I work in a small sized software/web development company.
I have gotten into the habit of optimizing prematurely, I know it is evil and promotes bad code, but I have been working at this firm for a long while and I have deemed this as a necessary evil.
It has never caused me an issue so far in the past, but it might if I get partners or a successor.
Should I change my current practice now to prepare for that case, or should I not worry about it?
MattyD
  • 2,285
    Are you optimizing prematurely or are you just a good programmer? – Jeremy Feb 08 '11 at 02:45
  • I like to think I'm a good programmer, but I just get lazy. I'd like to do 'best-practices' and what not but I don't see the point if it causes no issues for me or if noone else will be using my code – MattyD Feb 08 '11 at 02:50
    What's an example of when you optimized something prematurely? – rreeverb Feb 08 '11 at 03:24
  • The thing is I'm the sole developer here and as long as the program works that's all they care about. I still have a passion for codes and 'good code' but my whole life has been spent on doing the bare minimum and scraping through – MattyD Feb 08 '11 at 03:29
    As @rreeverb says, I really think we need to see an example to really know how to answer this question properly. – Dean Harding Feb 08 '11 at 05:36
    Did I miss the long-winded speech? – Marcie Feb 08 '11 at 16:17
    See [this answer](http://programmers.stackexchange.com/questions/75390/why-should-i-care-about-micro-performance-and-efficency/75466#75466). – Mike Dunlavey May 11 '11 at 12:58
  • DOn't call it optimizing - just call it refactoring, and it's ok. – Ingo May 11 '11 at 14:18
    The word "premature" carries bad connotations, and the definition means "too early", so, yes, if it's premature, then it is bad by the definition of "premature". If you optimize early, but have compelling reasons for doing so, it is not premature. Perhaps your question would be better phrased as "When is it appropriate to optimize early?" – Mike Samuel May 11 '11 at 17:14
  • If you know that an area of code will be a bottleneck ahead of time, and the resulting code change is relatively simple and clear, than there is nothing "premature" about it. – Ed S. May 11 '11 at 21:20
  • This has to be a duplicate... "Always" type questions are always answered with "it depends"! ALWAYS! – Mark Canlas Jun 19 '11 at 15:14
8 Answers8
14
IMO, 'optimising prematurely' is only bad if reduces readability. Programming tends to be a write-once read-many activity, and if your optimisations make the code significantly harder to understand then I would be concerned.
I would take a guess that the effort required to refactor your code would not be worth the benefits (in business terms), but its amazing what the odd comment does to enhance code clarity. This is especially true for 'unusual' code (i.e. the optimisations your are concerned about).
GavinH
  • 666
  • Well I'd be the only person viewing the actual code, just my concern was if I get replaces or another team member it could cause issues. – MattyD Feb 08 '11 at 03:33
  • If you are concerned, I'd go through parts of the code you know to be a bit hairy and add some explanatory comments. Not line-by-line 'create a new object' or 'add 4 to x' comments, but a few paragraphs to give an overview of what's happening. – GavinH Feb 08 '11 at 03:43
  • That sounds like a good plan! Hopefully I can get back to the roots and stop being a tool ;) – MattyD Feb 08 '11 at 03:45
  • If only there was somewhere you could post some examples and get feedback on how readable or otherwise they actually are... http://codereview.stackexchange.com – glenatron Feb 08 '11 at 11:36
    optimizing premature is not only bad if it reduces readability. If I spend two days optimizing an obscure part of my program that is hardly ever used, I've wasted my employer's money. You should always profile to figure out where you need to optimize before you optimize. – Malfist May 11 '11 at 13:17
  • There is a form of optimizing prematurely which does not seem to reduce readability at first hand, but will produce issues on the long term and so is very bad: introducing redundant variables. Though the code *seems* to be readable, you run into problems when trying to change or extend it later, when there is more than "one single source of truth". – Doc Brown May 15 '12 at 13:27
12
Although this question has been answered IMO biggest drawback of premature optimization is the time wasted both initially while optimizing without having the necessary performance information as well as (frequent) rewrites because while focusing on optimization the implementation has gone askew. Again IMO I think it is not a good programming practice.
Gaurav
  • 3,729
  • 43
    +1 - don't waste time optimizing unless you are absolutely sure it's necessary! – ozz Feb 08 '11 at 09:07
    +1 don't waste time optimizing unless you know you are -really- optimizing. If it's not a good, solid optimization, then it may be counter-productive. Focus on writing good code first. – Bill Feb 08 '11 at 17:48
Sounds like what you call optimising is what I call cutting corners.
If it truly is optimising, then there is only one answer: document it well.
