A simplified version of my code looks like this:
def process( object ):
try:
if suitedForA( object ):
try:
methodA( object )
except:
methodB( object )
else:
# we would get a bad result from methodA()
methodB( object )
except:
methodC( object )
Edit: Removed error in pseudo code pointed out by @gnasher729.
I would like to avoid the repetition of methodB()
. It may look not as bad in above pseudo-code, but in actuality, these are library calls with a bit of post-processing.
Edit: methodA/B/C()
may fail without me being able to tell when. This is independent of suitedForA()
The following code avoids the repetition, but I am not sure if it is a good idea to throw an exception for this case:
try:
if not suitedForA( object ):
raise NotSuitedException()
methodA( object )
except:
try:
methodB( object )
except:
methodC( object )
Is there a simpler approach to achieve the same without the repetition and without actively throwing an exception?
