What I try to solve:
- Given I run a set of microservices, most of which expose a RESTful API and additionally publish or consume events via messaging broker,
- and I have decided to go "API first" using OpenAPI and AsyncAPI to specify these APIs,
- when I design my the domain models,
- then ... should I create separate domain models for REST and messagin, or should I reuse the models from my REST spec within the events?
Pros and cons that I have come up with myself:
Pro:
- If the representation of the models is the same in REST and in messaging, the clients will understand it more quickly.
- I only need to write the spec once.
- There are no duplicate model definitions for REST and messaging, hence they cannot accidentally deviate from each other.
- I don't need to use the AsyncAPI generator, because all model classes are generated by the OpenAPI generator.
Con:
- AsyncAPI allows to
$ref
erence OpenAPI models because both are based upon JSON schema, but there is no guarantee that every OpenAPI feature will be supported within AsyncAPI as well.
AsyncAPI is still quite young, so...: Is there already a general best practice?
