why-youre-a-bad-php-programmer/
Basically to sum it up, you're a bad programmer if you don't write comments. My personal opinion is that code should be descriptive and mostly not require comment's unless the code cannot be self describing.
In the example given
// Get the extension off the image filename
$pieces = explode('.', $image_name);
$extension = array_pop($pieces);
The author said this code should be given a comment, my personal opinion is the code should be a function call that is descriptive:
$extension = GetFileExtension($image_filename);
However in the comments someone actually made just that suggestion:
http://net.tutsplus.com/tutorials/php/why-youre-a-bad-php-programmer/comment-page-2/#comment-357130
The author responded by saying the commenter was "one of those people", i.e, a bad programmer.
What are everyone elses views on Self Describing Code vs Commenting Code?
Phill
  • 221
    @Péter - I did take a look at that one but I was more wanting to get peoples personal opinion between the two, rather than defining comments as code-smells or not. – Phill Feb 24 '11 at 10:11
    "Why you are a bad PHP programmer" Answer: Because you are programming in PHP. – Thomas Eding Apr 04 '12 at 20:27
  • Your preferred method is essentially using function calls to comment your code. Why not use comments for that? Functions should be used for reusable code only. I personally hate having to follow someone else's code written in this manner for the same reason the GOTO statement is evil - It creates spaghetti code. This is made better by modern IDE's, but not every language and programmer can use these IDE's and it's still disorienting. Honestly, I agree that you should comment sections of code that are not clear at a glance - it just makes reading through your code so much quicker and easier. – dallin Sep 03 '13 at 20:54
  • @Phill After reading all the poor suggestions about self-documented code and using functions instead of comments, I decided to go into a little more depth than my comment above and add an answer that clearly describes why they are wrong below. – dallin Sep 03 '13 at 23:39
22 Answers22
77
You shouldn't document what the code is doing, but you should document why it's doing it.
No amount of naming trickery will expose the whys and wherefores, so you have to add comments to explain the purpose of the various bits of code.
All the other comments can safely be get rid of.
biziclop
  • 3,351
    +1 The example in the linked article says "make comments in any situation where the *purpose* of the code I've written isn't immediately apparent." - It's just silliness to believe that code by itself can communicate *purpose*, because machines themselves have no concept of purpose. Counter example: We have bugs in almost all software ever written, this is a truism. If a computer understood *purpose* (the *why*), it would simply refuse to do anything other than what we intended, rather than dutifully recreate the what/when/how/where that led to the bug. – David Meister Jun 27 '15 at 12:25
  • All the code inside a function should be there to fulfill the purpose of the function, i.e. what it does, e.g. write some text to a file, the function "writeTo(String text, File file)". If some code has a different purpose, e.g. check preconditions, like verifying that the file exists AND it is not evident, then _perhaps_ a better idea than a comment is writing a new function, e.g. "checkWritable(File file)". Code quality is not a dogmatic checklist, but if it _needs_ comments, that's a _bad_ sign, and the "whys" are not a good reason to _need_ them. _Why_ did the chicken cross the road? – Trylks Jul 24 '15 at 15:47
    @Trylks That works for some cases but not for all. Imagine this scenario: `for (int i = 0; i < length/2;i++) { //if length is odd, the middle element should stay in place`. Now, this is neither something that is obvious from the purpose of the enclosing function, nor could it be factored out into its own function. If you leave it uncommented, that's clearly bad. So you add a comment to clarify your intent. – biziclop Jul 24 '15 at 16:05
    @Trylks Besides, even if we take your example, you factor your check out into a method and call it, great. Now all you have to explain is why you need to check that the file is writable. :) – biziclop Jul 24 '15 at 16:08
48
I prefer writing self documenting code. A guide for this is Clean Code.
This of course does not mean one should never use comments - they have their role, but IMHO you should use them carefully. This earlier answer of mine on SO explains my thoughts on the topic in more detail.
Of course, as @Niphra noted, it is always worth double checking that what I believe to be clean is really understandable by others. However, this is a question of practice too. Back in the uni I wrote cryptic pieces of code simply due to using strange and funny names for all code entities, according to my whim. Until my teacher threw back one of my assignments, politely noting that he couldn't figure out which module was the main :-) That was a good lesson, so I strove to focus on writing ever more readable code since. Nowadays I hardly get complaints from teammates.
