54
Our company have a support team and a dev team. We require reproduction steps on every bug report, however sometimes the support team submit reports without and become frustrated when dev close them as "cannot reproduce / cannot fix".
Support then make the argument "if I take my car to the garage, the mechanic will look at the engine for me to diagnose and fix the problem, I don't need to know how my engine works, and I shouldn't have to spell out to the mechanic that my car makes odd noises".
What's a good way to explain WHY reproduction steps are important in response to this sort of challenge?
Searching for the topic finds lots of links with information on HOW to write good reproduction steps, but I cannot find any links that answer WHY they're important from the point of view of someone who is not a developer.
Edit: similar questions / sites / blogs the advise seems to amount "Mark it as cannot reproduce and they'll have to fix their work and resubmit the bug. Eventually they'll learn to do it right the first time", but I'd much prefer a constructive discussion on why I'm saying I can't fix it so that there's genuine understanding of what sorts of things the support team should be doing rather than completing a template by rote and being upset when their work is rejected.
Chris
  • 525
  • if you are mostly focused on this then duplicate target question would fit better: [Getting users to write decent and useful bug reports](https://softwareengineering.stackexchange.com/q/132248/31260) – gnat Jun 17 '21 at 12:37
  • 65
    The mechanic analogy is just wrong. Here's a counter example: I have a car which has a battery that goes dead. I jump it, take it to the shop and they see no problem. That's annoying but imagine I dropped it off with no explanation. They wouldn't know if I had engine problems, issues with suspension or tires, or maybe I just wanted an oil change. I actually do drop off my car in their lot off hours and guess what, they don't even look at it until I call or drop by to tell them what I need. – JimmyJames Jun 17 '21 at 13:42
  • 72
    Good auto mechanics absolutely do ask for reproduction steps when diagnosing intermittent or obscure issues. – Jordan Rieger Jun 17 '21 at 20:38
  • 26
    On the old NPR show "Car Talk" with Click&Clack they always talked about intermittent problems and spent plenty of time asking "did it only happen at night? In the rain? 1st thing in the morning?" Listening to that show *taught* you why careful reproduction steps were important – Owen Reynolds Jun 17 '21 at 20:55
    As a developer, I am inclined to close as not reproducible, any bug that does not specify repro steps. Whenever possible, however, I reach out to the support tech's boss and get that support tech retrained or fired. I usually have plenty of well defined problems to solve already, so I really don't have the time to play guessing games, or twenty questions. It's the support tech's job to elicit as much information about the bug as possible. They may not be responsible for verifying that the steps do in fact reproduce the bug, but I expect to see at least a plausible list of steps. – jwdonahue Jun 17 '21 at 21:43
    If I can't reproduce the bug before I make any code changes, and I still can't reproduce the bug after I've made some code changes, how can I prove (to myself or to anyone else) that my code-changes actually fixed the bug? – Jeremy Friesner Jun 17 '21 at 23:08
  • An auto mechanic will absolutely drive your car around to try and reproduce those odd noises. On cars, being physical objects, it is also a lot easier to see when something is broken. Software is invisible. What the software does when we use it is the _only_ thing we have to go on. – Seth R Jun 18 '21 at 00:29
  • FWIW, the mechanic doesn't work for everything (especially, amusingly, as cars accumulate software). My partner's had intermittent error codes on her in-warranty car for ~9 months, and taken it in at least 3x to two different dealerships and ended up with "we can't find anything wrong; bring it in while it is doing it." It finally happened when she had time a few weeks ago. They still couldn't figure it out. They replaced the battery, reset the codes, and asked her to bring it back after 100 miles. – abathur Jun 18 '21 at 02:57
  • Reproduction steps are helpful because once fixed, it'll be easy to check if the bug is really fixed. Bugs can be fixed without the steps, but they surely do help. – Aulis Ronkainen Jun 18 '21 at 07:53
    `if I take my car to the garage, the mechanic will look at the engine for me to diagnose and fix the problem, I don't need to know how my engine works, and I shouldn't have to spell out to the mechanic that my car makes odd noises` - How does the mechanic know to start looking at the engine? What if she spends a couple of days investigating the electrical system, or starts stripping down the brake system? Would you be happy with that? Remember they're billing you by the hour. With no information as to what is wrong you might get a really big bill. – Qwerky Jun 18 '21 at 08:22
