Here is the situation. System A sends the notification as it completes the work items to System B. System A does not know how many items the project consists of. It's just a pass-through system. System B knows the number of items. Once sys B receives the notification for the last item, it has to wait for the final authorization and send the close-project notice to system A.
My question is should I try to implement the entire communication as:
  1. one asynchronous REST API, or
  2. two synchronous APIs, one for items completion (from A to B) and the other one for the final approval transaction (B to A)?
system A ----------- system B
item 1 done ------------ >
<---------- got it ------
item 2 done ------------->
item n done ------------- >
<-------------------- ----got it but waiting for the manager's approval. may take weeks.
.... may take days/weeks
< ------------------------Manager signed. The project is closed and here are the details.
Glorfindel
  • 3,137
An API may be synchronous where low latency is a requirement and asynchronous where data or service availability and connectivity are low. So I would suggest doing it asynchronously because as you say in your example, the final approval(from B to A) may even take weeks.
  • In order for this to work the hosting process may not fail or restart for the duration of the call. If there are a few of these being kicked off every day then it's necessary for the hosting process to stay up 100%, which is unrealistic. – Jason Weber Mar 08 '21 at 03:22
With a timeframe of days or weeks you may want to think about what happens if there is a failure while waiting for the confirmation. If you want this to just work and be resilient to the host process being restarted then 2 calls (and saving the current state e.g. waiting for reply) in the database makes sense. You're on your first steps to creating a workflow engine, by the way. If you have many more of these human powered workflows to support it might be worth taking a look at them. Good luck!
Jason Weber