Péter Török
  • 46,427
  • 160
  • 185
    I still find comments valuable to express the strategy used, and those who were rejected (with the reason). I agree that micro-comments are generally useless. – Matthieu M. Feb 24 '11 at 17:59
  • @Matthieu M., for me design/strategy related comments are inside that "gray zone" about which I don't have a strict opinion; I consider it a matter of personal style so I am fine with it either way. Surely these kinds of comments age better, or at least don't rot as fast as the micro-comments. – Péter Török Feb 24 '11 at 20:38
    One of my favorite quotes from Clean Code is that every comment is a failure to express yourself in code. – Doval Feb 20 '14 at 20:01
    @Doval: An interesting philosophy, at least with regard to comments about what code *does*. On the other hand, some of the most useful comments can be those about why code *doesn't* do something--a concept which I don't think code should be expected to express. – supercat Feb 06 '15 at 21:25
    Disagree entirely. No amount of naming is going to fully describe the purpose of logic. – Kellen Stuart May 31 '18 at 19:43
  • let me put it like this, comment and clear code are both necessary, it's like a car, it needs both engine and wheels and you won't say wheels are more important than an engine, it works harder without each other, you won't wrap/encapsulate long code into small method name shortcut with comments, and yet you need comments in encapsulated code sometimes as you are not going to wrap everything infinitelly – FantomX1 Nov 11 '19 at 11:43
40
I don't actually believe in self-describing code. There is more readable code and less readable code, depending on the language, your knowledge of it (as the original author), the knowledge of the guy reading it, and the code function. But no, still ... it should be described with a short comment.
What is clear to me now, that I'm in that area of thinking will probably not be clear to me in a year, when I'm thinking about something completely different and need to use this part of the code again.
So, comment your code. Not every line (good heavens, no) of course, but put a few lines of comment above a function / subroutine / module, or a particularly tricky part and tell in short what it does. You'll thank yourself in a year or two.
Rook
  • 19,861
  • 53
  • 96
    Been there, done that. "Less readable code" should be improved into code that reads well. Knowledge of a language doesn't really count: When not familiar with the syntax, you should learn it first - frankly, that's the basis for being a professional. Trying to make up for terrible code by adding comments is not a good idea. Comments should never ever attempt to describe what the code does. A (general) comment is justified only if you need to tell the *why* and not the *what*. Everything else is just noise and unnecessary additional stuff to maintain. – Powerslave Jul 03 '16 at 22:02
    To avoid confusion, I'm talking about the usual case, when you're not forced into writing bad code by the business requirements (e.g. exceptional performance or fitting into confined storage). In other (rare) cases, you have no option but to leave comments, somewhat easing the burden of the next victim. – Powerslave Jul 03 '16 at 23:23
22
Luckily, both camps on this discussion are represented here, and pro and con arguments for both were mentioned.
I believe both camps have overlapping arguments, and actually agree on most of them, just the way how to achieve them is a bit different.
Overlapping arguments
  • Code should be readable.
  • Comments shouldn't say the exact same thing as the code does, but give further insight where necessary.
  • All variable/function names should be given good thought so they give a good representation of what they are/do.
  • Duplicate code should be prevented.
Now, the main difference is how much weight is put on some of those arguments.
Self-describing code
  • Comments can get obsolete, so minimize using them, as wrong comments are worse than no comments.
  • Comments are a duplication of the code. Everything which can be written in code, should be written in code.
More comments
  • Comments are more readable than code. Plain english is better at describing something.
  • Plain code often causes ambiguity which has to be commented anyhow. Trying to describe this in code, results in too long names. Furthermore, you are constantly confronted with this 'extra' information which you only need the first time you come across it.
I believe both camps have very valid arguments, but you shouldn't frantically follow one camp, just because it solves one issue.
To demonstrate, in the book Clean Code, code is broken down into numerous smaller methods which are only called once. Methods are created for the sole reason to document the code (and easier TDD). This results in Function Hell. The code is less readable than it was originally, and while refactoring, no thought was given to encapsulate reusable code.
On the other hand, you often see API's where every function is commented, just because 'comments are good'. The things which should have been commented still aren't.