  • It helps knowing on the spot if the software was used in an unintended way. – MPS Jun 18 '21 at 08:42
    **I shouldn't have to spell out to the mechanic that my car makes odd noises** the mechanic lubricates the squeaky door but not the rattling of the engine when going 70 on the highway........"what is an odd noise?" – Pieter B Jun 18 '21 at 09:15
    Without reproduction steps, how else is the developer supposed to know what exactly is not working? If you bring your car to the garage and just say “it’s not working.” what are they supposed to do? – Michael Jun 18 '21 at 10:03
    When you go to the doctor, do you just say "My body isn't working correctly. Fix it!" and expect them to have *the vaguest clue* what exactly isn't working? No, of course not. ;-) – MathematicalOrchid Jun 18 '21 at 10:30
    "We need to be certain that we see what you see, in order to be able to verify that the problem that goes away is _your_ problem." – Thorbjørn Ravn Andersen Jun 18 '21 at 10:54
  • I feel like the analogy has distracted everyone from the actual, really good question being asked. – Paul D. Waite Jun 18 '21 at 12:29
    It's literally impossible to debug something if you can't reproduce it. Stop thinking about analogies as they are often misleading (especially when comparing cars to software development), and think about the actual situation: How can I know if something is fixed if I have no way to measure whether or not my changes stopped the bug from occuring? – ICW Jun 18 '21 at 12:49
  • If you can legitimately "mark it as unable to reproduce", it means the bug has repro steps. Marking a bug closed as "unable to reproduce" because it lacks repro steps is a passively-aggressively silly and inefficient way to teach the bug submitters to provide repro steps. You add a comment "how does this happen? Can you provide detailed steps to reproduce it, in the appropriate feld?" The leave the bug in the "UNCONFIRMED" or "NEW" triage stage until the details are given. – Kaz Jun 18 '21 at 15:06
  • My first car had an issue that never got solved. My guess is that this was - at least to some extent - due to the fact that the mechanics never "reproduced" the issue that only started after driving for some 20km. OTOH, if I hadn't told them, they would never have known there was an issue... – Sabine Jun 18 '21 at 15:08
    @IsaacCWay: Without reproduction steps (or an equally good description of the behavior) how do you even know there is a bug in the first place? There is a reason why most bug trackers ask for reproduction steps, expected behavior and actual behavior. – Michael Jun 18 '21 at 15:33
  • @Kaz Agreed. At my company, it would be frowned upon for a developer to just close a bug as "not reproducible" without talking to the reporter. They would be seen as lazy. They are expected to work with the bug reporter to find out how the bug can be reproduced. – pacoverflow Jun 18 '21 at 16:41
  • @Chris I wonder how the support team can provide good service with that attitude. Shouldn't they be interested in getting the same kind information from whomever they are supporting, in order to reproduce issues before forwarding them? Or is this a team that forwards issue reports unverified? – Michael Schumacher Jun 18 '21 at 20:12
  • Because bugs are not just about the software, but also have behavioral and environmental causes. For instance, if you didn't ask for steps to reproduce, you'd never be able to fix this: https://support.displaylink.com/knowledgebase/articles/738618-display-intermittently-blanking-flickering-or-los – haylem Jul 12 '21 at 15:10
14 Answers14
85
To follow on from the car analogy, I've used the following in other contexts:
Say you took your car into the mechanic and said the battery keeps dying. He runs thorough tests on the battery and the electrical system and finds nothing wrong. The mechanic asks you how to reproduce the problem and you get annoyed at the question and say it just happens randomly for no reason. The mechanic digs deeper and eventually discovers you've been frequently leaving your headlights on all night, which as a brand new car owner, you didn't realize would drain the battery.
Now you might say that the car should prevent the battery from dying if you leave the lights on. That's a reasonable claim, and many modern cars do just that. However, it was still impossible to make the diagnosis without knowing the steps to reproduce the problem. And at least in this case, they mentioned the battery. Some bug reports are like, "my car is broken sometimes but it's fine now" and they don't know why you want more detail. Also, the best mechanics will have the conversation first and not even charge you.
