I have a method where I fetch user input, check if certain values exist, and based on that build my own custom input object that I would use to search in a database. The code for the search method is as follows.
public SearchDocumentResult searchData(EmployeeInput employeeInput) {
EmployeeInput getEmployeeInputForSearch = buildApplicationInputForSearch(employeeInput);
if (employeeInput != null) {
return super.searchForExactData(getEmployeeInputForSearch);
} else {
return super.searchForCloseMatchData(getTestPersonInput);
The methods with multiple if checks on the input are as follows. Both the below methods and the above method exist in the same class.
private Application buildApplicationInputForSearch(Application applicationInput) {
Application.Builder applicationForSearch = Application.builder();
String jobIdFromInput = applicationInput.getJobId();
applicationForSearch.withIsTagged(applicationInput.isTagged());
if (!StringUtils.isEmpty(jobIdFromInput)) {
applicationForSearch.withJobId(jobIdFromInput);
FormSection formSectionInput = applicationInput.getFormSection();
if (formSectionInput != null) {
this.buildFormSectionInputForSearch(formSectionInput);
return applicationForSearch.build();
private FormSection buildFormSectionInputForSearch(FormSection formSectionInput) {
FormSection.Builder formSectionForSearch = FormSection.builder();
String formCountry = formSectionInput.getCountry();
Map<String, String> employeeQuestions = formSectionInput.getEmployeeQuestions();
Map<String, String> applicationQuestions = formSectionInput.getApplicationQuestions();
List<String> formNames = formSectionInput.getNames();
if (!StringUtils.isEmpty(formCountry)) {
formSectionForSearch.withCountry(formCountry);
if (formNames.size() > 0) {
formSectionForSearch.withNames(formNames);
if (employeeQuestions.size() > 0) {
formSectionForSearch.withEmployeeQuestions(employeeQuestions);
if (applicationQuestions.size() > 0) {
formSectionForSearch.withApplicationQuestions(applicationQuestions);
return formSectionForSearch.build();
The EmployeeInput
is a model class that gets generated through a library and therefore I cannot make that use Java Optional for fields that may or may not exist. Using this EmployeeInput
object as it is, how can I make this code more readable, with less if conditions? Any help would be much appreciated.
