I came across a class that implements a kind of "strategy pattern" with a concrete implementation defined inside the main class as a template method.
#include <iostream>
struct ObjA {
    int a = 123;
struct ObjB {
    int b = 456;
class Algo {
public:
    void stratA(const ObjA& obj) {
        strat<ObjA>(obj);
    void stratB(const ObjB& obj) {
        strat<ObjB>(obj);
private:
    template<typename T>
    void strat(const T& obj) {
        std::cout << "Start" << std::endl;
        print<T>(obj);
        std::cout << "End" << std::endl;
    void print(const T& obj);
template<>
void Algo::print(const ObjA& obj) {
    std::cout << obj.a << std::endl;
template<>
void Algo::print(const ObjB& obj) {
    std::cout << obj.b << std::endl;
int main()
    Algo algo;
    ObjA a;
    ObjB b;
    algo.stratA(a);
    algo.stratB(b);
    return 0;
Is it a known pattern of should this be considered bad practice?
The strategies and their usage being known at compile time, the main goal I guess is to avoid indirection and hide template abstraction to the user of Algo class.
Delgan
  • 366
    Aside: you could make `strat ` public, `stratA` and `stratB` aren't needed because template arguments can be deduced – Caleth Oct 13 '22 at 13:27
0 Answers0