Steven Jeuris
  • 5,804
  • 30
  • 52
    @Steven - "On the other hand, you often see API's where every function is commented, just because 'comments are good'. The things which should have been commented still aren't." Ugh, so frustratingly true! – dss539 Jun 30 '14 at 15:34
    This is a very good answer! One thing, if you won't mind, on comment readability: I personally don't believe in comments being more readable. We, as developers, usually think in source code, especially when in "coding mode". In those moments, the vagueness of plain human language is usually more of a distraction than of help. – Powerslave Jul 03 '16 at 22:16
    Thanks for mentioning Function Hell! – dzieciou Dec 09 '22 at 15:50
The Short, Better, and Correct Answer
The idea that well-written, "self-documented code" is all you need is an anti-pattern and should die, even when it makes exceptions for comments that explain "why". It's a myth that you can always write all code for any algorithm clear enough for any programmer to glance at and get it (or that it won't require refactoring or organizational time you don't have). Even more importantly, more often than not, programmers who think they write clear code do not.
A much better answer than comments should only be used to explain "why" is that comments should:
  • explain "why" (of course)
  • explain "what" on individual lines only when the code is complex or the purpose is unclear and it can't be or isn't worth simplifying further
  • explain "what" for blocks of code to speed up comprehension and locating what you need
The Explanation to Back It Up
People erroneously think the only reason people use comments is to explain what a line of code means. The truth is a large purpose of commenting code is to make it quicker to glance through your code and find what you're looking for. When I come back to code later or read someone else's code, sure, I can read and understand a section of well written code - but isn't it faster and easier to read the comment at the top saying what that section of code does and skip it altogether if it's not what I'm looking for? Why sit there and figure out code at all, even if it's well written, if you can glance at a couple comments and understand an entire function? That's why we use descriptive names for functions - no one says I don't need to use a descriptive name for my function because someone can just look through my cleanly written code to see what it does.
For example, if I'm looking through someone else's function, is it easier to go line by line through the code to see what it's doing or to glance at three well written comments throughout the function to see exactly what the function is doing and where it's doing it?
Another anti-pattern is the overuse of functions to comment your code. Well named functions are an important part of code documentation, but sometimes programmers separate 2-3 lines of code that will never be used anywhere else into a function for documentation purposes. Why is overusing functions any better than overusing comments? Using functions like that is the same as embracing GOTO statements - it creates spaghetti code that can be a pain to follow.
Essentially, when you work in an enterprise environment, where people are constantly sharing code and people don't always have the time to make their code perfect, a few good comments can save tons of time and frustration. And remember, while you may be a guru who can read through code at light speed, not everyone in your office probably is.
dallin
  • 412
  • I hate it when people downvote and don't even leave a comment why. Did you even read the entire post? What in there isn't straightforward and true? What do you disagree with? I feel like people are so set in their idea or what they read that they don't even think about it and will downvote anything immediately that doesn't share their view. – dallin Sep 03 '13 at 23:45
    I assume it's because you outright reject and name an antipattern something which is nearly universally recognized as right. I certainly think you go too far. Mostly, I can't imagine trusting comments as well as you seem to. If you blindly read the comments and not the code, the comments may be wrong and out of date, and you'd never know. That's the basis of using functions as documentation. I'll agree that you shouldn't have too many functions in one place, though the solution to that is definitely not to replace them with comments. – Magus Feb 19 '14 at 16:02
  • @Magus Thanks for the comment. I assume you were referring to my talking about using functions as documentation. Rereading that, I believe I worded it poorly to sound like I meant using functions for that purpose at all (as opposed to the overuse of functions for that purpose) was bad. I've cleaned up that paragraph to clarify my original intent. My thoughts about trusting comments is if a comment becomes obsolete, it's usually a sign you were commenting too narrow of a section of code - that you were commenting implementation rather than intent. – dallin Feb 20 '14 at 18:59
    `but isn't it faster and easier to read the comment at the top saying what that section of code does and skip it altogether if it's not what I'm looking for` It's called "the name of the method/function". If you've got a block of code that has no name but is so long that you can't take it in with one quick glance, maybe the problem lies there. – biziclop Jun 27 '15 at 14:51
    @biziclop Overtime I came to believe this argument is mostly semantics, and in practice, our code would look similar. Having said that, assuming the block of code is not used in more than one place, I do not see a difference between a block of code with a short descriptive comment at the top and a block of code with a short descriptive function name at the top. They are the same, except one has no spaces. They can both be wrong and out of date. The only difference I really see is the code is easier to read with a comment since you don't have to follow the function call to a separate location. – dallin Jul 03 '15 at 18:46
    @dallin That is true, on the other hand though, a short code block that is its separate function can be compartmentalised in your mental map of the code far more easily. Without the familiar formalism of a function declaration that task is a lot harder. Of course you can formalise your block comments too, but not everyone will adhere to your comment formalism. No problem, you can write a tool that checks the comment formatting. But how different will that tool be from the compiler? :) – biziclop Jul 03 '15 at 18:53
  • @biziclop What I'm trying to say is we both believe code should be organized in short, single purpose code blocks with a descriptive name. The argument I'm addressing is whether small, single purpose code blocks that are only used in one place should be organized by breaking them out into separate functions or collapsing them with a descriptive comment above them. Both look the same in code and function similarly, and it's largely a matter of opinion. In my experience though, too many functions eventually lead to spaghetti code in large projects, similar to the problems with goto statements. – dallin Jul 03 '15 at 18:59
  • @biziclop I do see your point about comment formalism though. Functions do provide a much more formalized and adhered to methodology that you can trust in a team. I guess it gets back to an opinion on how to balance the two evils: do you go to the effort to strictly train and adhere to a comment system as a team or do you accept the code complexity created by having excessive functions in large projects. I think the best answer is perhaps modern languages need to adopt some sort of formalized inline function syntax. – dallin Jul 03 '15 at 19:06
  • Once everyone agrees on the problem, I'm sure we could come up with plenty of solutions. And surely some languages suffer more than others, so the solutions will probably vary too. – biziclop Jul 03 '15 at 19:24
"Im sorry but your that guy."