It's not a perfect analogy, because in a computer application, "leaving the lights on" might not have been a user error, but an unintended side effect of another feature, or subtle interaction between two features. You also can add preventative measures and logging even if you don't precisely know what the cause is. And I would consider a mechanic very poor if they just returned your car without at least having a discussion about possible root causes.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
    I like this answer - it also speaks to another subtle concern with steps where preliminaries are skipped. "1) Click here 2) see error page" looks superficially like good short repro steps, but has missed step 0 where last week someone deleted the required reference data from the database, so we can't repro it from following those steps on a test environment – Chris Jun 17 '21 at 14:14
    This and other answers expanding on the car mechanic metaphor could be summarized as "We need repro steps for software bugs and don't need them for cars because software is soft (could be almost infinitely complex) and cars are hard (physical and so limited in complexity)". – Mate Mrše Jun 18 '21 at 06:37
    The issue is deeper than just being able to diagnose a user's problem: *how can you know if you have fixed their problem, if you couldn't reproduce it in the first place?* – RBarryYoung Jun 18 '21 at 11:10
  • Working as intended... take your brand new diesel truck into the dealer, complaining about the tapping sound. Dealer returns it with a report of nothing wrong. Take it back in, again reporting tapping sound. Make the service person listen and then get told that is normal for a diesel engine ... it is working as intended and there is nothing wrong. Without knowing the steps to reproduce, you don't know if there is a problem, bug, or not, working as intended. Auto analogies are quite useful. – CGCampbell Jun 18 '21 at 11:38
    RBarryYoung's comment is on the mark. One of the biggest effects of vague problem reports is that the devs might fix a related but different issue than the user reported. I see this happen all the time - "X is broken" is reported, Dev fixes an issue they found with X, but the original problem remains. – Jim Jun 18 '21 at 15:01
  • @RBarryYoung I think in this case, the support team is wanting the dev team to find out how to reproduce it themselves, since they can't/don't want to figure out how to. – Drake P Jun 18 '21 at 16:52
  • @DrakeP Yes, I got that, but it's still the same issue. How does the dev team know that they are even working on the same problem? They could end up "fixing" something that no one else regards as a problem and/or that never occurs in production use. This has happened to me more than once. – RBarryYoung Jun 18 '21 at 18:13
72
True story: A family has a problem with their new car. Every sunday the whole large family meets for lunch, then someone drives to the ice cream parlor and buys ice cream for everyone. And then a strange thing happens: Whenever they buy vanilla ice cream, the car's engine won't start. If they buy any other ice cream, the car's engine starts. Mechanics couldn't find a fault.
Finally, the family invited someone quite higher up from the manufacturer for sunday lunch. And the guy drove with them to the ice cream parlor, vanilla ice cream was ordered, and the engine wouldn't start. This guy would have made an excellent software tester: He checked out the ice cream parlor. It turned out that they had a huge tub of vanilla ice cream that could be served quite quickly, while any other ice cream took longer. The fault had nothing to do with the ice cream flavour, but with how long the engine was turned off. Once they could reproduce the problem, the fix was easy.
But in the end, a bug that appears always and under all conditions is easily fixed. These bugs are most likely already gone before a tester ever sees the software. What is hard is problems that only happen under certain circumstances, and that will not appear 99% of the time. In that case, your bug report is not helping at all if you can't describe how you got the 1% case.
Good tools would also allow you to specify how reproducible a bug is. You may have a bug that even with your best efforts can only be reproduced 10% of the time. What does that mean? It means the developer won't give up if he tried it out three times and the bug didn't appear if he knows it is rare.
And when you write down steps to reproduce a bug: Consider that a developer cannot read your mind. If you don't write it down, he doesn't know about it. If you are not precise, he doesn't know what you are doing. If you are inaccurate, the bug may not be reproducible at all with your description.
PS. I've had bugs that would only happen to testers or even specific testers. For example: Tester does step 1, checks the screen, compares it to what his script says, does step 2, checks the screen etc. And there's a bug that only happens when you do step 1, 2, 3 and 4 several seconds apart, by the exact right amount. A second tester writes down the results, therefore takes longer, bug disappears. The developer knows all the steps, does them quickly in a row, bug disappears. Developer and Tester 2 go to Tester 1's desk and see him reproduce the problem. They ask him to do it slower, problem goes away. They ask him to do it faster, problem goes away. He does it at his own speed, bug comes up. This does happen.
