I am curious if the following example of testing a class with protected methods is fine.
For example, say you have the following class Foo that has method a() of return type Bar:
class Foo {
    protected Bar a() { ... }
    // ... other stuff
And the following test class TestFoo (using JUnit):
// Question: is extending a source class a bad practice?
class TestFoo extends Foo {
    @BeforeAll
    public void setup() { /* some setup stuff */ }
    @Test
    public void testA() {
        Bar value = a();
        assertEquals(value, ...);
Also, let's assume that I don't want to use libraries like PowerMockito (say, I don't want to deal with anything that uses Java Reflection API) and I want to keep it really simple. I know there has been a debate on whether to unit-test private methods or not and that can be applied to protected methods, but assuming you want to test this protected method, is this approach correct?
Or am I just crazy?
EricSchaefer
  • 2,091
  • 30
oneturkmen
  • 165
    Have you tried this? I don't think it will compile, because a private method is not visible outside the class which declares it. `TestFoo` can't call `Foo::a`. – bdsl Mar 10 '21 at 18:52
  • @bdsl, thanks for the good catch. It should have been `protected`. – oneturkmen Mar 10 '21 at 18:55
  • Right, that makes sense. – bdsl Mar 10 '21 at 18:56
    This slightly obfuscates the construction of Foo. If you just go `new Foo()`, no problem. But it there are multiple constructors with complex arguments, it adds work (Bar will need a lot of calls to `super(x,y,z)`) and may be slightly confusing. Also, many classes are **final** and cannot be extended. I personally think this is a dubious practice, for reasons just like this use case, but others differ. – user949300 Mar 10 '21 at 19:24
  • @user949300, thanks for your input. I see, my example might be too simplistic/unreal in practice. – oneturkmen Mar 10 '21 at 19:35
  • For folks who are down-voting - at least, provide a reason why you are down-voting? Down-voting without any comment (constructive criticism is welcome) is bogus. – oneturkmen Mar 10 '21 at 20:22
    Yes, its fine. Sometimes it is the best approach, in fact. But a limitation is that the class itself has to be ready for it - you have to be able to create a child class instance, for example, and maneuver it to the correct state. And to do _that_ it should be with documented or at least well-understood methods of the class, otherwise your test will be fairly fragile. – davidbak Mar 10 '21 at 20:28
  • It isn't always possible. Your class may be `final` or have `private` methods. I would prefer to have a universal solution. – GHopper Jan 25 '23 at 02:26
One of the dangers of testing is locking down an implementation. Tests should make it easier to refactor not harder. Tests that don’t focus on the public interface tend to lock down implementation.
Extending a class let’s you come in the back door and fiddle with non public stuff. That puts the focus of testing in the wrong place.
You may feel the private stuff needs testing. However, if you can’t achieve code coverage by testing the public interface then you have too much code. Get rid of the unreachable code. Maybe put it in a junk folder until you have a real use for it.
For example, you have a protected constructor. Fine. If it exists for a reason then something somewhere uses it when it’s accessed publicly. Test that.
candied_orange
  • 102,279
  • 197
  • 315
Sometimes classes are designed such that they can only be used as a base-class but where you still want to test them independently of the existing derived classes.
In such cases, the usual pattern is to create a derived class specifically for testing the base class, which is independent of the class that houses the actual tests. That pattern can also be used to gain access to protected members for testing.
It would look like this
class FooForTest extends Foo {
  public Bar public_a() {
    return this.a();
class TestFoo {
    @BeforeAll
    @Test
        FooForTest foo = new FooForTest();
        Bar value = foo.public_a();
Bart van Ingen Schenau
  • 71,712
  • 110
  • 179
  • I've often thought about this as well, but I've never gone this route. I always felt it was more appropriate to test the base class via a concrete derived class used in production code. Still, +1. Just because I haven't found a use case for this yet doesn't mean I never will. – Greg Burghardt Mar 11 '21 at 14:55
The simplest way - both from an implementation standpoint and from a readability standpoint - is to use the tailor-made tools provided to you rather than rolling your own for each thing you want to test. What you're doing is how some of these tools approach testing protected/private methods, but they'll do it in a more consistent way and without you having to maintain all of that scaffolding.
Telastyn
  • 108,850
  • 239
  • 365
While I would not use this pattern for new code, it is a well known and helpful pattern for testing legacy code. It comes in two flavors:
  1. the extending class is a class that is only used in test
  2. the test class (fixture) is itself extending
#2 is called the Self ShuntPattern and was first described by Michael Feathers, IIRC.
EricSchaefer
  • 2,091
  • 30