If it is cutting corners, then it really is up to you to see where the benefits outweigh the risks, be prepared to justify, or change that habit if it is not justifiable (in your own view... until you get involved with others and then use peer review as your measuring stick).
asoundmove
  • 1,667
    hmm... yeah, I don't understand what optimizing has to do with him being lazy and "I'd like to do best practices but don't see the point...". – ozz Feb 08 '11 at 09:09
When talking about microoptimizations, looking to squeeze every last nanosecond out of that for loop, it often isn't worth your time. When working on a web/database application, make sure your database interactions are more or less optimal, but more importantly, make sure they'll scale. Unless you're working on very high-performance code, scientific data processing or some such thing, other procedural optimizations won't help you much.
Michael
  • 1,327
Optimizing without profiling is always wasted time & energy. Shooting in the dark. Voodoo stuff. Bad.
Before optimizing do profile and/or analyze to make sure that:
  • You do actually have a performance problem
and
  • You know where the bottleneck is
Don't try guessing. Measure twice, cut once.
And after optimizing, profile again to make sure you solved the problem.
Maglob
  • 3,839
  • Well, I once had this screen someone else wrote that tool about 60 seconds to open. I optimized it so it took less than 2 seconds. I didn't need to profile anything. – Scott Whitlock Feb 08 '11 at 17:09
  • @Scott Whitlock: Good for you :) I did mention "or analyze". At least you took some measurements before and after to verify results, which is good. And if you knew (?) from previous experience (on that software/screen) that 60 seconds is way too much, you did knew that a) you do have a problem and b) where it roughly is. – Maglob Feb 08 '11 at 17:24
    This is absolutely wrong. Profiling is a great tool, but it's entirely reasonable to say that you know what the critical path of your code is going to be, and to optimize that to an extent as you are developing. Granted, at first pass this should be mostly relegated to design and algorithmic concerns, and the low-hanging fruit of implementation level optimizations, but it's quite naive to just go about writing without a care in the world for performance until after you start profiling. – Cercerilla Feb 08 '11 at 19:05
  • @CodeninjaTim, I don't think he said, "pay no mind to performance while writing code." He said to profile before optimizing. There is a difference. For example, I know not to write a loop that does everything twice, but is that optimizing if I write it so it doesn't? I don't think so. – Malfist May 11 '11 at 13:20
    @Malfist, but where do you draw the line? The whole "profile before optimizing" mantra seems tautological when you simply stop considering anything you'd do before profiling to be optimization. – Cercerilla May 11 '11 at 14:41
In small shops many developers are also the designers and analysts. When you have a bigger picture (did I just say that?) of the problem, we are more likely to plan ahead. If it performs poorly, it's a direct reflection on you since you're the only programmer.
Narrowing your estimation time can be a little trick to cause you to speed up and stop any unnecessary development. Any kick in the pants will do.
JeffO
  • 36,816
  • 57
  • 124
To Your current state
It always worked for You to do it? "If it is not broken, don't fix it" is another golden rule which I should stick to more. It caused me lot of headache when I did not stick to it. It can never cause You a problem, but who knows.
As has been said before "do the simplest thing that could possibly work". I found Pike rules on programming to be very enlightening.
What to consider
I assume You mean mostly speed optimization. Because there is also optimization for readability, size ...
Premature optimization is always bad, because:
  • It takes time to optimize. You might have spend this time by making something better; for example, calling Your girlfriend;).
  • Optimization usually means making things more concrete.
  • It will most likely be unreadable to other programmers. Every programmer should know simple algorithms so if there is something more complex he will waste time puzzing on what it means; he will be thninking low level, parsing more information and quite likely making errors in understanding Your optimized code.
  • It has been said by Donnald Knuth, which is the authority for programming and if he claims something is some way it is almost certainly so.
  • You have to measure first where is Your system slow and THEN optimize. Not the other way around. For example Quake engine used string compare O(N) to lookup variables instead of hashing O(1), it used scripted language Quake C which took about 10 percent of it's performance and "famous" PVS is simple hashing O(1) with simple compression (visibility is precomputed, each section of world to each section therefore what objects are visible is obtained trough a hash map lookup and since such information is huge in memory it is compressed). Michael Abrash's Graphics Programming Black Book is full of "measure first"" examples and examples where he was wrong estimating what was problem (chapter 17
But premature optimization is not always bad, because:
  • There cases when, by optimizing, You can see better solution. But is is about more about a chance.
So You have to weight pros and cons of doing premature optimizations.
I think that, because we are all people You just have to burn Yourself few times with premature optimizations to stop using them.
user712092
  • 1,412
The Knuth quote is in a context where it is expected you write as good code as you can in the first place. The optimization part is where you give in on the good code to get an expected performance boost, by writing less clear code or do smart tricks.
This is usually not a good idea, as you rarely know when it will be needed ahead of time - this is the job of the profiler to tell you - so you end up with sub-optimal code without any benefit.
Note, that "as good code as you can" may be doing a normal amount of trickery which in your experience is necessary anyway, but then it is your job to document these things well for future you's.
It is my experience that compilers do a very good job of creating good code for good, simple code, but may be confused by smart code. Smart code has its place to work around issues (runtime or compiler wise) but do not overdo it.