gnasher729
  • 42,090
  • 59
  • 119
    For the last part, there is another real story. The [Therac-25](https://en.wikipedia.org/wiki/Therac-25) XRay machine had a software bug where filling the mode to XRAY and then quickly correcting it to electron beam mode caused the unit to use the xray calculation for electron mode.(Waiting a few seconds before changing the mode would have prevented this bug, the typing speed of people who use the machine on a daily base was to fast)This caused it to deliver an overdose to the patient of the machine, killing them from radiation poisoning. The machine has 6 confirmed kills by this software bug. – Ferrybig Jun 18 '21 at 06:56
  • I've had the same sort of problem to your "PS", but the other way round - testers knew all the steps of a wizard and would even anticipate where the next click would be even before the next screen appeared. Because they went so fast, a bug occurred due to (simplistically) a new record created in one step not being available to a later step yet ( in their very slow and underpowered VM). Real users never saw the issue because they actually had to fill stuff in at each step. – AdamV Jun 18 '21 at 11:37
  • @Ferrybig ok that Therac stuff is deep. Thanks for sharing. From the investigation report, quoting AECL technical support supervisor: _"After careful consideration, we are of the of the opinion that this damage could not have been produced by any malfunction of the Therac-25 or by any operator error." The letter goes on to support this opinion by listing two pages of technical reasons why an overdose by the Therac-25 was impossible._ – Simo Kivistö Jun 18 '21 at 12:04
    Is there a source for the ice-cream story? It's simply _too good an example_ to believe it's not made up. – mgarciaisaia Jun 18 '21 at 20:15
    @mgarciaisaia Collected in books of urban legends in the 1970s by Jan Harold Brunvand. https://www.snopes.com/fact-check/cone-of-silence/ – shoover Jun 18 '21 at 21:16
    "The Ice-Cream Car," in Brunvand's _Curses! Broiled Again!_, pp. 121-122. https://archive.org/details/cursesbroiledaga00brun/page/120/mode/2up?q=vanilla – shoover Jun 18 '21 at 21:21
18
Complexity and discoverability.
The mechanic fixes dozens of cars which are basically the same every single day. He has a list of tests, which is reasonably fast to check and covers detecting all expected and most unexpected defects.
Still, if the right back side flutters a bit beyond 50 mph, that's unlikely to be covered unless the driver highlights it. Actually, unless it is for the mandatory regular general inspections, not trying to describe your concerns to make sure they are addressed is at best odd, at worst irresponsible.
The software engineer has a far more amorphous test-target. First, it is one-of-a-kind. Yes, there is probably an automatic test-harness which is applied, but that that mostly covers the nuts and bolts, not the user-interaction, and it cannot be exhaustive. At least those will all work properly when released, so won't be reported by the user (anymore). All the inputs, all the dependencies, all the system-configurations, and myriad other outside influences, and on top of that it is hard to anticipate all possible interactions.
The coup de grace is that you cannot look at it, and say you have thoroughly tested everything, as even delineating parts of the application to check is non-trivial, and making sure you hit everything in that part is just about impossible. Try checking the border of an invisible shape for some kind of interaction. Better if that changes dynamically, best if the way you want to interact depends on that dynamic change. Try testing an ai, or anything else with mostly hidden highly dynamic state.
And that left out all the cases where the behavior is as designed and seems reasonable, but actually isn't, or at least doesn't help some group of users.
If the user says "Your software has a bug", the only thing the developer can say for moderately complex software is "probably. Where does it hurt, so I can look there."
And until that information is present, that's "no repro / cannot fix".
Deduplicator
  • 8,591
  • 50
    @Deduplicator, if anything, the interaction between QA and software developer has more in common with the interaction between a test driver and mechanic. And a testing driver would be expected to give reproduction steps for issues encountered. – user1937198 Jun 17 '21 at 19:57
    "you cannot look at it" made me realize the mechanic can look at the car. The programmer is looking at the factory that makes cars. (looking at code, rather than an execution) – Mooing Duck Jun 17 '21 at 21:53
    @user1937198 I heard there were certain Formula 1 drivers who were excellent test drivers, capable of telling a mechanic precisely how their car misbehaved, and as a result their cars were in a better state than the team mate's car. – gnasher729 Jun 17 '21 at 22:04
  • @MooingDuck The best analogy I've seen about this aspect is that source is akin to *blueprints* in manufacturing. Then, the binary is the product and the compiler is the factory. So just like other engineers, SW engineers produce blueprints. They just happen to have a factory on their desk too. And of course it's perfectly valid in this analogy that the mechanis is looking at the car and not its drawings, unlike the dev. – Angew is no longer proud of SO Jun 18 '21 at 07:12
    @AngewisnolongerproudofSO It's even worse; in practice, often those "blueprints" are really more of a "recipe" - i.e. with far less insight into what's actually going on, and any modifications (intentional or otherwise) frequently either break everything or result in subtle changes in seemingly unrelated parts of the product. Now let's not forget that the recipe you're talking about is expected to behave just as well when baking on a fire, and in a stone oven, and in that microwave on the ISS. And then you realize some blueprints are actually blueprint factories... – Luaan Jun 18 '21 at 09:00
12
You can't fix a problem you can't see most of the time. It depends in the context of your company BUT the developer will need to reproduce the error so it can be investigated/fixed .
