We have an application that fetches user data from an Azure tenant via MS Graph. We need to distinguish between guests and regular members.
Guests come back with Usernames that look like this:
johndoe_agreatdomain.org#EXT#@mydomain.onmicrosoft.com
In our web application that actually displays this information, we need to transform that username to be a little more user friendly. So we change it to look like:
johndoe@mydomain.onmicrosoft.com
The question is where / who is responsible for this transformation. I'm trying to come up with a list of questions / factors that should be considered before making the call. And more than just an answer to this specific question, I'm looking for the broad principles / strokes that will apply in general.
The overall process would look like this:
a) pull data from MS Graph. This happens as a cron job on a daily basis. But we use their delta api so it's just a handful of records each time the job runs. The first time is the only time we will pull across the wire all 300,000 records.
b) save to local db (with / without a user friendly version of the username in the table)
c) expose methods in an API allows for reports about Guests (aka many records going across the wire at a time)
d) expose methods that allow look ups on specific users.
So far these are the questions I've been mulling over:
- how many records are we talking about? 300,000.
- how often are these reports run? If it's really often then instead of transforming each time, it's smarter to save in the database.
- how expensive is the transformation? Doesn't seem to be expensive at all. We just strip out everything between "_" and "@"
I'm tempted to say the database should be client agnostic and just save the data as we get it from graph. And .. we shouldn't "care" about front end display requirements. But the counter argument is that if this is the way the front end will "search" for users and talk to the back end about users, this isn't just a front end problem.
How do we calculate how expensive these transformation are? What would be a good approach?
Last comment.
If we did it dynamically i would likely add a view model in the application layer for this specific domain context. Or I was also thinking about implementing a specific response object in the API layer that does the transformation just before passing it along.
If we did it in the database, I would just add another column to the table to be the user-friendly version of username.
Any comments would be appreciated.
