We have function DoStuff. It can return Stuff or Error. What is the cleanest way to do this in C#? I know that it's best to throw in error case, but it has its own downsides. Also consider case where there are 2 logically different results, which are not errors. what then?
Important for me is that code is readable and robust (i.e. no weird cases when someone can return both success and result by mistake etc.).
Solutions I've found so far:
1. Throw an exception
 Stuff DoStuff() { throw new Error(errorCode); }
Pros:
  1. Easy to add new cases
  2. Can pass through multiple layers without altering other code
Cons
  1. Can be swallowed by accident
  2. You need to inspect function body or spec to see how it fails
  3. You need to define additional exception type which is nasty and takes lots of code to do properly
2. Use a container object
class DoStuffResult() {
    DoStuffResult(Stuff success) {...}
    DoStuffResult(Error failure) {...}
    public Success? {get;}
    public Error? {get;}
// Consumer
var result = DoStuff();
if (doStuffResult.Success != null) {
   Process(result.Success);
else {
   ReportError(result.Error);
Pros:
  1. Easy to see what may be there by inspecting container class definition
Cons:
  1. There are both Success and Error properties on single object.
  2. What happens when success returns null? You need enum and complexity increases
3. Pattern matching
interface IDoStuffResult {};
IDoStuffResult DoStuff() {
    if (x) { return new Success(); }
    else { return new Error(); };
// customer
DoStuff() switch {
   Success success -> Process(success),
   Error error -> Report(error),
   _ -> throw new ArgumentOutOfRangeException()
Pros:
  1. Cleanest code to read and write
Cons:
  1. Extra marker interface required
  2. More than two possible results visible
  3. It's not obvious how many possible results are there
Which solution is most readable and easiest to maintain?
Alexander
  • 3,562
Shadow
  • 363
    There is similar question focusing on exceptions https://softwareengineering.stackexchange.com/questions/250518/what-is-a-good-design-for-a-method-that-can-return-several-logically-different-r But I also wonder about more broad cases, not only exceptions. – Shadow Sep 01 '21 at 17:21
  • I think the example using exceptions conflates the point of the question. If you need exceptions, use exceptions. If you need multiple unrelated return types, the specific use-case may be relevant. Sometimes a container makes sense. Sometimes it makes sense to extract common denominators into an interface. And sometimes it just makes sense to go back to the whiteboard. – svidgen Sep 01 '21 at 17:51
  • I prefer a Result for this scenario. See https://softwareengineering.stackexchange.com/a/381673/320517 – Rik D Sep 01 '21 at 18:38
    I disagree with all the cons you attribute to exceptions. They can't be swallowed by accident, one has to deliberately write a catch all clause for that to happen, something CodeAnalysis will warn you about. Inspection of code to see what went wrong is not needed as you will pack all there is to know into the exception. Finally, creating new exception types is trivial. You do one properly (which will be readily available on the internet) and use that as a template to create your own. – Martin Maat Sep 02 '21 at 08:12
  • Can you clarify your question, please? In your title, you ask about returning *multiple results*, whereas in your question body, you consider returning multiple results "a mistake" ("no weird cases when someone can return both success and result by mistake"). So, which is it: do you want to return multiple results, or don't you want to return multiple results? – Jörg W Mittag Sep 02 '21 at 13:41
  • You can see response with tuples below. In that case someone can return both `Success` and `Error` in that tuple, however I would like to be able to return either of them, but not both. For instance exception satisfies this, becuase you cannot return and throw at same time, so does DoStuffResult because you can use one constructor at time, and so does pattern matching, because you can have only one result. – Shadow Sep 02 '21 at 13:52
  • I posted an answer to a similar question here, it uses empty interfaces to create Union Types in C# - https://softwareengineering.stackexchange.com/questions/409471/how-to-design-a-statically-typed-rest-api-client/409889?noredirect=1#comment902882_409889 – Graham Sep 02 '21 at 14:08
As usual, the one that eliminates the problem in the first place.
For C#, that tends to mean designing the code so that methods only have one (non-exceptional) return type. Sometimes that means a Result type that can be queried. It should not be exceptions that are not exceptional, or implementations of interfaces that violate LSP. Most times though, a simple design change can eliminate the need for this altogether.
Telastyn
  • 108,850
  • 239
  • 365
I like very much your pattern matching approach.
