I could not find anything regarding this question except some lecture notes about game design and a book which describes something similar but not quite the same.
General Description
The approach is as follows.
There are two kinds of state in an application: Core State and Derived State. The Core State is any state that cannot be readily derived from other state. The Derived State is any state that is not core. As a trivial example, if you have N bananas and M apples, you can easily calculate how many fruits S you have with S = N + M. Thus N and M is core state, and S is derived.
The main application components are Data, Systems and the Main Loop.
Data is represented as a single struct, that contains all of the core state of the application, publicly accessible. All fields within this struct should ideally be primitive types, PODs, generic collections (a hash set, a list, etc.) or utility types from the standard library (e.g. Option and Result in Rust).
A System is a function that is called in the Main Loop. It must never return any value and instead mutate the values, which are parts of Data, passed into it and must never call another systems directly. The second requirement means that systems can only communicate by modifying Data (or shared private state when grouped in a class).
Systems can be grouped into classes with private state, which should ideally be Derived. Instances of such a class are created before the Main Loop, the internal state must be initialized either during construction or in the Main Loop.
The Main Loop is simply the outermost loop inside the main function that keeps the program running. This loop must be located in the main function and not hidden behind a function call.
Example
A simple example that illustrates what the code written in this fashion may look like is given below. It is written in Rust but is not specific to it.
// Farm Data
#[derive(Default)]
struct Data {
pub keep_going: bool,
pub money: u32,
pub time: Time,
pub sheep: Vec<Sheep>,
pub cows: Vec<Cow>,
pub ducks: Vec<Duck>,
pub food: u32,
pub last_error: Option<FarmError>,
pub log_messages: Vec<Log>,
fn feed_ducks(ducks: &mut [Duck], food: &mut u32, last_error: &mut Option<FarmError>) {
for duck in ducks {
if *food > 2 {
*food -= 2;
duck.hunger -= 1;
} else {
*last_error = Some(FarmError::new("not enough food"));
// If you want to record logs, you must pass the array as a parameter to the place
// where it is needed.
// Using globals to push logs directly from any part of the code is discouraged
// as all application state should reside in Data.
fn sell_cows(
cows: &mut Vec<Cow>,
money: &mut u32,
last_error: &mut Option<FarmError>,
logs: &mut Vec<Log>,
// Sell the cows, get money.
fn buy_food(food: &mut u32, money: &mut u32) {
// Buy food to feed ducks (using money).
fn shear_sheep(sheep: &mut [Sheep], last_error: &mut Option<FarmError>) {
// Shear the sheep.
fn rest(logs: &mut Vec<Log>) {
// Rest
fn print_logs(logs: &Vec<Log>) {
for log in logs {
println!("{log}");
fn clear_logs(logs: &mut Vec<Log>) {
logs.clear();
fn check_bankrupt(money: u32, keep_going: &mut bool) {
if money == 0 {
*keep_going = false;
fn main() {
let mut data = Data::default();
while data.keep_going {
if data.time == Time::Morning {
feed_ducks(&mut data.ducks, &mut data.food, &mut data.last_error);
} else if data.time != Time::Night {
sell_cows(
&mut data.cows,
&mut data.money,
&mut data.last_error,
&mut data.log_messages,
shear_sheep(&mut data.sheep, &mut data.last_error);
buy_food(&mut data.food, &mut data.money);
} else {
rest(&mut data.log_messages);
check_bankrupt(data.money, &mut data.keep_going);
print_logs(&data.log_messages);
clear_logs(&mut data.log_messages)
My questions are the following:
- Can this way of structuring an application survive in the real world and be used for almost any application imaginable? What are its pros and cons (including the most obvious ones) for a game versus, say, a microservice or other application?
- Can any of the problems be removed if some of the constraints were lifted?
- Does this approach scale to larger (game or non-game) projects? Can it make them simpler than using the current best practices?
