I was reading about composition over inheritance and came across a question about solving the Circle-Ellipse Problem in Object-Oriented Programming. This kind of problem is often used as an example of the limitations of OOP. I am from a C++ and Java, therefore heavily OOP, background, but I have struggled with trying to fit real-world scenarios into OOP so am well aware of the paradigm's flaws. Recently I have been learning Rust and Golang, neither of which have inheritance, but instead have mechanisms for composition, as does Python, which I have been using a lot in the last few years. Clearly this is the way modern programming languages are going, and going away from OOP!
In this StackOverflow answer, someone states that:
There is no programmatic problem you can solve with inheritance which you cannot solve with composition
though there is no source given for this assertion. I wonder if it is true? And to get back to my question: can composition "solve" the Circle-Ellipse Problem?
