You can't simply look at LOC/SLOC by itself the way you are trying to. The only way you can use LOCs with some degree of success (and as a guideline, not as an infallible rule) from previous projects to estimate future project sizes is by having a decent number of projects with their SLOC, number of resources (developers) and time of completion accounted for. Then you can use that to extrapolate.
But to take just one project, one single project, specially one that is not that big (1K is fairly small), that's just too little data to use LOC metrics in any meaningful manner.
If this is a homework, your professor is a clueless dick btw.
However, if this is for real, and if you are really that pressed, you could use the following guidelines:
EXPECTED_COMPLETION_TIME =
( PREVIOUS_COMPLETION_TIME / PREVIOUS_KLOC ) * EXPECTED_KLOC * SPILLOFF
With SPILLOFF = 1 giving you a 30% chance of success (a 70% chance of failure), SPILLOFF = 1.5 giving you a 60% probability of success (a 40% chance of failure) and SPILLOFF = 2 giving you a 90% chance of success (a 10$ chance of failure.) The reason for using such estimates is that failures in completing software projects tend to exhibit an exponential distribution with respect to the allocated time per time allocate (or whatever other resource you choose to use.)
When you have consistent work within an organizations or when you work in similar environments, and technology (not just the language, but the technology) as well as processes are uniform, then you can do some estimations with some margins of errors based on prior projects. In such cases, you want to give more weight to the most recent projects.
Say, for the last n + 1 projects (say n + 1 = 5 or 10... notice, it's n + 1, not n), you could do the following but only if you carefully keep track of the number of people involved in a project, actual number of LOC, actual completion time, and estimated completion time as estimated prior to the start of the project.
SUM = 0
FOR i = 1 to n
KLOC_PER_HEAD(i) = KLOC(i) / TEAM_SIZE(i)
ACTUAL_COST(i) = ACTUAL_COMPLETION_TIME(i) / KLOC_PER_HEAD(i)
RUNOFF(i) = ACTUAL_COMPLETION_TIME(i) / ORIGINALLY_ESTIMATED_TIME(i)
SUM = ( ACTUAL_COST(i) * RUNNOF(i) ) + SUM
END
LAST_COST = ACTUAL_COST(n+1) = ACTUAL_COMPLETION_TIME(n+1) / KLOC_PER_HEAD(n+1)
LAST_RUNNOF = ACTUAL_COMPLETION_TIME(n+1) / ORIGINALLY_ESTIMATED_TIME(n+1)
LAST = LAST_COST * LAST_RUNNOF
ESTIMATE = ( ( (SUM / (n + 1) ) + LAST ) / 2 ) * SPILLOFF
With SPILLOF as defined previously.