I wonder why he does not like commenting :P
Seriously, coding is too much of an art that one could truthfully make such a sweeping statement. Sometimes you need comments, sometimes more and better named functions. Usually both.
Look up literate programming as an extreme style.
vegai
  • 693
    Yeah. I mean, if Donald Knuth thinks you not only need comments, but sometimes need *chapters* of them, I would think at least twice before disagreeing. – PeterAllenWebb Feb 25 '11 at 01:50
Well, the thing with self documenting code is that within that function, you would find :
which is self explanatory when you have the function name since it's only two lines. When things get more complicated, you either have to wrap every few lines of code in a function with a descriptive name, or use comments where necessary.
I never understood why it should be an or/or matter, instead of and/and. Yes, make your code as much self documenting as possible, and yes, add some comments to the parts that would otherwise be rather unclear.
Joris Meys
  • 1,933
In that case, it's easy to make a descriptive function. But I've read a lot of code made by good programmers who believed their code was self-documenting, and what had been crystal clear to them was really confusing to me.
$extension = GetFileExtension($image_name);
To get back to your exemple, can I send an array of image names to it, or does it take only one image? Does it support any types of file, or only some of them? Will it secure the string for me, or do I have to do it? If the file type doesn't exist, does it notify me?
Of course, I'm stretching this one a bit. But I remember a programmer who believed audio_bandwidth and video_bandwidth were self-documenting names; turned out audio had to be expressed in bytes and video in kilobytes. Took a lot of time to figure that one out.
DistantEcho
  • 1,196
    You're stretching that one a lot. The function gets the file name extension. Nothing more nothing less. Its name says if it takes an array or not (clearly not). I can't think of a method that would rely on the file type to get the extension. Securing the string is the only one that might be incorporated, but I would never expect it because as any PHP dev knows: all user input is suspect, so secure it before you use it. – Matt Ellen Feb 24 '11 at 09:52
    @Matt: The “clearly not” is an indication that you don't do maintenance very often. Being explicit saves much head-scratching (and RTFSource) later on, and it also documents what the original author *expected* it to do. Whether that's in a comment or in a long function name isn't nearly so important. – Donal Fellows Feb 24 '11 at 10:01
  • Maybe the example was a bad one to use in this question, I haven't touched PHP in about 7 years, been doing C# and a tiny bit of Java, so I'm used to having an IDE that tells me the type returned or declaring the types. – Phill Feb 24 '11 at 10:10
    @Donal Fellows: it says file, singular. What is ambiguous about that? It's completely explicit. – Matt Ellen Feb 24 '11 at 10:12
    @Matt: If the definition really is GetFileExtension($image_name), I would expect it to do something at least vaguely related to images. Why wouldn't it be called GetFileExtension($file_name), if it didn't check the type? – DistantEcho Feb 24 '11 at 10:14
  • @Niphra - Sorry, I actually copy pasted it, I would actually call it $image_filename, since it's relating to a specific filetype and maybe doing image manipulation. Will edit question. – Phill Feb 24 '11 at 10:16
  • @Niphra: you're looking at the callsite, not where the function is being declared. `$image_name` is not necessarily the name of the parameter, but is that name of the local variable that holds the file name. If the function were meant to only work with image files I would expect it to be named differently. – Matt Ellen Feb 24 '11 at 10:18
    The fact that there are now 7 responses from 4 people discussing the obviousness or otherwise of a single function call suggests to me that *you need to use comments*. It's also highlighted the fact that accurate naming is an artform in itself. – Ant Feb 24 '11 at 13:12
Well you also have to remember something that is obvious or "self-documenting" to you, may not be to someone else...Maybe someone with less understanding of certain functions. So I comment just about everything.