A pattern often used is the Try.. method returning a bool indicating the success and an out parameter returning the result
public bool TryDoStuff(out Stuff result)
    do_something();
    if (success) {
        result = some_value;
        return true;
    } else {
        result = default;
        return false;
You can use it like this
if (TryDoStruff(out var result)) {
    consume_result();
} else {
    handle_error();
You can add more out parameters if required. E.g. if two kinds of result objects are required:
public bool TryDoStuff(out Stuff result, out Error error)
    do_something();
    if (success) {
        error = default;
        return true;
    } else {
        result = default;
        error = error_object;
        return false;
A new possibility arises with the introduction of the value tuples
public (bool success, Stuff result) DoStuff()
    do_something();
    if (success) {
        return (true, some_value);
    } else {
        return (false, default);
var (success, result) = DoStuff();
Here also, you can extend it to return two different (or more) objects, where only one will not have the default value (null). The bool value is not necessarily required, as you can test which object is not null. You can also test the result with pattern matching.
    Tuples are arguably "the wrong way round", however. What you want is a *sum type*, but tuples are *product types*. They are exactly the dual of what you need. – Jörg W Mittag Sep 01 '21 at 18:17
    Yes, what we need is a sum or discriminated union or [Tagged union](https://en.wikipedia.org/wiki/Tagged_union) type which does not exist in C#. – Olivier Jacot-Descombes Sep 01 '21 at 18:24
  • We can add a tagged-union. To sketch it: `public abstract class Result { public abstract bool IsSuccess { get; } protected Result() { } public static Result New_Success( T resultValue ) { return SuccessResult.New(resultValue); } public static Result New_Fail( ) { return FailResult.New(); } } public class SuccessResult : Result { public override bool IsSuccess { get { return true; } } public T ResultValue { get; private set; } protected SuccessResult() { }` [...] – Nat Sep 01 '21 at 23:59
  • [...] `public static SuccessResult New( T resultValue ) { var toReturn = new SuccessResult(); toReturn.ResultValue = resultValue; return toReturn; } } public class FailResult : Result { public override bool IsSuccess { get { return false; } } protected FailResult() { } public static FailResult New( ) { return new FailResult(); } }`. – Nat Sep 01 '21 at 23:59
  • By having separate classes for successes and failures (`SuccessResult` vs. `FailResult`, both of which are `: Result`'s), we can avoid having to have an unused field in `FailResult` for a result-value. That said, in C# it might potentially be a bit heavy-weight to use multiple types, plus making stuff `abstract`, to achieve that effect. – Nat Sep 02 '21 at 00:02
    @Nat, The problem is that `T` will be different for the success and fail types. I.e., You end up having types derived from `Result` and a `Result` which are not assignment compatible. – Olivier Jacot-Descombes Sep 02 '21 at 11:57
  • @OlivierJacot-Descombes: `T`'s the same in both cases. The caller gets back a `: Result`; that `: Result` may be a `SuccessResult` or `FailResult`, depending on if the call succeeded/failed. If it's a `SuccessResult`, then it'll have a property `.ResultValue` with the result from the successful call; however, if it's a `FailResult`, it won't have such a property. – Nat Sep 03 '21 at 21:14
  • @OlivierJacot-Descombes: We can add some helper-extension-methods to make it convenient to use, too. Though I'd speculate that a tuple-like solution would generally perform better in prior C#-environments, even if they may address storage that'd go unused in the event of a fail. – Nat Sep 03 '21 at 21:15
  • There're a few other ways such a thing could be constructed in C#. I basically just wanted to point out that this could be done in C#, even if there wouldn't seem to be a strong call for it. – Nat Sep 03 '21 at 21:20
  • @Nat, the OP wants to return a `Stuff` class in case of success and an `Error` class in case of failure. So, what is `T` supposed to be? – Olivier Jacot-Descombes Sep 04 '21 at 15:52
  • @OlivierJacot-Descombes: Ah, then an `Error`-property can be added to `FailResult`. Or we could make it `Result`, with corresponding `SuccessResult<>` and `FailResult<>`. (I'm hesitant to be too precise in describing it because there's really a bunch of ways that this could be done.) In general, the idea'd be that we can avoid allocating space for unused fields (as in a tuple-like solution) by having an `abstract`-base with child-`class`'s that allocate space only for properties that they actually implement. – Nat Sep 04 '21 at 18:03
Let's first consider two well-known extremes.
Option types
An Option type is a type that encapsulates the notion that something may or may not exist. In languages that support Closed Algebraic Sum Types (aka Discriminated Unions aka Tagged Unions aka Variant Types), and Option type can be very simple:
data Option a = None | Some a
That is, an Option of a is either a nullary data constructor representing nothingness or a wrapper around a.
This Option type has a couple of interesting properties: it can be viewed as a collection that has either exactly one element or is empty, i.e. similar to a list of length at-most one. What this means is that you can use all the power of the collections library, and all the knowledge you as a programmer have about collections to work with these Options.
