Related (but different) question:
I have always worked on small projects where editing a piece of code is easy: you modify the code, you recompile and in a matter of seconds you can play around with the compiled program.
Everyday one may end up doing the "edit compile try" loop hundreds if not thousands of times.
Some codebases however (e.g chromium) are huge, and require minutes to compile.
How do software engineers manage to efficently work on such large codebases? Do they recompile every time they make a small edit?
Doc Brown
  • 199,015
  • 367
  • 565
Acerbic
  • 69
  • If you are working with C++ , John Lakos' book "Large Scale C++ Software Design" may be useful to answer your question. – Doc Brown Jul 28 '21 at 14:15
Even in small projects, when you do a change, you don't recompile anything. In fact, the build is often performed in two steps: compilation and linking. If you modify two files which don't impact anything else in the code base, then only those two files are compiled (usually in parallel!), and the linker does what it needs to do with them.
Moreover, large projects are usually split into several components: shared objects (.so files) in Linux, or dynamic-link libraries (.dll files) in Windows. Each component can be complied independently, i.e. you can change a component and recompile it, without the need to recompile anything that depends on this component (unless you changed the interface).
Note that when working on a large code base, more often than not you don't even need most of the code. If, for instance, you need to change the internals of a class in order to make it faster, there are chances that all you would need is the class itself, and its unit tests; that's all. Your iteration would therefore be still a matter of seconds: edit, compile, ensure the tests are still green.
Only when you think you finished that you will check if you didn't break the class in a context of its integration. This involves not only compiling and linking, but also running integration tests, stress tests, load tests, and system tests. That's usually a lot of stuff for a developer machine even for a small scale project, and is often dedicated to the build servers. Essentially, you commit your changes, and the build is triggered, running a lot of stuff on a cluster of machines. How much machines depends on the scale of the project, and the budget. It may be just one or two servers, or it may be a farm containing hundreds or thousands of servers running the tests in parallel.
Arseni Mourzenko
  • 134,780
  • 343
  • 513