    Can you give an example. I mean given the example in my original question. "GetFileExtension" whats the point in the comment "Gets the file extension of a given file"? The method has already described what should go into the comment. If the method was named "GetExtension" then a comment would aid in clarifying what the method is to do, since the method is not explaining itself. – Phill Feb 24 '11 at 13:22
  • +1 This is a know-your-audience question. Who is likely to use this function? How can you help them? What will your help be worth? Is it worth more than spending a bit of time now to add a comment? Etc. Etc. Etc. – PeterAllenWebb Feb 25 '11 at 01:56
    @PeterAllenWebb: No point to that comment at all. That doesn't remotely mean the function shouldn't be commented; it should. Does "extension" include the dot or not? What is the return value for `"foo"`? (`null`? `""`?) For `"foo."`? Will passing in `null` cause an exception, or will the function return something (perhaps `null`)? – T.J. Crowder Jan 08 '15 at 13:21
Comments and the self-documented clean code are different. Code is all about how to do things. And comments should cover the why part, which can't be explained in code, whatever your language is. Also, if your language is very limited and you've got no contracts, no static specifications and even no assertions, comments should cover the boundary issues of your code.
SK-logic
  • 8,497
One does not exclude the other. Even though your code is self-commented, there are times when you may need regular comments to explain why your self-commenting code does what it does.
gablin
  • 17,377
  • 89
  • 138
  • I think this falls into my opinion which was "code should be descriptive and mostly not require comment's unless the code cannot be self describing". If you write code which is while written well, doesn't full explain the intension of the code, then the comments aid in making the code more descriptive. – Phill Feb 24 '11 at 13:19
  • Code can *never* explain its purpose. When you see a hammer, you can't figure out what is it for - is it for smashing skulls or just for forging a raw iron. – SK-logic Feb 24 '11 at 13:29
    @SK-logic: `public void hit(T item);` – Michael K Feb 24 '11 at 15:38
  • @Michael - exactly. How the user will figure out, what categories of objects can and should be hammered? Even with a much better type system it is not always clear, what range of possible uses is actually planned by a developer. – SK-logic Feb 24 '11 at 15:49
I disagree with that article and agree with you to some extent. If you use good method names, good variable names and small method that do a single thing, the code should be simple to follow.
Just try not to be clever because clever code is horrible read and maintain. Keyword: maintain!
My opinion is that comments should describe the why and not the what. Remember in this hypothetical perfect world, your code is clean enough to allow for easy reading, you don't need to explain what it's doing, but why you chose to do it this way or that way.
If you're using a source control system, you can use the commit message to let everyone (and yourself) know what you did at a given time and more importantly, why.a
You would want to avoid writing comments just like you would want to avoid any documentation. When it comes to the programming language itself, everyone is operating from the same set of vocabulary and syntax (almost).
When your app is for a particular domain, it can be difficult to get everyone involved to agree on and/or establish a common vocabulary. We're taught to avoid abbreviations and extensive jargon, but I'm going to call it
EBITDA
and not
EquityBeforeInterestTaxesDepreciationAndAmortization
If you don't know one, you probably don't understand the other. If the company has some uncommon implementation, a comment would help the next programmer who may have experience in the domain, but not this particular firm (Which just makes things more complicated.).
JeffO
  • 36,816
  • 57
  • 124
I think we need to distinguish between documentation and expressivity of the code.
When debugging or reviewing code, you're not reading a book. Most of the time you just want to jump from method to method and make quick connections in your mind to get a basic understanding of what's going on at runtime. It's not the documenting around the code but the expressivity of the code signatures that matters in that process, their ability to be meaningful enough that you can immediately identify them and add them to your own internal call stack. At that point, our brain (at least, mine works that way ;)) tends to consider large comment blocks as a noise rather than a help. Therefore, one-line comments, or even better, just self-descriptive method and object names are sufficient here.