For example: you want to transform the value? Just map (in C# Select) the Option! You want to print it only if it exists? Just foreach it! You have nested computations all of which may or may not return a value and need to use the value of the previous computation? Just flatMap (in C# SelectMany) the Options and the result will either be the result of the entire computation if all of them return a value or None if any of them returns no value. In other words: Options are composable!
Everything you know from how to handle collections transfers directly to Options. Note that in the above examples, there was actually never any point where you would need an if statement or pattern matching or any other kind of conditional to check whether or not the value exists: if you foreach over an empty collection, then simply nothing happens, if you map or flatMap over an empty collection, you get an empty collection back. You can almost treat the Option as if it didn't exist, and it will just do the right thing.
More generally,Options are not just collections, they are monads as well, meaning you can use all the power of monads. For example, in C#, monads support the LINQ Standard Query Operators and can be used with LINQ Query Expression Syntax. You could write something like this:
var ultimateResult =
    from res1 in ComputationThatMayOrMayNotReturnAResult()
    from res2 in AnotherComputation(res1)
    from res3 in YetAnotherComputation(res2)
    select res3;
And the result will either be Some(res3) or None.
Option can essentially replace any method that uses the Try… pattern, e.g. int.TryParse(string).
Now, unfortunately, C# does not have Closed Algebraic Sum Types (although there are Github issues about that). But, it is possible to implement Algebraic Sum Types using nothing but simple rank-1 parametric polymorphism (aka Generics) and classical OO inheritance: the type becomes an abstract superclass and the data constructors become concrete subclasses.
In Scala, this looks something like this [Please forgive the large amount of Scala code, I don't really know C#]:
sealed trait Option[+A] {
  val isPresent: Boolean
  def getOrElse[B >: A](default: => B): B
  def foreach[B](f: A => B): Unit
  def map[B](f: A => B): Option[B]
case object None extends Option[Nothing] {
  override final val isPresent = false
  override def getOrElse[B](default: => B) = default
  override def foreach[B](f: Nothing => B) = ()
  override def map[B](f: Nothing => B): this.type = this
final case class Some[+A](value: A) extends Option[A] {
  override final val isPresent = true
  override def getOrElse[B >: A](default: => B): value.type = value
  override def foreach[B](f: A => B) = f(value)
  override def map[B](f: A => B): Some[B] = Some(f(value))
val twoPlusThree = Some(2).map(_ + 3)
twoPlusThree.foreach(println)
// 5
val ohOh = (None: Option[Int]).map(_ + 3)
ohOh.foreach(println)
// no output, since the `println` is never executed
Scastie link
I chose to show a Scala example first, even though the question is about C#, because it is somewhat easier to see what is going on in the Scala example. (For example, C# does not have upper bounds for generic type parameters, so we have to use A as the parameter type for the default value in getOrElse, which is however a contravariant position, which in turn means that Option cannot be covariant in A, and so on. Also, C# doesn't have a bottom type (type that is a subtype of all types), so we cannot have a single None object, we need a separate None<T> object for each T, and so on.)
In C#, this could look somewhat like this:
var twoPlusThree = new Some<int>(2).Select(i => i + 3);
twoPlusThree.ForEach(System.Console.WriteLine);
// 5
var ohOh = new None<int>().Select(i => i + 3);
ohOh.ForEach(System.Console.WriteLine);
// no output, since the `WriteLine` is never executed
interface Option<T> /* : IEnumerable<T>, … */ where T : notnull
    bool IsPresent { get; }
    T GetOrElse(T defaultValue);
    void ForEach(Action<T> action);
    Option<U> Select<U>(Func<T, U> f) where U : notnull;
readonly record struct None<T> : Option<T> where T : notnull
    public bool IsPresent { get => false; }
    public T GetOrElse(T defaultValue) => defaultValue;
    public void ForEach(Action<T> action) { }
    public Option<U> Select<U>(Func<T, U> f) where U : notnull => new None<U>();
    // In reality, you would probably have a factory method that caches one `None` for each `U`
readonly record struct Some<T>(T value) : Option<T> where T : notnull
    public bool IsPresent { get => true; }
    public T GetOrElse(T defaultValue) => value;
    public void ForEach(Action<T> action) => action(value);
    public Option<U> Select<U>(Func<T, U> f) where U : notnull => new Some<U>(f(value));
(Obviously, a real-world implementation would have all the IEnumerable methods, also IComparable would be a good idea, and we would implement Serialization and Deconstruction / Pattern Matching, etc.)