An example:
Reported Bug : The xml response gives the wrong dates for departure times
Reality: The xml response gives the wrong dates for departure times , when the train is from a certain company at a specific station .
If the developer cannot see the specifics of this bug(train company, station) , how is she gonna pin point the error and proceed with appropriate actions ? Imagine there are thousands of trains and stations responses all working properly.
Cap Barracudas
  • 1,001
Lets take your literal question aside for a moment. Your description gives me the impression the core problem is not the bug reports themselves, but the disconnection between the people who notice the bug, and the ones who have to fix them.
Ideally, a user may notice a behaviour of a program which looks like a bug to them, calls the support team, and they use some screen sharing tool, or screenshots, and real data to reproduce the issue, so the support team member can either help the user directly, or come to the conclusion they need to get a dev involved.
But if they cannot reproduce the issue together, the support team member can already close the ticket as "cannot reproduce". If they can, the support team member now can call a dev and do the same with them: show them what works wrong - for this, the support team member needs to make sure they can demonstrate the problem, for example, within their test environment. If they now cannot reproduce the issue again, the support team member can either speak to the user again, ask for more information, or close the issue themselves.
That gives me the impression the support team member just try to write down their bug reports in words (not necessarily by reproducing the issue together with a user first), they don't try to reproduce issues in their environment and don't use screen sharing tools to explain the issue to the devs. And that's the real problem here - the communication workflow isn't ideal, there is too much "one way" communication, too much risk for "chinese whisper".
Interestingly, the answer given by @gnat in 2012 was pretty much going into the same direction: there needs to be a good bidirectional communication channel between users, support staff and devs. Of course, as that older other answer points out, such a channel can be established by using written text. Today screen sharing has become standard, it has made support communication a lot simpler. It is not a replacement for written tickets, but has proved itself as terribly useful.
Of course, reproducability is not only important for this communication chain, it is also important for the dev to be able to verify a bug fix works, but you asked for the non-dev perspective.
Doc Brown
  • 199,015
  • 367
  • 565
    At the risk of implying our software is hugely buggy, if I had a screen share for every bug that came in I'd get nothing else done, and I'd still have to write it up so that someone could do the work. All this would do would be to shift the responsibility of writing the ticket from support to dev. – Chris Jun 17 '21 at 14:09
  • @Chris: writing a ticket should be responsibility of the support team, but adding the missing details to make the ticket useful is something a dev **together** with the support member should do. Screen sharing is not a replacement for this, but it supports the process tremendously. – Doc Brown Jun 17 '21 at 14:30
  • Sometimes I call whoever raised something I can't repro to help me understand. If it still can't be repro'd, I sometimes hear the objection "well the steps are wrong but it's definitely broken, why can't you fix it?" I trust that they're right that there is a bug somewhere, but I still can't do anything until someone works out the steps. I have to reject this bug as can't repro, but I don't want to be saying "we need steps because I said so", I want to be able to explain why the steps are a prerequisite to my doing anything. Screen share or not makes no real difference to the conversation. – Chris Jun 17 '21 at 15:56
A few reasons:
  1. "Trust, but verify": A large portion of bug reports are not actually bugs but rather mistaken user conceptions of how software should work. Sometimes, the problem is not even in the software they are complaining about: they mixed up the problem in their mind and remembered the flow incorrectly. Software developers know this, and ask for the reproduction steps as a form of verification. The repro steps offer more concrete proof that the issue is real and affects their software.
  2. Ease of debugging: As a practical matter, it is much easier to resolve an issue if it can be reproduced consistently. You can attach a debugger and step through each line of code, watching the relevant variables change. Without repro steps, if you don't intimately understand the relevant code, you might not intuitively know where to find the bug. You might then need to add extra logging to all suspect code and wait for another occurrence.
  3. Self-education: Developers are often tasked with maintaining code they did not write in a system that they do not use. Repro steps help educate the developer on the context of the problem and how the system is actually used. This is invaluable background that can help them understand potential side-effects of any fix they attempt.
  4. Future regression testing: With good repro steps, a developer or QA engineer can more easily write an automated or manual test that can be added to the system to prevent future regressions of this bug.
I should also add that the car mechanic analogy is flawed because good auto mechanics do, in fact, ask for repro steps for issues that are intermittent or hard to diagnose.
