Usage Standpoint
Most of the time from a usage standpoint, I think our predominant concerns in reasoning about a codebase is concerned with write patterns, not reads. So even a queue or stack which provides read-access through the entire container via iterators often still provides the lion's share of the benefits of reasoning about code using it, as it offers the guarantee at a glance that we won't suddenly finding elements being removed to/from the middle, e.g. There's a great deal of clarity to be found in merely constraining write ability.
But at least in my domain, it often has little benefit to clarity and often serves as a hindrance if a queue or stack structure fails to provide the ability to iterate over its elements for read-only access. Many of our use cases involve building a stack or queue and then, after we're done building it, iterating over the results and treating it like a read-only sequence (often even a random-access sequence we read in a parallel loop which is impossible to do with the container if it can only read in serial FIFO/LIFO patterns without popping everything off of it first and transferring the results to a random-access container).
That's a very common case requirement in what I've encountered at least and not an obscure one. So to have to, in such use cases, build a queue or stack and then read and pop each element until the container is empty tends to be quite inefficient both for the programmer and the hardware; it also turns what could otherwise be a read-only operation just wanting to read the contents of the container into a write operation which requires modifying it.
A Proposal of How To Think About It To Make It Feel More Right
To require popping to read the container is generally going to make the code harder to understand, not easier, with more places in your code superfluously modifying data it wouldn't otherwise have to modify and less code merely reading it for immutable access[*]. So even if it seems to feel wrong and a violation of LIFO/FIFO access patterns to provide iterators for a queue or stack when you can effectively provide them, I'd keep this in mind that you might be introducing more code needlessly mutating data in your codebase which can make it more difficult to understand, multithread, and test if you don't.
- Remember that it's mostly reducing writes in our codebase, not reads, that tends to add to the clarity of the code. Exchanging more write operations for less read-only operations when you're completely free to do either tends to be a counter-productive trade-off except possibly in some very obscure cases.
Implementation Standpoint
That said, as pointed out in the John Wu's answer, there are far more implementation reasons to constrain even the read access of a queue or stack even though I just tried to propose why it might often hinder usability.
As another example besides his, a concurrent queue or stack might -- in order to provide the most efficient and atomic LIFO/FIFO push/pops -- require constraining reads in a similar fashion. There the most efficient implementation might require the people implementing the write operations to be able to make guarantees about what the readers can't access as they are modifying the data structure. It's a lot easier to implement a concurrent queue or stack efficiently if we're guaranteed that user can only push and pop from it, not read from it in ways outside of popping off the top/front element.
So I think there are far more implementation reasons to limit reads as well to LIFO/FIFO patterns, but I don't think it adds that much clarity to most codebases to impose such constraints on the users when the implementation doesn't benefit from it. At least in most of the cases I've encountered, that would serve more as an obstacle than something that lets us reason about the code using the queue or stack more easily.
Abstraction Standpoint
Another thing to keep in mind though also in favor of constraining reads is for generalized code where you might have a variety of queue/stack implementations offering the same interface. That common interface might only be able to provide a subset of what any single implementation is able to provide for them to all uniformly conform to the same interface.