As you can see, it is structurally very similar to the Scala code. The main differences are:
  • The Scala version is closed, you cannot add any further subclasses to it. (sealed in Scala means "can only be extended within the same compilation unit", whereas final means "cannot be extended at all", i.e. like sealed in C#. Since Option is sealed, it can only be extended within the same compilation unit, and the only two templates that extend it are Some and None, both of which are final.)
  • The Scala version is covariant.
  • The Scala version only has a single None value. (Nothing is a bottom type, i.e. it is a subtype of every type. And since Option is covariant, Option[Nothing] is a subtype of every Option[T] for all T. Therefore, a single None can be used wherever an Option[T] is expected.)
Either types
So, what we had now was a type that encapsulates the notion that something either is there or it isn't there. In other words, it either is some type or it is nothing.
The other extreme is something that can be either one type or another type. This kind of type is called an Either type. It, too, can be easily expressed as an algebraic sum type:
data Either a b = Left a | Right b
This can be implemented in the same way as Option using inheritance:
sealed trait Either[+A, +B] {
  val isLeft: Boolean
  val isRight: Boolean
  def getLeftOrElse[C >: A](default: => C): C
  def getRightOrElse[C >: B](default: => C): C
  def either[C](f: A => C)(g: B => C): C
final case class Left[+A](value: A) extends Either[A, Nothing] {
  override final val isLeft = true
  override final val isRight = false
  override def getLeftOrElse[C >: A](default: => C): value.type = value
  override def getRightOrElse[C](default: => C) = default
  override def either[C](f: A => C)(g: Nothing => C) = f(value)
final case class Right[+B](value: B) extends Either[Nothing, B] {
  override final val isLeft = false
  override final val isRight = true
  override def getLeftOrElse[C](default: => C) = default
  override def getRightOrElse[C >: B](default: => C): value.type = value
  override def either[C](f: Nothing => C)(g: B => C) = g(value)
val s: Either[String, Int] = Left("Hello")
val i: Either[String, Int] = Right(23)
println(s.either(_.length)(_ * 2))
// 5
println(i.either(_.length)(_ * 2))
// 46
Scastie link
Scala has some other syntactic niceties that we can use. For example, generic types with exactly two type parameters can be written A Foo B instead of Foo[A, B]. So, if we rename our Either to Or, we could write A Or B as the type, which reads really nice. In fact, | is a legal identifier like any other in Scala, so we could also name the trait | and write A | B.
In C#, it would look roughly like this:
Either<string, int> s = new Left<string, int>("Hello");
Either<string, int> i = new Right<string, int>(23);
System.Console.WriteLine(s.Either(x => x.Length, x => x * 2));
// 5
System.Console.WriteLine(i.Either(x => x.Length, x => x * 2));
// 46
interface Either<A, B> where A : notnull where B : notnull
    bool IsLeft { get; }
    bool IsRight { get; }
    A GetLeftOrElse(A defaultValue);
    B GetRightOrElse(B defaultValue);
    C Either<C>(Func<A, C> f, Func<B, C> g) where C : notnull;
readonly record struct Left<A, B>(A value) : Either<A, B> where A : notnull where B : notnull
    public bool IsLeft { get => true; }
    public bool IsRight { get => false; }
    public A GetLeftOrElse(A defaultValue) => value;
    public B GetRightOrElse(B defaultValue) => defaultValue;
    public C Either<C>(Func<A, C> f, Func<B, C> g) where C : notnull => f(value);
readonly record struct Right<A, B>(B value) : Either<A, B> where A : notnull where B : notnull
    public bool IsLeft { get => false; }
    public bool IsRight { get => true; }
    public A GetLeftOrElse(A defaultValue) => defaultValue;
    public B GetRightOrElse(B defaultValue) => value;
    public C Either<C>(Func<A, C> f, Func<B, C> g) where C : notnull => g(value);
(Obviously, a real-world implementation would implement Serialization and Deconstruction / Pattern Matching, etc.)
Unfortunately, the Either type does not have the nice monadic properties of Option. (Unless you "bias" it to one side, that is.) So, we can't implement IEnumerable, Select, SelectMany, ForEach, and friends. We have to either implement everything twice, or always pass both alternatives. So, for example instead of ForEach we would have ExecuteIfLeft(Action<A>) and ExecuteIfRight(Action<B>), or ExecuteEither(Action<A>, Action<B>), and similar for Select, and so on.
This is essentially a Discriminated Union implemented in a language that doesn't support them.
