I have an eternal discussion in my work about why "error first" is "worng".
In order to ensure what I try to tell with error first is the following code pattern:
if condition:
    raise Error()
code
Instead of if-else approach
if condition:
    code
else:
    raise Error()
I think that the first one (error first) is better because you only check your error conditions, you avoid using else statement, by logical error will be raised and never you execute the code.
But on the other hand, probably race conditions or any strange reason, if you encapsulate the error inside an else you are always are setting the logic, and probably is defensive programming approach in order to avoid errors.
The question is there is any reason beyond its de facto standard (in javascript), or there are any other design reasons.
Edit
Another argument is that if only have one error is not enough to do "error first", but anyway I think that if you select an error template for checking the flow of your code you should following in each place including one error code.
Thanks
Tlaloc-ES
  • 387
  • More generally, this is called "Return Early." – Robert Harvey Aug 30 '21 at 18:25
    Rather than thinking in terms of how many errors, think in terms of what it does to enhance the readability of the code. The error first "do checks - write code" pattern reads as "here's what I expect to be true, these are my assumptions", followed by "here's the logic of the method expressed in a simple and straightforward way". With extensive if-else nesting, on the other hand, you have "partial logic - error check - partial logic - error check - some logic that has to do with code 15 lines above - error check - more partial logic - error check ..." – Filip Milovanović Aug 30 '21 at 18:48
I prefer the former, because if there are multiple errors then they are handled one after another without further indentation of the non-error code:
if error-condition1:
    raise Error("1")
    raise Error("2")
code
Compare with:
if not error-condition1:
    if not error-condition2:
        code
    else:
        raise Error("2")
else:
    raise Error("1")
Here not only does the regular code get indented twice, but the condition1 and Error("1") get separated further the more "code", and the more error conditions there are.  I also don't like the negation as I'd rather test directly for the error condition than the absence of the error condition.
There is another option, which is to swap the then- and else-parts.
    raise Error("1")
else if error-condition2:
    raise Error("2")
else:
    code
This is quite readable, though personally I still prefer the else-less version.
Erik Eidt
  • 33,282
  • 57
  • 91
    As I said, I’ve seen this 20 levels deep… – gnasher729 Aug 30 '21 at 17:21
  • It’s not only errors, it’s also trivial cases quite often that are handled separately. And sometimes it’s hard cases that are solved trivially by “divide and conquer”, and you only have real code for the medium hard cases. – gnasher729 Sep 02 '21 at 07:11
  • Not only it is more readable, if you later have to add one more check you do not need to touch the "code" lines to change their indentation level. It saves menial work and the diff in source control (which you are using, right?) will be more compact. – Rad80 Sep 02 '21 at 09:51
  • Worst, if you have 20 errors, then adding another one after error#12 makes it really hard to find where to put the code handling the error. And if you read the code, try finding the code handling error #7. – gnasher729 Sep 05 '21 at 11:28
I’ve seen code doing a few operations that could all potentially fail, with a 20 times nested if. Inserting another error condition after test #11 was practically impossible.
At some point a code structure that handles one condition after the other in a linear fashion is just better.
gnasher729
  • 42,090
  • 59
  • 119
