coders. I'm learning C programming language and found out such thing as #define
directive that allows us to use symbolic constants (following Brain Kernigan). I know that this directives "insert" literals or expressions right into code. Their purpose, as I understood for now, to get rid of magic numbers in a code. Also I found out that #define
directives also can't be accessed out of the scope they were declared. That fact makes their usage is very similar to classic variables. My questions to experienced programmers is "What and when should I use? What pros and cons of each mechanism?". At the first glance, I can use them interchangeably. Thank you.
Asked
Active
Viewed 170 times
CoderDesu
- 1,005
- 5
- 10
Do you understand that `#define` is a textual substitution, not a variable? – Philip Kendall Oct 31 '22 at 08:11
1I tried "C const define preprocessor" at Google, and found a lot of articles, like this one ["static const" vs "#define" vs "enum"](https://stackoverflow.com/questions/1674032/static-const-vs-define-vs-enum). – Doc Brown Oct 31 '22 at 10:06
You should never use the preprocessor to define symbolic constants. C has had the const
keyword since C90, which does the same thing and makes your intent clearer. It also provides better scoping (preprocessor definitions always have file scope, while normal declarations have the scope you'd expect from their location).
Kilian Foth
- 107,706
- 45
- 295
- 310
2I feel uncomfortable with equating `const` and `define`. The const does not create a special kind of variable, it just creates a const-qualified type for a variable. The variable still names an object with an address, and may be initialized at runtime. You can't use variables in some places where the C syntax expects literals. In contrast, C++ `constexpr` does create true compile-time constants. – amon Oct 31 '22 at 08:40
Use "variables" (as const
objects) when practical.
Better type control.
Use symbolic constants in select cases.
Examples:
*scanf()
width control
Consider reading into a buffer of some fixed size via *scanf()
to form a string. "%s"
deserves a width, like "%79s"
to prevent buffer overflow. Rather than a magic number in the format, derive the buffer size and width via a #define STRING_LEN_MAX 79
#define STRINGIFY(x) #x
#define TOSTRING(x) STRINGIFY(x)
char buffer[STRING_LEN_MAX + 1];
if (scanf("%" TOSTRING(STRING_LEN_MAX) "s", buffer) == 1) {
puts("success");
Values meant for macro processing
chux - Reinstate Monica
- 618
- 3
- 11
