I'm trying to come up with a good name for a data access object that executes non-query SQL statements. I know DML is a valid term, but I wanted to make sure it is the best.
Right now we have OracleNonQuery, but I'm hoping to find something better.
UPDATE: OracleDML or OracleDMLStatement are good suggestions. I'll probably go with one of those unless someone has a better term.
Jordan Parmer
  • 203
Just call it a statement. Then you can have an enumeration of statement types: OracleDMLStatement, OracleDDLStatement, and just OracleStatement. If it's an actual piece of PL/SQL you could have OraclePLSQLStatement, but without an example, it's hard to suggest much else.
FrustratedWithFormsDesigner
  • 46,105
  • 126
  • 176
DML and DDL covers all of it. I'm just looking for name suggestions that imply a statement that isn't a query.
I wouldn't conflate DML and DDL into "Statement" or some other single term.
I'd keep things separate and call non-query DML "DML".
There are three sublanguages of SQL that have separate purposes and conflation is a potential issue.
No end-user-oriented application should execute DDL (or DCL) for that matter.
It should be doing DML Statements only. And non-query DML is -- well -- still DML.
Other admin applications may do DDL or even DCL. Because that's so very separate, I'd stay away from "Statement" and use DDL or DCL.
I think the tree looks like this.
  • DML insert, update, delete
    • Query, i.e., the SELECT statement, a subclass of DML.
  • DDL create, drop
  • DCL grant, revoke
S.Lott
  • 45,264
  • 90
  • 154
  • You are correct. I should have not have said DDL because we aren't allowing those. DML is all we are doing. I'll modify my question to exclude DDL. – Jordan Parmer Feb 17 '11 at 17:09
You are not creating a DAO to access an oracle database. You are creating a DAO that accesses an Oracle database to solve a problem. Describe the probelem in the name of the DAO. For example, you might create a TpsReportReaderDAO to read TPS reports. Another example is, FlammyJammyHootyDAO might be used to apply Flammy Jammy to Hooty.
Summary: Use meaningful names; Oracle is the tool not the purpose. I don't use a Metal headed, wood handled tool to drive nails, I use a Hammer.
DwB
  • 672
  • Actually, the goal is to create a generic DOA that wraps a nice OOP pattern we are using. This object abstract the database plumbing and will be used by our data tier. – Jordan Parmer Feb 17 '11 at 23:02
