PEP 8 states the following about using anonymous functions (lambdas)
Always use a def statement instead of an assignment statement that binds a lambda expression directly to an identifier:
# Correct: def f(x): return 2*x # Wrong: f = lambda x: 2*x
The first form means that the name of the resulting function object is specifically
f
instead of the generic<lambda>
. This is more useful for tracebacks and string representations in general. The use of the assignment statement eliminates the sole benefit a lambda expression can offer over an explicit def statement (i.e. that it can be embedded inside a larger expression)
However, I often find myself being able to produce clearer and more readable code using lambdas with names. Consider the following small code snippet (which is part of a larger function)
divisors = proper(divisors)
total, sign = 0, 1
for i in range(len(divisors)):
for perm in itertools.combinations(divisors, i + 1):
total += sign * sum_multiplies_of(lcm_of(perm), start, stop - 1)
sign = -sign
return total
There is nothing wrong with the code above from a technical perspective. It does precisely what it intends to do. But what does it intend to do? Doing some digging one figures out that oh right, this is just using the inclusion-exclusion principle on the powerset of the divisors. While I could write a long comment explaining this, I prefer that my code tells me this. I might do it as follows
powerset_of = lambda x: (
itertools.combinations(x, r) for r in range(start, len(x) + 1)
sign = lambda x: 1 if x % 2 == 0 else -1
alternating_sum = lambda xs: sum(sign(i) * sum(e) for (i, e) in enumerate(xs))
nums_divisible_by = lambda xs: sum_multiplies_of(lcm(xs), start, stop - 1)
def inclusion_exclusion_principle(nums_divisible_by, divisors):
return alternating_sum(
map(nums_divisible_by, divisor_subsets_w_same_len)
for divisor_subsets_w_same_len in powerset_of(proper(divisors))
return inclusion_exclusion_principle(nums_divisible_by, divisors)
Where lcm_of
was renamed to lcm
(computes the lcm of a list, not included here). Two keypoints 1) The lambdas above will never be used elsewhere in the code 2) I can read all the lambdas and where they are used on a single screen.
Contrast this with a PEP 8 compliant version using def
s
def powerset_of(x):
return (itertools.combinations(x, r) for r in range(start, len(x) + 1))
def sign(x):
return 1 if x % 2 == 0 else -1
def alternating_sum(x):
return (sign(i) * sum(element) for (i, element) in enumerate(x))
def nums_divisible_by(xs):
return sum_multiplies_of(lcm(xs), start, stop - 1)
Now the last code is far from unreasonable,but it feels wrong using def
for simple one-liners. In addition the code length quickly grows if one wants to stay PEP 8 compliant. Should I switch over to using def
s and reserve lambdas for truly anonymous functions, or is it okay to throw in a few named lambdas to more clearly express the intent of the code?
