choose between stdout and stderr depending on the levels (e.g. info and weaker to stdout, warning and more severe to stderr)?
This. Unless there's a good reason not to I like stderr to get errors. This is customary expected behavior.
When making this call simply pretend that the level logging system doesn't exist. Send the log message where you would have sent it before. Nothing in a level logging system justifies changing the meaning or use of stderr. If you use it, use it right.
A case can be made that warnings don't belong in stderr. A warning is a potential problem but doesn't indicate that anything the system was asked to do hasn't been done. Understand that some sys admins monitor stderr for any text at all and configure automated responses to it.
The stdout and stderr custom is to directly hard code those destinations / concepts into your app and configure where they go on the command line when the app is run (be that, console, file, etc).
The logger custom is to directly hard code logging levels into your app and configure where they go, and if they go, in a logging configuration file that is aware not only of the log level but what logger was used to send them. This configuration also controls where they go (stdout, stderr, file, etc).
They can be configured to work together just fine. The difference between them is that configuring stdout and stderr output at the command line is a 30 second google search. Configuring most logging system with logging levels involves planning. Even if all you want to do is make it work like the old school stdout and stderr.
The reason planning is needed is the flexibility. Log level tools let you make noisy things shut up when you don't need them and bring them back when you do. It also lets you chose which things to do this to. All without touching code.
With stdout and stderr all you get is two buckets and a choice of where to dump them.
So you combine them by configuring the logging tool to wisely target the most appropriate bucket (stdout or stderr) for the log message. Not that you must use either std bucket. But if you use them then people who know how to use the std buckets, and don't feel the need to mess with logging levels, will appreciate not having to touch that confusing config file.
