There exists different composition arts/techniques, i will present in the following some of them.
The question then is do you know more techniques additional to my presented ones?
And then the important question is, what kind of different makes it from the client perspective, how should i access from a client a compositionend objectgraph or in an other way asked, which composition-technique is client-friendly in the context of a good object orientented design, which depends on the Law of Demeter?
Which other dependencies could be out there, let me go more into that direction (using the compostion A) and what to go into an other direction (using composition B)
i have choosen my examples with the approach extending a root object, which is initially used by the client in its behaviour:
This question is related to that one: No trivial god-class refactoring
i have an object and a few methods in it
//also called MyObject1
class MyObject{
doSomething1(){}
doSomething2(){}
and now i want to extend this object with more methods, for example a doSomething3
which acts on the state of that object and maybe on some kind of "own" state.
so there are now different ideas how i can achieve this:
- add this method + its more membervariables, which are needed, to the existing class
- create a new class
MyObject2
and write it down into this class
if i decide for the secound solution, then the question is how to combine MyObject
and MyObject2
I can integrate
MyObject2
intoMyObject
class MyObject { MyObject2 myObject2 = new MyObject2(this) ... doSomething1(){} doSomething2(){} }
i can let
MyObject2
standalone, but when is the question, how the client get access toMyObject2
, if he has access toMyObject
Third class, that combine the other two
class ThirdClass { MyObject myObject = new MyObject() MyObject2 myObject2 = new MyObject2(myObject) }
The client have then in option 1) and option 3) the following possibilities:
....myObject.getMyObject2().doSomething3();
....thirdClass.getMyObject2().doSomething3();
Edit (because the solution from Greg Burghardt is a trivial solution, but correct, to my simple examples, but covers not the main-problem):
So let us say we have a MyObject3
built up the same way as MyObject2
, depends only on MyObject1
(it's a synonym for MyObject without the 1
, to make clear that i dont have type-mistake here), and a MyObject4.... MyObject2-4
don't need to know each other because they extend only the behaviour of MyObject1
And then i have a MyObject5
, which depends directly on MyObject1
and MyObject3
The question is the same, how should i compose that objects, to get access to all functionality of all of these objects from client-side? Which of these objects is the root-object, do i have a "third" object which acts as root-object?
