This is Arduino code, but since it uses C syntax, and it's not Arduino-specific, I thought I'd ask here. I have a few values defined so:
#define PID_RPM 0x0C
Typically it's used as a hex number. But in one spot, I need to print the last 2 chars ("0C") as literal 2 ASCII chars "0C". Right now I do it with a switch and an explicit string "0C":
switch(pid){
case PID_RPM: OBD.println("0C"); break;
How can I convert the PID_RPM define to get its last 2 chars as literal ASCII? Maybe, instead of using a define, use char variables to store the hex PID values, then format them as a string with sprintf?