Jordan Rieger
  • 227
To look at this a slightly different way:
When a tester fills out a bug report, they typically can't write down exactly what the problem is. They write their interpretation of the problem. When a developer starts working on that ticket, they base their work on their interpretation of what the tester wrote. At each step, there's lots of room for error due to poor communication, faulty assumptions about how the program works, or mistaken observations. Reproduction steps describe the problem in an objective way that retains its accuracy, even through multiple layers of non-technical middlemen that may not all be fluent in the same language.
The other aspect is that reproduction steps provide a "definition of done". If I follow the steps and no longer see the problem, then I've fixed the issue. Without reproduction steps the situation is ambiguous. Did I fix it? Or am I just not doing the right thing to trigger the problem? It's hard to say. Situations like this are where you see bugs go through multiple cycles of fixed->re-opened before it gets fixed for good. It saves time for the tester and the developer if the tester provides the reproduction steps up front.
bta
  • 1,003
There are two somewhat related reasons, I think.
First off, the car mechanic analogy is pretty badly flawed. For one thing, cars wear out in ways that software does not. Also, the mechanic is not the guy who designed and built the car. He (or she) is someone whose job it is to diagnose and repair problems. The role is more akin to QA than design.
Another thing to keep in mind that if someone who's reporting a bug doesn't think it's important to describe the bug carefully, or with reproduction steps, it's probably because they imagine that the bug is so obvious that no one could fail to miss it after even a cursory inspection. We'll come back to that.
Finally, of course, just about any modern software application is almost infinitely more complicated than a "simple" automobile. It's going to have gobs of different features and functions and usage patterns. How one user uses it may have almost no resemblance to how another does.
So the first of my reasons is that, like it or not, developers tend to imagine that their code is perfect. They tried hard to make it so, they tested it before they released it, it passed all its unit tests before they released it. And if nothing else, they know that their code works perfectly when it comes to the things they most commonly test it on. So if you hand a developer a bug report about his code, without much description, imagining it's obvious, the developer may or may not "put the code through its paces", but if he does, it's going to be with his preferred usage pattern -- the one he already knows it will pass handily. So he's totally predisposed to say, "Cannot reproduce, user error".
And then the other reason is is that users are probably making more heavy use of the older and more established features, while developers are always working with (designing and implementing and testing and using) the brand-new features that Marketing wanted in the new release. So if (as not uncommonly happens) a new feature inadvertently introduces a bug into an old, long-established feature, and a user notices and complains about it, and even if it is a glaring, showstopping bug that would be immediately noticed by any casual user, it's still not likely to be noticed by a developer, because the developers never use that old feature any more, they may have forgotten it even existed, because they're all consumed working on the brand-new features.
So, bottom line, careful descriptions and reproduction steps are necessary because the alternative -- just saying, "there's a bug, it's obvious, you'll see it right away" -- is too likely to be false.
Steve Summit
  • 137
    I think that third paragraph may no longer apply: https://spectrum.ieee.org/cars-that-think/transportation/advanced-cars/software-eating-car – Jeremy Friesner Jun 17 '21 at 23:16
  • I'd also add that: A - Software can most certainly "wear out" if it's not self-contained and relies calls to other software that can change or especially internet APIs(in which case it can wear out much quicker than a car) and B - given high turnover in many software projects, the person trying to diagnose the issue is not the one who wrote the code that's causing it and is quite often reading it and going "W-T-F does this do!?" – Eugene Jun 18 '21 at 16:01
  • @Eugene (A) Sure, but go back and read what I wrote! (I didn't say software doesn't wear out!) – Steve Summit Jun 18 '21 at 16:21
  • @SteveSummit fair enough, on a more careful re-reading, I see I misunderstood you – Eugene Jun 19 '21 at 00:10
To add to the other answers, sometimes of course you do have to investigate a problem that you don't know how to reproduce. We had a customer once with a database corruption, with no idea how it occurred; I was supporting the database software and had to work out a possible sequence of events that could have led to the corruption, working backwards from the symptoms. It took a week, and at the end of it, I had a possible explanation, but no evidence that it was the correct explanation. So the real reason developers ask for a repro is because it reduces the effort needed to find an explanation for the problem, and increases the likelihood that the explanation will be correct.
Michael Kay
  • 185
  • +1. E.g.: I use a particular online LMS (learning management system). My courses this semester have a bug where initial posts with math symbols, by myself and students, are always corrupted. I've escalated it several levels with the company, sent replication videos on multiple browsers, etc., but the devs are stumped and tabled pursuing it. Which I sort of understand, on a priority basis, if I'm really the only instructor so hit. So this answer is an important addendum regarding the cost-benefit analysis of pursuing certain intermittent or rare bugs. – Daniel R. Collins Jun 17 '21 at 23:36
The Software Bug/Defect might not be a bug with the software itself, but a combination of the Software itself with a specific configuration.