Error types
Halfway in between Option (which only supports one type or the absence of a value) and Either (which completely generically supports two types) lies the Error type, which supports either a value or an error. You can think of it as a biased Either, where one type is fixed to be an error type (type Error[A] = Either[A, Throwable]). Because it is biased to one side, it satisfies all the monadic properties and can implement the LINQ Standard Query Operators (meaning Select, SelectMany, ForEach, etc. all prefer one side).
The semantics are similar to Option: it either returns the result of the whole computation chain, or it returns the first error and aborts the chain.
import scala.util.control.NonFatal
sealed trait Try[+A] {
  val isSuccess: Boolean
  val isFailure: Boolean
  def map[B](f: A => B): Try[B]
  def flatMap[B](f: A => Try[B]): Try[B]
final case class Success[+A](value: A) extends Try[A] {
  override final val isSuccess = true
  override final val isFailure = false
  override def map[B](f: A => B): Success[B] = Success(f(value))
  override def flatMap[B](f: A => Try[B]) = try f(value) catch { case NonFatal(e) => Failure(e) }
final case class Failure[+A, E <: Throwable](ex: E) extends Try[A] {
  override final val isSuccess = false
  override final val isFailure = true
  override def foreach[B](f: A => B) = ()
  override def map[B](f: A => B) = this.asInstanceOf[Try[B]]
  override def flatMap[B](f: A => Try[B]) = this.asInstanceOf[Try[B]]
object Try {
  def apply[A](f: => A): Try[A] =
    try Success(f) catch {
Scastie link
And again in C#
interface Try<T> where T : notnull
    bool IsFailure { get; }
    Try<U> Select<U>(Func<T, U> f) where U : notnull;
readonly record struct Success<T>(T value) : Try<T> where T : notnull
    public bool IsSuccess { get => true; }
    public bool IsFailure { get => false; }
    public Try<U> Select<U>(Func<T, U> f) where U : notnull => new Success<U>(f(value));
readonly record struct Failure<T, E>(E ex) : Try<T> where T : notnull where E : Exception
    public bool IsSuccess { get => false; }
    public bool IsFailure { get => true; }
    public Try<U> Select<U>(Func<T, U> f) where U : notnull => this as Try<U>;
I believe between these three examples, we have covered all of your use cases (two different types, a type or an error) as well as another common case (value that might exist or not).
In all three cases, we can use pattern matching, as you suggested. But actually, especially for Option and Try, it is even better to treat them either as collections (using ForEach, Select, SelectMany, Where, and so on) or as monads (in LINQ Query Expressions), because they just do the right thing by themselves without the need for any sort of conditional (whether that be an if statement or pattern matching).
All three of these are essentially your proposal #2, while also facilitating #3, but with well-known names and reusable, general semantics. In fact, many languages ship these three types in their standard libraries, e.g. Scala: Option, Either, Try. Even Java now ships with Optional, although unfortunately, this one does not implement the collection API.
Jörg W Mittag
  • 101,921
  • 218
  • 318
  • A potential problem using structs inheriting from an interface is that it will likely cause boxing. I think it is more common in .Net to reduce inheritance and use a internal flag to indicate the state. See [random github example](https://github.com/nlkl/Optional/blob/master/src/Optional/Option_Maybe.cs) – JonasH Sep 06 '21 at 14:32
-1
C# also has structures which are arguably simpler than classes, since they are copied more or less directly by value rather than allocated (presumably in the heap) and passed by reference.
C# also has several types included in the library, namely Tuple<type1,type2> (and Tuple<type1,type2,type3>, etc..), which means you can declare a return type as a struct containing two members without even having to declare a new or custom struct type, if you are willing to settle for non-descript field names like Item1 and Item2.
Newer C# also has simpler tuple syntax and destructuring assignment.
Erik Eidt
  • 33,282
  • 57
  • 91
  • @JörgWMittag yes agreed. If you want to return error vs. value, but, if you want to do what the OP said in the title (return multiple results), then product types... – Erik Eidt Sep 01 '21 at 19:00
  • Oh, I didn't notice that. In the question *body*, the OP writes (**bold** emphasis mine) "It can return `Stuff` **or** `Error`" and "Important for me is that code is […] robust (i.e. **no** weird cases when someone can **return both success and result by mistake** etc.)." which to me implies that the OP is looking for "either / or", whereas the title "return **multiple** results" implies "and". – Jörg W Mittag Sep 01 '21 at 19:05
  • @JörgWMittag, yes, hopefully this discussion will help future readers clarify the difference. – Erik Eidt Sep 01 '21 at 19:42
  • I've skipped depicting tuples here as container object are superior, because in implementation you can guard aganist case of multiple values, setting both at once etc. I think container object is superior here. – Shadow Sep 02 '21 at 07:07
