I have 1000 lines in a text file. I want to read them into some data structure[DS].
After reading them, I will be randomly picking 50 lines from the DS (using a Random Number Generator). Next time 50 more & 50 more the time after that. Each time I use 50 lines from the DS, I want to delete them from the DS. So after the first iteration, I will have 950 items, after the second iteration, I will have 900 & so on.
So 3 operations
  1. Read from file & insert lines into the DS
  2. Random access from the DS
  3. Delete members from the DS in a random manner.
Consider both these requirements, which would be the best DS to use?
FWIW, I will be coding this in python.
user93353
  • 441
Whatever?
1000 lines aren’t enough to tax any modern computer or even mobile device. And you’re unlikely to actually delete the entries. Read the contents into a list or array, sort using rng as your sort criteria, then increment an index (or pointer) over the collection. If you want to increment 50 at a time, go nuts.
I’m not familiar enough with Python to know what to recommend in particular.
For larger problem sets, you might consider a kind of hash table where the random number generator results split the line numbers into 50 item buckets, then you take one bucket at a time.
Telastyn
  • 108,850
  • 239
  • 365
  • Just this. Looking for the "best" solution for trivial problems is premature optimization, any solution that isn't obviously wrong or convoluted is ok. The random ordering function in python is `random.shuffle()` (https://www.w3schools.com/python/ref_random_shuffle.asp). – Hans-Martin Mosner Mar 10 '21 at 06:26
To consume 1000 lines of a text file in random order in chunks of 50 each, you don't need to care much about data structures, the built in lists and iterables of Python will work perfectly. Shuffling the 1000 lines first then slice it into chunks of 50 elements will be equivalent to the scenario you described:
import random
def random_chunks(file, chunksize):
    with open(file, 'r') as f:
        lines = f.readlines()
    random.shuffle(lines)
    for i in range(0, len(lines), chunksize):
        yield lines[i:i+chunksize]
for chunk in random_chunks('README.md', 50):
    for line in chunk:
        print (line)
Wolf
  • 630
