Judging by this description, you're looking for the visitor pattern:
My only idea left is for the piece itself to call the method but then I either have to wire in the PieceService to each Piece, create a new one upon each call (the service has no dependencies), pass the service to the method, or change PieceService from a @Service class to a static class. What's the best practice here?
I assume you currently have a design like this:
abstract class Piece { ... }
class Queen extends Piece { ... }
class Rook extends Piece { ... }
class PieceService {
public Moves calculateLegalMoves(Queen q) { ... }
public Moves calculateLegalMoves(Rook r) { ... }
public Moves calculateLegalMoves(Piece p) {
if (p instanceof Queen) return calculateLegalMoves((Queen) p);
Indeed, you can solve this problem by having each Piece call the PieceService. But, with the help of an additional class, you can do this without creating a direct Piece→PieceService dependency. The idea is that we introduce a PieceVisitor
interface for classes that want to do different things to each piece. Then we'd have to write the following one-time boilerplate:
interface PieceVisitor<R> {
// the methods could all be called visit() and use overloading,
// this doesn't matter
R visitQueen(Queen q);
R visitRook(Rook r);
public abstract R accept<R>(PieceVisitor<R> v);
public R accept<R>(PieceVisitor<R> v) { return v.visitQueen(this); }
public R accept<R>(PieceVisitor<R> v) { return v.visitRook(this); }
Our PieceService could then implement the PieceVisitor interface. For clarity, I'll call it LegalMoves
instead:
class LegalMoves implements PieceVisitor<Moves> {
public Moves visitQueen(Queen q) { ... }
public Moves visitRook(Rook r) { ... }
// convenience method for invoking the pattern:
public static Moves of(Piece p) { return p.accept(new LegalMoves()); }
As to the idea that “models should not contain business logic” – eeh. There's a good debate to be had here. When you have a large matrix of behaviours × objects, both approaches to organize this code can be reasonable: grouping it by object, or grouping it by behaviour.
Classic OOP tends to favour grouping behaviours together with the objects on which they operate (like adding a calculateLegalMoves()
method to each piece).
Other approaches such as functional programming or “anemic design models” tend to favour simple data definitions without behaviour, meaning that behaviours are provided outside of the class. The aforementioned visitor pattern makes it possible to keep (some) behaviours outside of an object hierarchy in an otherwise OOP-ish design.
Both of these approaches can be valid, but they enable extensibility along different dimensions. Grouping behaviours into each object makes it easy to add new object types, but difficult to add new behaviours. Keeping behaviours external makes it easy to add new behaviours, but difficult to create new objects.
Since chess features a fixed set of pieces, it is unlikely that you'll need to create new types of pieces. In contrast, it is likely that you will want to extend your chess engine with new behaviours. This would be a weak indication that classic OOP modelling wouldn't be a great fit, and keeping behaviours in service classes/visitors/anywhere else could be part of a good design.
It is worth noting that modern Java has increasingly good support for dealing with such closed object hierarchies. This example could also be written as follows, using sealed classes + pattern matching instead of a manual visitor implementation:
sealed class Piece { ... } // can only be extended in current file
class LegalMoves {
return switch (p) {
Queen q -> ...;
Rook r -> ...;
// no "default" case needed
