In this answer, I'm going to use SLA to mean the maximum amount of time that a downstream system can be behind the primary source.
There are basically two options here:
- Downstream systems poll for data on a frequency smaller than the SLA (e.g. 2 times per SLA period)
- You detect changes and alert the downstream systems
The first option is definitely the simpler one. It's also the easiest to make robust. Unless you have a really large number of downstream systems, I can't recommend doing anything else without some other mitigating circumstance that you haven't mentioned. As @DocBrown notes in the comments on @Hans' answer, you can implement a HEAD
operation which provides the last time the data was updated. This will minimize the cost of these polling calls. The clients then, just need to keep track of which update they have successfully processed. It's important that you don't change the last update date-time until you have fully processed it. This will make your updates more robust. Downstream applications should also have account for being repeatedly unable to handle a given update. I recommend at least 2 checks in each SLA time period. If you only check once, even a simple networking hiccup could result in missing the SLA.
If the volume of these checks is too high (unlikely) then the only thing that really changes is that you need to notify clients. There are many options, they aren't that hard to implement if you've done it before. The trick isn't getting them to work, it's making them robust to errors. The most likely failure mode is that they stop receiving updates. I'm going to guess that you don't need this and if you decide you do, the details are outside the scope of this question.