Reproducibility steps do help verify that a specific issue is reproducible, and raises flags to the mechanic if, for example, you tell him the car doesn't have its steering wheel working properly on the road, but it does work in the mechanic's shop when they test the car there.
This could be thought of as similar to browser compatibility issues with a web based application (i.e. the "It works in newer browsers, but not in the browser the client is using" problem), but we can also see this elsewhere in the software configuration.
In some cases, the way a piece of software operates in production versus a staging server, versus a development server, could be widely variant, in cases where the software team recognizes that we don't want certain production aspects to be working as production level things, when in dev environments, or staging environments, but do want them working as production in production environments. For example, an E-commerce site doesn't make actual actionable orders with real money based on developer testing the workflow for adding an item to a shopping cart, or in paying in a shopping cart.
What reproducibility steps help with is determining if the error is in one of those steps. With a car, you might need to add additional details in case it turns out Your car is pulling a Volkswagen style effect in the mechanic's office and appearing to work properly at achieving their preferred goals.
It's been dubbed the "diesel dupe". In September [2015], the Environmental Protection Agency (EPA) found that many VW cars being sold in America had a "defeat device" - or software - in diesel engines that could detect when they were being tested, changing the performance accordingly to improve results. The German car giant has since admitted cheating emissions tests in the US.
In this case, you would likely need to tell your mechanic what was going wrong, especially if they're having issues reproducing it locally - they can't verify if it was broken before they sent it to the environment where the defect is being found.
Ideally, situations like this are rare in practice, but having steps to reproduce will allow a developer to verify that this is consistent behavior across environments, or whether this behavior comes across as a result of a configuration that they will need to look into why that configuration gives different behavior, especially if that behavior involves a different result than the testing behavior implies it should be.
Questions
As a thought experiment how many questions does your software ask and answer?
As an approximation search for words like: if, for, while, interface. Sum up their counts. That is a low ball-park figure.
Now when this software executes it plays a choose your own adventure story walking through each question and bouncing to this page or to that page.
A simple program that does 1 thing like copy a file, still has many paths it can take. A Large file vs a small file, from/to a fast/slow drive, across file systems, different filesystem paths.
A complex program has infinite paths, like just about any GUI program. Every user event occurs at different times, in different contexts, producing different layerings of response.
As a very rough thumbnail. Presume your system has roughly operational life time in seconds * factorial(the number of decisions) unique paths. There is a bug in one, or more of those paths. Find it.
If you aren't quaking about the factorial in that approximation, you really should be. Its get large really fast. The more complicated the program, the even quicker it grows. This is why a large program is guaranteed to have bugs, and why so much effort is put into making programs simpler and smaller.
Bug Reports
This is why it is so essential to describe as much information about the bug as possible.
The basics like:
  • What was wrong.
  • What it should have been.
  • Which screen, report, extract, email.
  • When it has occurred
  • Who it has occurred to
  • Which version
... are important. They help close down a lot of possibilities for where the bug could be lurking.
But in a complex software eco-system its just not enough.
Ideally there would be a testing tool that support have access to that allows them to recreate the situation inside an automated test. Even if the test is slow, and does way more than it really needs to. All of that can be worked on. The important part is that it exactly reproduces the issue.
Short of having that the next best tool is a manual test. Do this, then that, click this, and voila. This is also know as steps to reproduce. The more accurate these steps are, the easier it is going to be to find the bug. If these steps are inaccurate/not there then it is pure luck if the developer spots the bug.
Analogy
Also to the description of a mechanic and a driver, its the wrong analogy. Support are the mechanics. The driver of the vehicle is the client. Developers are the designers working on the car production factory.
Support do need to know what components make up the vehicle, and be able to describe accurately the effects of real world usage on those components. IE. Did you know the computer board A, burns out really quickly for high way driving users? In software speak Did you know that the last day of the month batch process X takes 3 times longer to run, but the input is the same size as every other day that week?
If support just communicates back to the developers. Hey your product is broken. you can expect them to be ignored, because of course its broken. It arrived broken, or it has been misused to the point of breaking. That's supports problem.
