For .NET, there's an app called Tree Surgeon that lays out a dev tree for .NET projects. It's kinda dated and I'm not sure how much of a standard it is, but it's an interesting starting point.
For my own projects outside of .NET, I tend to set up a folder for source, a folder for tests, and a folder for third-party libs that I depend on. There are often subfolders under each to allow for grouping by feature or namespace.
In .NET, I allow Visual Studio to organize itself and create a folder for the solution and then a folder per project under it, although I sometimes corral test projects into a "Tests" subfolder. I still create the "lib" folder for third-party dependencies and it typically goes under the main solution folder.
For web projects you can also look at frameworks such as Rails, Django, etc.
In general, when you consider the source layout, make sure you're not going to end up fighting the tools you use in order to maintain it. Some frameworks enforce layouts (Maven, Rails, etc.) and you can't do much about that. In some cases going against the flow would be merely an annoyance (as in Visual Studio), but it'd be a persistent annoyance that you'd have to deal with daily.
