I'm looking for architectural guidance.
I've got this monolithic application. It has a payment platform functionality, where payments are made, scheduled or on demand, via some banking API.
Payments used to be stored in DB, along with all relevant info like banking transactions, etc. Making the payment is inherently unstable error-prone process, where many bad things can happen like unexpected remote API outage, and code quickly becomes unmaintainable with all these try-catches and conditions. Additionally, I want the payment process to continue from where it failed.
So I decided to switch to event-driven microservice architecture, where I would present the payment process as Saga(state machine). Sagas are implemented as subclasses of given abstract class in framework of my choice, and it has its state.
Now I can logically split the payment process into multiple states, transitioning from one state to another upon arrival of event signifying that certain payment step had finished.
It all sounded logical until I started prototyping it and stumbled upon this question: do I move the payment records entirely to Saga state, or only put the data required for Saga execution, and leave all other fields in original DB table? If I leave all the data in original DB table I will need to fetch/update this data from Saga handlers, and I realize I could do all the same by handling corresponding events by separate handlers without Sagas at all. What benefits does Saga offer then? Orchestrating events manually without any Saga helper class still implements the Saga pattern, right?
Any good example code/articles would be great, because I only managed to find the code where the whole business entity was converted to Saga state.