What is not supports problem is a structural defect with the product itself. Not with how it was delivered, or how it was used. They would communicate this exactly like a mechanic would to the car manufacturing company. In circumstance X, Y, Z. Following these normal system usage patterns. Some P% of the time Q happens. Doing F reduces P% or increases P%. If you do M the Q changes to Q2.
Kain0_0
  • 15,888
Simple tell them, "if I can't reproduce it, I'm unlikely to have the time to find and fix it."
Testers should always record everything they see (with details about / debug info on what they were doing at the time), even if they can't reproduce it. Once a bug is found, the test team need to figure out what is causing it or it may be impossible to fix. Having a working atmosphere where programmers come over and chat to testers makes a huge difference here as there's often a lot of background information from both sides that does not get communicated in a bug report.
Finding and fixing these bugs can be incredibly challenging for both sides. It may end up being a decision for the project lead - ignore it and put it out or devote more resources to finding and fixing it.
David
  • 271
The fundamental problem with this analogue is that Support aren't the customer. They work for the "garage". They're part of the chain of people who are paid to be there in case of "car trouble". If they're getting paid, this analogue doesn't work.
Assuming they aren't rushing to rip up their paycheques, they need to take part in a division of responsibilities to help "fix the car".
Why are they best placed to be the ones to understand and reproduce?
Because they are closer to the customer. They can leverage their closer communication with the customer to figure out how the issue presents and they can use the knowledge they acquire during that process to provide very fast feedback to similar future queries. Passing the buck on this leads to support staff who don't understand the product, which isn't good for anyone.
Because doing this isn't a core competence of software development. Putting developers general work that they have no special ability at is a poor use of an expensive resource. Even if support people weren't cheaper (and let's assume they aren't, because that can come across as offensive), they should be better that this kind of work because it is part of their competence. Good support staff understand the product and how the users use the product. Working together, support and developers can make a better product for everyone by playing to their strengths.
So is it just up to them to change?
No. When Support are in the mode of just forwarding issues, it could be because Developers and Product professionals haven't provided them with the tools they need to understand the system and reproduce issues. They could be resistant to reproducing issues because of something like that, and I suspect you'd only find out that by talking to them.
Nathan Cooper
  • 1,319
Your own question is basically a bug report in disguise, and it lacks repro steps.
"There is a bug in our support team. They don't understand the purpose and meaning of repro steps."
So you say, but you have not given the repro steps by which this hypothesis was formed: what are the exact words that they said, in response to what, in what context?
Maybe they were just complaining about an overly rigid bug reporting style.
Bugs are rarely described without implying some of the repro steps. We have that as a separate field in a bug database to encourage detailed, precise, specific repro steps. This is because the issue may hinge on a key detail which is tangential to what appears to be the overall repro step.
However, some bugs really don't need elaborate repro steps; they can be inferred from the bug description. Suppose the title of the bug is Device burst into flames on power-up after Firmware C was flashed. All the info you need is contained in the topic; it hardly needs a Description field any more, let alone Repro Steps. That can literally be the entire bug report. (Still, repro steps could reveal some mistake, like that the submitter deviated from the recommended flashing procedure, or referenced the wrong firmware path name or something. But say none of that is the case. The background assumption is that the correct procedure was followed using the correct inputs; that's the implicitly understood repro step.)
If you have some bug submission validator that won't let you submit a bug without Repro Steps, that would be annoying if you're often submitting bugs which don't require them.
It could also be that the support people are frustrated because they are not getting clear repro steps from the customers, but when they escalate problems to the bug stage, those are required.
The support people may feel that since neither they nor the developers know what the repro steps are, the developers should be the ones to step up to bat and figure out the repro steps, since they know the product internals.
Remember, the support people are handling third parties. So when they talk about taking a car to the mechanic, they may be thinking of taking someone else's car to the mechanic, without a sufficiently detailed problem indication from the car owner. In that case, the mechanic is in the better position to figure out those details than the person who conveyed the car.
Another possibility is that the support people know the value of repro steps but are looking to engineering to help them explain it to customers, just like you're doing by going to StackExchange. That is important because if that is so, the explanation has to work for end users. Your support people are not getting repro steps, and would like some better scripts on how to obtain them, especially from certain irate customers who give them flippant mechanic analogies.
The question, "as a customer support agent, how do I handle customers who insist that the repro steps are a puzzle for support to figure out" is subtly different from "as an engineer, how do I convince my customer support people of the value and importance of repro steps?"
It's hard to believe that you would have people in support roles who are so unqualified that they question the value of repro steps per se. If so, that is a big problem in which the repro steps discussion is just a small part.
Kaz
  • 3,572
  • 30