If you want to "read the book" of a particular class or feature, a much better place for that is in the unit tests. Well-designed unit tests are by nature intention-revealing and much more documenting (ie explanatory, detailed) than the thickest of comment blocks since they contain 1/ the expectations on exactly what this code is supposed to do and 2/ the ability to check these expectations against the real code. A passing test is a hundred times more reliable than any comment in terms of documentation, because it proves that what it asserts is true.
guillaume31
  • 8,358
Some code just is not self-documented, and requires some commentary from a fellow human who understood and tested that piece. What I have below just is not enough to understand it, I think.
// iterative version
Node* ReverseList( Node ** List )
  Node *temp1 = *List;
  Node * temp2 = NULL;
  Node * temp3 = NULL;
  while ( temp1 )
    *List = temp1; //set the head to last node
    temp2= temp1->pNext; // save the next ptr in temp2
    temp1->pNext = temp3; // change next to privous
    temp3 = temp1;
    temp1 = temp2;
  return *List;
Job
  • 6,459
  • 32
I generally favor writing self-documenting code, with comments where unclear, since I think most code will not completely document itself.
Abbafei
  • 821
I believe in the mantra that code does not document itself, because you could be the best programmer in the world (Ada), and yet don't understand a thing about what is going on, but if you document why and in a short extent how your code is doing what it does, your going to help yourself and others in the future.
Coyote21
  • 437
Comments are a must have. Because when you write code, you are writing for your current needs, but also for the people in the future who have to read your code, figure out wtf, are you doing, and why, and then how to make modifications for it.
If you just keep this in mind, when coding/programming?
How can i make this easier to understand and modify for future coders of this code I am working on, then you'll be doing a good job. Failing that, your just making it hard for others to modify your code, and don't imagine that never will be the case, that's rare...
At most of my job's, I have had always to modify other people's code, and most horribly written, poorly documented.
So your habit of thinking the code document it's self, is just not doing due diligence.
As programmer's we must practice the self-discipline that may appear to be totally a.r. to inexperienced programmers, but must have habits, to avoid all the horrible experiences we've had with other people's code. Or even looking at our own code months, years later.
Check out http://thedailywtf.com they have tons of humorous but real stories about programmer's who just didn't do their due diligence..
crosenblum
  • 997
This is why "code review" was invented.
The problem is that you - when you write the code - have a mental envisioning of what you work with, that will be gone in a while. Hence if you could ask your future self if you have documented enough of what you have in your head to reestablish this later, that would be the best.
Until we invent time machines, the best substitute for your future self is a colleague, so let them have a look and if they think they can understand what you do well enough to let them maintain it you are fine. If not, you refactor and document until they do.
As all these answers show, you cannot set up rigid rules for this. Some things simply need better explaining than others.
At university we were taught to pretty much rephrase every line of code in English with a comment (probably just to get us into the habit of understanding what code actually does, rather than just copy/pasting something and hoping for the best).
Personally, I reckon that clutters the hell out of your code, making it less readable than if it were just comments or just code. I'm a C# coder and the only comments I make all the time are the "triple-slash" comment blocks that are interpreted back to IntelliSense documentation. If I'm feeling especially guilty about a particular way of doing something, orit looks especially cryptic, I'll give a further explanation, but that's about it.
IMO: Self-documenting code is code where variable and method names are given meaningful and contextual names, so that they describe what their purpose is.
James Love
  • 819
If you have revisited your code multiple times and still not have found a way to make the intention clear to some one who knows the domain. Rewrite the function. After all it's no more than 10-20 lines. If it is longer rewrite the function anyways it's to long and that's part of why it's unreadable :) rinse-repeat
and in the unlikely case it's still unclear what the code is doing and you've remembered to ask your peers for help. Well then We all thank you for helping evolving Linux cuz it is kernel code you're writing right? if not rinse-repeat from the top :)
Simply put don't write you're comments CODE them
Rune FS
  • 314
Check out Code Complete 2nd edition, pg 128-129.
Abstract Data Types will save you from this conundrum. Self documenting code is the way to go. Comments can be useful, but having
real-world entities rather than low-level implementations
you're able to avoid using comments.
One thing about comments is that you write them once, but you don't see them when you implement the function, you only see them when you change the function.
Comments are really useful when they're interpreted by the IDE the way Delphi 2009+ or JavaDoc works, but that's more of a structured markup language, so in a sense you're programming your documentation, which is very smart.
Peter Turner
  • 6,897
  • 57
