-1
I had to create an ASMX web service for my company. Even though ASMX is old, I tired to do everything according to modern standards. So I have a UI layer (web service layer), business layer (service layer) and a data layer (for talking to the database).
However, I cannot get DI to work ,and I don't think it's worth the trouble trying to get it to work. Given that I am not using DI, is there any point in making my Service classes non-static?
Having to "New" a service class every time is quite annoying, and I can see a maintainer (or myself) forgetting to do this and then getting the null reference exception.
user648336
  • When you make something static, you can no longer (easily) test the client of that thing in isolation. – Rik D Mar 28 '22 at 05:53
  • Use service locator pattern with your favorite DI framework in your UI layer and resolve next layers through it... There generally should be no code in UI layer of web service (just return JSON version of response from "service layer") - so should not impact ability to test much. – Alexei Levenkov Mar 28 '22 at 06:28
At a push; if it's stupid and it works, it ain't stupid. Sometimes, you are severely limited in your options and if this is the only option that you're able to implement and it does what you need it to do, then sure.
That being said, I'm hard-pressed to agree that this is the better route to take here.
The "modern" standard you're referring to here is one that was already well established back in the ASMX days. That's not to say that there haven't been implementations where layers were not correctly separated, but this basic layer separation is not somehow more modern than ASMX itself.
If your sole concern is the annoyance of having to instantiate objects; that's IMHO not a good enough to reason to make this level of good practice shortcut. You're bringing a lot of negative side effect to the table and you're not getting anything meaningful in return.
I infer from this that you are not testing your code. That is a much bigger and more important fish to fry.
By using statics, you are also irrevocably closing the door to (unit) testing, as it renders you unable to mock your service. This is a detriment that far outweighs the benefit of "not having to new a service instance".
DI by itself isn't something you need. It doesn't directly deliver any of your software requirements.
However, DI is an approach that is fairly easy to implement and it enables/simplifies several good practice approaches that will directly impact your ability to deliver and maintain the software requirements. The avoidance of DI itself is not the biggest loss to your deliverables, but shutting the door to all those good practice approaches is a significant loss.
Summing it all up; it seems that you are working in a bad practice codebase. ASMX completely aside, it seems that there is tight coupling and no testing in your codebase, both of which are major red flags.
Your question then reads like it's asking for permission to double down (and permanently enshrine) these bad practices (or call it lack of good practices, if you prefer).
This will significantly impact the stability, maintainability and longevity of the project. I would consider these to already be compromised based on what I infer your codebase is currently like; but putting the statics on top of that makes it significantly harder to turn this ship around in the future.
Unless this project is already close to delivery and you intend for this project to reach its end of life very soon; the choice you're suggesting to make here will significantly hamper your future development efforts.
Really, really reconsider.
That being said, we cycle back to my initial point. Sometimes you're not given the freedom (time, budget) to do things the right way. It's not something a developer enjoys, but it's one of those facts of life that we can't always escape.
But if this is the case, and there is someone else who is putting up these boundaries, they need to be made aware of the consequences of those boundaries, so that they can make an informed decision, rather than a decision for ulterior (non-technical) reasons and forgetting to estimate the impact of that decision on the technical side of things.
Flater
  • 44,596
  • 88
  • 122
  • I don't have unit tests, but I do have integration tests. Therefore, i don't need to mock anything. – user648336 Mar 29 '22 at 01:15
  • @user648336: A lack of unit testing still isn't great. They don't replace integration tests, but they help identify which component fails (and why) when your integration test starts failing. – Flater Mar 29 '22 at 08:25
IMHO, making classes static just because you are not using DI is a bad idea.
This is an over-simplification but DI is basically a map of objects by type. And, as @Flater mentioned, you don't really need DI to make your application work.
Also, DI doesn't free you from designing and thinking about the dependencies of your components. And what you are suggesting tends to hide those dependencies.
As I also mentioned in this post, I believe it's a good idea to explicitly declare the dependencies of a class (via constructors). This means maintainers won't be able to "forget" as the compiler will enforce it.
Finally, I wonder how often do you really instantiate a class. I'd say you could put most of that inside a Factory of some kind.
freakmind
  • 85
